Build Advice New build time....
Discussion in 'Hardware' started by mrlongbeard, 29 Oct 2013.
  1. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    ...... nearly.
    Just toying with ideas before I decide if it's worth pulling some money together in the new year.
    Budget:
    £500 - £750
    Main uses of intended build:
    Pew pew gaming, almost 100% FPS
    Parts required:
    Mobo
    CPU
    RAM
    SSD
    OS
    PSU
    Cooling
    Previous build information (list details of parts):
    Will be recycling;
    Case, a MESH ATX Midi Tower(Wave)
    Blueray player
    Lightscribe DVD
    Mouse
    Keyboard
    Monitor
    GPU (Sapphire Radeon HD 5770 Vapor-X 1GB GDDR5 PCIe)
    Creative Labs Sound Blaster Audigy 4 Sound Card
    Monitor resolution:
    A stonking eye watering 1027 x 768, although probably upping to 1600 x 1200 a tad later
    Storage requirements:
    Going to need a SSD for OS and programmes etc, will also need a drive for docs etc.
    will you be overclocking: yes/no (delete as required)
    Nope
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
    Erm......
    Extra information about desired system:
    Not looking for bleeding edge (as you can tell from monitor res) but looking to future proof for a good couple of years.. last game i bought was MW2 :jawdrop: but it played the origianl Crysis at an acceptable level
    So anything worth doing within my budget?
    I appreciate the GPU is a tad long in the tooth but it works for now, I'm leaning towards Win 7 over Win 8
  2. rollo
    rollo Modder
    16 May 2008
    A new monitor would be top of my list of buys in truth.
    Intel Core i5 4670K Combo scan today only £444 (http://www.scan.co.uk/todayonly/index.aspx#3)
    includes
    hdd
    psu
    ram
    cpu cooler
    mobo + cpu
    add on your windows 7 and a ssd ( can get refurbed 128gb vertex 3s for £64 ) and your at about £600 job done.
    Use the rest of your budget to get a monitor as it will make such a difference to your actual user experience.
  3. mrlongbeard
    31 Jan 2010
    Thanks, but monitor is set in stone, CRT or nothing for me.
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    You can probably do a little better now on the GPU as that was two weeks or so back.
  5. mrlongbeard
    31 Jan 2010
    That's 2 recommendations for 500W PSU's now, back in the day they'd be seen a a tad weedy, has power consumption been reduced to make 500 Watters viable?
  6. jizwizard
    jizwizard Modder
    24 Dec 2010
    What games. Cs?
  7. mrlongbeard
    31 Jan 2010
    Any and all first person shooters.
  8. AlienwareAndy
    7 Dec 2009
    Yes. And the PSUs are better and more efficient now. Most are single rail too, with a half decent amount of amps :)
  9. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    I'd suggest nothing is the better option.
    Watch out or people will be trying to force those horrible, new internal combustion engines on you.
  10. mrlongbeard
    31 Jan 2010
    They can try but I've got about 6 laying around the place anyway :rolleyes: might have to get rid of some though to increase my CRT stockpile
  11. hakank
    hakank What's a Dremel?
    28 Oct 2013
    Is it me or do his gpu'd look damn ugly :)?
  12. mrlongbeard
    31 Jan 2010
    Well I did say nearly.....
    ....and the time is now, so with a budget if £1k hit me with your suggestions for a fps shooter rig.
    Parts required:
    Mobo
    CPU
    RAM
    SSD
    OS
    PSU
    Cooling
    Will be recycling;
    Blueray player
    Lightscribe DVD
    Mouse
    Moitor
    It'd be super cool if we could ignore my crt preference, it's not by choice, thems the cards I've been dealt so that's the hand I'm playing.
    Ta.
  13. adidan
    25 Mar 2009
    Nearly. 6. Years. Later?!! Holy moly.
    What's the deal with the monitor btw? To run that you don't need to spend £1k.
  14. mrlongbeard
    31 Jan 2010
    I can't do flat screens they send one of my eyes wonky, it's either the polerising filter or the low freqs, either way I've mostly given up on them for computer use.
    adidan likes this.
  15. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What inputs and resolution does it have?
  16. mrlongbeard
    31 Jan 2010
    Crt, VGA, 1024 X whatever @ 85hz.
    I don't / can't do flat screen monitors, I've been trying them for the past 13 odd years, I've given up looking, it ain't happening.
  17. mrlongbeard
    31 Jan 2010
    Thoughts?
    ImI seeing concerns with RAM & Ryzen's, is that going to be a problem
    Ok, so maybe a tad OTT, but I'm going for future proofing Screenshot_20190427-181357.jpg
  18. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  19. mrlongbeard
    31 Jan 2010
  20. Fingers66
    30 Apr 2010
    Wierd, I got your build at £176 cheaper using pcpartpicker?
    https://uk.pcpartpicker.com/list/D6xKw6
    mrlongbeard likes this.
