Hardware Nesteq Nova 600W External PSU
Discussion in 'Article Discussion' started by Tim S, 3 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. naokaji
    naokaji whatever
    8 Dec 2006
    well.. i dont think that will be a psu many will buy... but, some modders will prolly be happy pants about it.
  3. phuzz
    phuzz This is a title
    28 May 2004
    It's a shame it's voltages ain't much good, because the other problems of cable lengths etc. would be even easier to fix than on a normal PSU. You wouldn't even have to worry about touching a capacitor.
  4. Paradigm Shifter
    10 May 2006
    I would agree, yes. :)
  5. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    It could also prove useful to those looking to locate a dual/triple radiator in their case as it would free up much needed space. Too expensive though.
  6. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Yeah, much too expensive.
    The 'PSU outside the box' tactic is one I swear by, though - I'm not a modder at all, but that one innovation made my system run SO much better. Then again, mine's mATX - that could have something to do with it!
    I love the design of the casing. A whole PC themed like that would look amazing.
  7. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Wouldn't it be possible to just put a normal PSU outside the box? that would seem like a much better idea, I mean, it wouldn't look so good, but it would have many of the advantages that this have and be half the price.
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    You'd have to lengthen the cables and really stick something insulated around it to prevent nasty shocks if something goes wrong, but no not a totally unmoddable proposition.
  9. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    why do you need to insulate it? This is why we have the ground wire in the AC cable. (your computer case is directly connected to the case of the PSU, so keeping the PSU in the case have no safety advantages.)
  10. Midcoregeek
    Midcoregeek What's a Dremel?
    4 Aug 2007
    The voltage is a problem for high power-pc's but how about in a Home Theater PC application?
    The lights on the outside and/or shelf space might be an issue... but silent, more room, reduced heat
  11. Guest-16
    Guest-16 Guest
    Yep, it would probably work well. Especially for those who can't get away with a 120W dc-dc psu
  12. boiled_elephant
    14 Jul 2004
    I've got the machine in my sig running w/ the PSU (tagan 430W) sat outside the back of the box. The tagan cables made this easier - it's true that you have to arrange it carefully, or the cables won't reach. But my fans now run at about 1/3 the speed they did w/ it in, and I get consistently better game performance :)
    Aesthetically, it looks horrible, though. I'd like to design and build my own case to hold everything better so all the fans went in the right direction, but I "cba".
  13. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    i thought about making something like this years back ( when baybuses were an endangered species :) - so when i saw the review it had to be read! Major disapointment as its a good idea - but very poorly implemented, and way,way overpriced for the way its implemented. Actual hardware looks good - but losy package..
  14. Guest-16
    Guest-16 Guest
    Like I said in the value section, you can't really compare it to a standard 600W because of its completely different market, but it should be no more than £100 imo. Unlike almost every other unit I've ever used that claimed "silence", this one actually achieves it for a change, it just lacks attention to detail and 5/3.3V rails.
  15. Guest-18698
    Guest-18698 Guest
    it would be ideal for the SFF market. to bad about the voltages not being stable and the cables
  16. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    so its good upto 450W what should do for shuttles qute well i be Very surprised if you can get 300W-400W out of an shuttle type computer
  17. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    We need to send a message to these people...
    *Great idea
    *Great form factor
    *Great case design
    But make the rail monitor more useful (IE switching from -12 to +12, etc?)
    And make the internals more efficient and ATX-compliant.
Tags: Add Tags
