Electronics Newbie Q about power buttons
Discussion in 'Modding' started by iwog, 27 Jun 2007.
  1. iwog
    iwog Linux cursed
    14 Jun 2007
    Hello shiny nice helpful bit-tech people. I'm planning on building a server PC for future use and as this is my first ever mod of any shape or form i want to get all the details confirmed and "near perfect" before i even pick up/purchase any tools and start the construction. (as i got screwdriver and drill happy the other day and completely disassembled the donor case, did take pics first tho :) )
    Ok so the question is how exactly do power and reset buttons work? Do they make a circuit constantly or do they do so only when pressed?
    If they only make a circuit when pressed could i replace the cheap nasty plastic buttons with these?
    Third and final would attaching said buttons be as easy as removing the wires (as shown below) and just hooking them up or would they have to go on some special way? ie, black wire black terminal.
    Thanks again will hopefully have another thread up soon when i've finished the ProD designs which will undoubtedly contain yet more questions. :(
  2. weaselx
    weaselx What's a Dremel?
    30 May 2006
    the switches that your lookin at are fine. the power switch works on a momentary circuit just google it. it really is as simple as attaching the wires.
  3. saltynay
    saltynay What's a Dremel?
    12 May 2007
    and there are lots of shiny ones aswell. What would happen if you made a button to a constant voltage switch would it just not turn on
  4. weaselx
    30 May 2006
    correct it just wouldn't work. For pc switches you always look for momentary switches
  5. saltynay
    12 May 2007
    it would be quite cool to just have a row of those airforce trigger switches and rout everything through it like turning on the pc and your dual monitors and your speakers just by flicking up the caps and switching them all on at once. I am easily entertained :D
  6. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    The trick with that is making the rest of the computer look military grade... Having a row of protected toggles on the front of a Dell just looks silly.
    As for using them in a case, well... stay tuned. I'm not starting my project log until I start cutting stuff, but that's not too far off.
  7. saltynay
    12 May 2007
    I was actually thinking of mounting them in a table rather then a case
  8. iwog
    iwog Linux cursed
    14 Jun 2007
    And thus ruin a perfectly good table? Dont think i'd ever go as far as to mod another piece of furniture for a PC.
  9. saltynay
    12 May 2007
    mounting a small 3" squared metal panel into a table is ruining it :s
  10. iwog
    iwog Linux cursed
    14 Jun 2007
    Yeah, cos that plate will always be there. Unless its a cheap table you're gonna throw away in a few years i wouldn't mount anything into it.
  11. saltynay
    12 May 2007
    but the switches will always be there aswell and you can use them for different functions if the computer is taken away from the table e.g. lamp, lights, stereo, printer, ipod charger, alarm clock lol anything electrical
    how about we agree to disagree??
  12. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    the problem with the switches in the desk is that they can't be used to turn any thing else on cos they are momentary and things like lamps use normal switches
    but as long as the desk remains a computer desk you could always use the switches for another pc and if the switches are dont right it might look good
    i would put a plug and the switches so they and easily be plugged and unplugged from the pc
  13. Techno-Dann
    22 Jan 2005
    Protected toggle switches tend to be SPST or SPDT... That makes them great for turning stuff on and off, but not so hot for PC power switches.
    Of course, the real trick will be finding ones tough enough to take the kinds of power to run monitors and the like. The biggest I've found are only 20 amps @ 12v.
  14. iwog
    iwog Linux cursed
    14 Jun 2007
    Techno-Dan who is that at? As the switches i'm looking at are slow SPNO, which is a phrase i vaguely understand.
  15. saltynay
    12 May 2007
    no you misread my plan was to put normal switches in the desk not momentary ones a line of "trigger" switches
  16. Techno-Dann
    22 Jan 2005
    iwog, I'm looking at switches like this one, which are what I assume are what saltynay means by "airforce trigger switches". The description he gives from there seems to fit. Those switches (I have two here on my desk) are SPST, not momentary.
  17. saltynay
    12 May 2007
    yes those were what I was talking about and routing power through them to turn on and off the monitor/lamp/pc/tv/stereo have everything controlled in one little control panel perhaps with 3 of those airfoce triggers in line and then 3 momentary switches below
  18. Skulldragger
    Skulldragger What's a Dremel?
    28 Jun 2007
    ok, try this. Mount your switches on the table as you wish. You can find the protected covers by themselves or pull them off other switches which you can get but do not meet your power / load requirements. Behind the switches however you will have to build some electronics to preform the actual action you want the switch to do.
    for instance to turn on a PC with a SPST (Single Position Single Throw - On/Off) switch you would need a circuit which takes a + in and triggers a momentary pulse to a relay or transistor which in turn connects your PC power pins.
    This circuit could be researched @ (googled) http://home.cogeco.ca/~rpaisley4/LM555.html
    With this setup if you decided to re-task your switches you only have to change the circuits behind them preserving your "Look"
    Keep in mind however that most actual military systems having any resemblance to the system you describe has an arming switch (on/off) and a ... "Big red button" (a momentary push button) which is usually not red and only about the size of the average thumb print.
    :thumb:
  19. saltynay
    12 May 2007
    I was just thinking out loud not planning on doing this my pc moves around to much for me to build it into a desk
  20. iwog
    iwog Linux cursed
    14 Jun 2007
    ok can some one explain to me what the different letters in switches mean. I know SPNO means single pole normally open. but what are the other variations?
