Graphics New graphics card
Discussion in 'Hardware' started by SDG, 28 Jul 2010.
  1. SDG
    SDG What's a Dremel?
    6 Oct 2009
    Hay guys
    Is it worth wait till around xmas for the newer graphics cards or is it the best time now with the nvidia460, im currently using a 8800GT.
    What sort of proformance boost will i see going from 8800GT to nvidia460?
  2. adam_bagpuss
    24 Apr 2009
    what res are you gaming at ?
    whats the rest of your spec ?
  3. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    A hefty one, unless you're CPU-limited. Hence the request for the rest of your rig. If, for instance, you're using a C2D E6300 and you're trying to play large-scale RTS games, it won't do anything for you.
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Unless of course you overclock the C2D E6300 to 3.6GHz in about 5 mnutes flat, then you have the best of both worlds.
  5. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Please post more of your spec and what you are trying to achieve - as per other comments. If there are no other limiting factors, then you are looking at a massive graphics boost. It is distinctly possible that you will run into other limitations however.
    If you are rocking an 8800 GT then we probably assume an Intel 775 socket and a core2 dual-core?
  6. boiled_elephant
    14 Jul 2004
    In which case the 460 will money well-spent and Christmas probably won't yield anything more balanced in the performance-on-a-budget vein. It also depends what games you need it for, too - since an 8800GT isn't good enough, I'm guessing high-end titles. Word of advice I can give without any other information: if those titles include GTAIV, don't bother upgrading your graphics card unless you've already got a tri- or quad-core processor. It's a minimum realistic requirement.
  7. SDG
    6 Oct 2009
    Sorry its taken me a little while to respond, been away for a day or 2.
    My current set up is
    Q6600 - No overclock as yet but thats the next step.
    4gb of ocz reaper memory.
    Asus premium p5k motherboard.
    Running windows 7 64bit
    8800GT
    As it is this PC is 2 years old, Has never let me down but iv noticed that iv had to lower my graphics sets some what these days.
    Would like to play through MW2 and bad company, been saving them for the new card. Plus crysis and my 8800GT doesnt like it much
    So is it worth a graphics update or maybe a new computer is in order.
  8. Pete J
    Pete J Employed scum
    28 Sep 2009
    A 460 would go nicely in that rig! Once you've got a nice overclock on the 6600 of course...
  9. roosauce
    12 Feb 2010
    The Q6600 is still fine ... although it'd be a crime not to try nudging the speed up a bit ;)
    Certainly you shouldn't be CPU limited and a 460 will rock your world. Make sure you get the 1GB version.
  10. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Thats pretty much exactly the same as my rig. :D
    Except my Q6600 is running at 3.2GHz.
    I too want to get a GTX460, but I'm still trying to decide which to get.
    Don't want to hijack the thread. But can someone tell me if the apps like msi Afterburner are compatible with all the cards, not just the ones from MSI?
    Basically, does it matter which card I buy if I want to try and OC it?
  11. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    MSi Afterburner works with any card - It works fine with my Asus 5870s for instance.
  12. Pete J
    28 Sep 2009
    Well, if you try this version of Afterburner, you should be able to overclock. If not, just wait until a new version is released.
