Hello I bought this case in the link. http://www.newegg.com/Product/Product.asp?Item=N82E16811125468 I want to put a full window in it but there are vent holes on the sides that are stopping me from making a big window. Do you guys no of anyways to fix this problem? Thankyou
Call me crazy, but I almost think you should curve the window along the same curve the vents are. It would be original if nothing else.
What if you cut the window so that some holes are still left on the side, but only like 2 or 3 rows of holes. That would give you a large rectangular window.
Why is that? I'm curious. For the window, I'd do like Warrior says and have the window curving down maybe 1/2 an inch away from the air holes right the way down, reckon that'd look extremely cool.
I love that case, I used to have one made by chieftec. Just that powersupply mount would bother the absolute piss out of me. I guess it is just one of those things. I would try to find a new plate for it, or make one. It just kind of looks doopy from the back IMHO.
I have the same case! Also, the pic on newegg shows the PSU standing up, but in mine, it actually sits flat, as seen here:http://www.chenmingusa.com/901A_layout.jpg
Well my Chenming isn't modded, so it looks the same as yours. However, there are a few cases that are the same as that chenming. Antec makes one, and Chieftec as well.
