Build Advice New Build For Mum
Discussion in 'Hardware' started by andrewbarke, 17 Jun 2012.
  1. andrewbarke
    andrewbarke What's a Dremel?
    5 Aug 2010
    Afternoon, after my earlier post about a dead computer, ive resigned myself to the fact it is well and truely dead, so now mum needs a new one:
    Budget: As Little as possible, around the £300 mark
    Main uses of intended build: Checking email and web surfing, oh and playing spider solitare
    Parts required: CPU, M.Board, RAM, PSU & GPU (or would onboard be ok?). No need for a HDD since that appears ok same with DVD drive and case
    Previous build information (list details of parts): already got the HDD, DVD, and Case.
    Monitor resolution: cant remember the exact resolution, but its a 19 inch
    Storage requirements: None, already got HDD
    will you be overclocking: no
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): NOPE
    Have just quickly got these together:
    PSU: LN38345
    CPU: LN36724
    M.Board: LN43271
    RAM:LN32202
    GPU: LN42922
    OS: LN29161
    That comes to £310 with delivery, but that would be free thanks to bit-tech so bang on £300.
    hopefully you wounderfull people will come up with something since i dont really know where to start with the budget end, if she wanted an i7 gaming rig then no problem, but with a budget one????
  2. samkiller42
    25 Apr 2006
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    As suggested by samkiller42, that's really all you need for a basic PC!
    Also get a nice small case for the budget.
  4. GoodBytes
    20 Jan 2007
    Also the selected GPU is just as fast as Intel integrated solution. Look for something faster than a GT 520, if I am not mistaken.
  5. andrewbarke
    5 Aug 2010
    cheers for the replies, never thought of AMD and to be honest dont know a thing about AMD products, was looking for something in line with the core 2 duo range, which this will replace!
  6. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    The Llano chips are just as fast as a c2d if not faster and the inbuilt graphics are far superior to any intel intergrated graphics. Remember, just because intel has almost the whole market on enthusiast products, doesn't mean they do for budget ones.
    I think the build above is a good simple build for basic tasks. The graphics chip is even capable of playing modern games on low to mid settings. IF you need a tiny bit of extra power for some reason, the tri-core is only a few quid more, although you probably won't see much extra performance on day to day tasks.
  7. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    If you were wanting to stick with Intel, I'd recommend the Pentium G620. Custom PC tend to use that in a lot of their budget builds, and technically it's a Sandy Bridge CPU :thumb: That would provide enough grunt for standard usage. I'd think you would be fine with integrated graphics as well. Hope this helps!
