Build Advice Need RGB case recommendations
Discussion in 'Hardware' started by numanoid, 6 Dec 2018.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guys
    I need an RGB case with 2 rear fan connections so I can mount my H100i at the rear as the case I have is absalutely rubbish at cooling from the front... Any recommendations please thanks guys
  2. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    The ONLY case I can think of with 2x 120mm rear mounts is the massive and massively expensive Corsair 1000D. Oh, and it has RGB fans. Because value for money.
    I don't think I've seen any other cases with more than 1x 120/140mm rear fan mate.
    Edit: Just go for a decent case with a vented front panel and top mount for double or triple rads and exhaust out the top. Add your own RGB fans et voila.
  3. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks matey, yes I'll look into a case with decent front cooling.... Here's the case I've got, you can see the problem I have Game Max Gaming Mid Tower Case https://g.co/kgs/6wtT6g thanks again matey
  4. Sentinel-R1
    13 Oct 2010
    Looks like you can get the h100 on the roof mounts, providing they'll clear VRM/RAM. In the meantime, I'd ditch the front glass panel. Doesn't add anything aesthetically and is suffocating your airflow as there's zero intake space between front, side and top panels.
  5. numanoid
    numanoid Modder
    26 Apr 2009
    I'm just going to sell this case bud, not sure how roof mounted radiators work as heat rises so do i push or pull from the top cheers bud...
  6. Sentinel-R1
    13 Oct 2010
    In a roof mount, always go for exhaust.
    A) heat rises, so don't fight it.
    B) means your not sucking in the dust that settles on top of the case
  7. numanoid
    numanoid Modder
    26 Apr 2009
    Thank you matey I might just try that but aren't you pushing hot air from the inside through your radiator and out thank you
  8. Sentinel-R1
    13 Oct 2010
    Yes, CPU will run about 2c hotter than the other way BUT it won't raise the ambient temp inside the case and cause GPU to throttle as you're dumping the warm CPU air outside the case. That's more important IMO.
  9. numanoid
    numanoid Modder
    26 Apr 2009
    I'll give that a go matey, thank you for your help
  10. Sentinel-R1
    13 Oct 2010
    No problem bud. If temps don't improve much, unscrew the front panel glass and set aside, then test again. I bet you drop about 10c off load temps!
  11. numanoid
    numanoid Modder
    26 Apr 2009
    OK matey, will let you know how I get on
  12. numanoid
    numanoid Modder
    26 Apr 2009
    Just bought a sama ark full size case it's also rgb and tempared glass so happy days lol
  13. Sentinel-R1
    13 Oct 2010
    Nice one. Sling a few pics and your thoughts in when you've transferred it over.
  14. Arthur
    Arthur It's for 'erberts !
    24 Nov 2009
    Well done matey....lol
