Network not working
Discussion in 'Tech Support' started by lp1988, 2 Aug 2008.
  1. lp1988
    lp1988 Minimodder
    24 Jun 2008
    i'm having problems with my computer, after installing vista i am no longe able to find anny network i have tried running all drivers for the onboard ethernet however nothing happens. when i plug in a cable the green light appears however no network are found, just says "not connected". i have had other computers on the same internet so there are nothing wrong with the connection. i have had Vista home premium 32 installed to make shure that it wasn't Vista. BIOS is set to the optimized defaults.
    pc specs
    Vista Home Premium 64 bit
    MSI K9A2 platinum v2
    AMD phenom 9850 Quad core
    ATI Radeon 4850
    4x 1 gb Kingston RAM set to 800
    1000W corsair power
    LiteOn LH-20A1S dvd+rw
    500 g Seagate Barracuda HDD
  2. GoodBytes
    20 Jan 2007
    - Do you have the latest drivers that are available on the website that made the onboard Ethernet card?
    Try this:
    - Turn off your computer.
    - Disconnect your modem and your router and wait 30sec (power and Ethernet).
    - Give power to your modem connect it to the router and give the router power. Wait several second until the router is connected with the modem
    - Connect the Ethernet cable to your computer following the direction given in the instruction manual of your router.
    - Turn on your computer, wait until everything loads and wait several more seconds (to make SURE that the router has time to connect with your computer)
    - Open "Internet Explorer (Safe Mode)" (it's somewhere in the start menu)
    See if it connects.
    Also try to connect on your router.
    For example, on some Linksys router it's 192.168.1.1
  3. lp1988
    lp1988 Minimodder
    24 Jun 2008
    did not work.... i have plugged in an old networks kart, worked perfectly fine, just a b**** that I can't get the onboard card working. but thank you for trying...
    all drivers are no less than four days old.
  4. scuzzphut
    scuzzphut perfectly normal
    5 Aug 2008
    something in the setup of the onboard card, then ?
    Is it set to automatically retrieve an IP address and DNS server from your router? (usually referred to as DHCP)
  5. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    Is the onboard showing up in Device Manager? I'll need more details to help you further.
    Also do you have a spare nic card laying around?, if not borrow one!
  6. lp1988
    lp1988 Minimodder
    24 Jun 2008
    it is set to automatically retrieve an IP address and DNS server and every other computer does that..
    there is no trace of the onboard card in the device manager however the card i ripped out of an old server and put in my com works and shows up in device manager..
  7. Geektechnica
    Geektechnica Minimodder
    11 May 2004
    If the onboard card isn't showing up in device manager it is very likely that you have it disabled in BIOS.
    Check the BIOS settings (Probably under "Integrated Peripherals" or somesuch) and make sure that onboard LAN in enabled there.
  8. lp1988
    lp1988 Minimodder
    24 Jun 2008
    it is... i have tried all that i could think of in BIOS.... and when it is set to the optimized defaults BIOS should not be the problem...
    i have tried to format the computer and use a diffrent version of vista (home basic 32 bit)
  9. JamesCreese
    JamesCreese What's a Dremel?
    10 Aug 2008
    Try disabling "Turn this device off to save power" in Windows.
    I assume you've tried using a different cable in to the network card, and a different switch port?
  10. lp1988
    lp1988 Minimodder
    24 Jun 2008
    yes i have tried that but I haven´t tries to switch the power saving off
