Modding Noritake GU126x32F-K612A4 graphic VFD
Discussion in 'Article Discussion' started by Cheese, 19 Jul 2002.
  1. hentaihero
    hentaihero What's a Dremel?
    7 Oct 2002
    @Cheese
    :clap: :clap: :clap: :clap: :clap: :clap:
    u roxxxxxxxx:rock: :rock: :rock: :rock: man
    thx 4 ur help it works , it realy works wooooooooooooohooooooo
    thx man
  2. Nightwulf
    Nightwulf What's a Dremel?
    20 Aug 2002
    GPO help
    Can someone please tell me how to use the GPO on the VFD please. I have try hookup the two wire to ping 3 VDD and one of the p0, i pick pin 16 but nothing is happen what did i do wrong? and what is the other pin for like ping 1-8?
    thank ya all for the help
  3. Cheese
    Cheese Doc
    6 Oct 2001
    You set the display up in software to turn the I/O pin you connected to into an output and then switched it on?
    There's a good example of how to do it in the datasheet...
    Rob.
  4. Nightwulf
    20 Aug 2002
    Thank rob
    i will try to see it working or not, i just use the LCDC and event to with MBM5 plugin and turn on the GPO is Gt or Eq, but i have not put in any command.
  5. TAG
    TAG What's a Dremel?
    7 Aug 2002
    I thought it was totally impossible to use the I/Os w/ lcdc .... I'm confused now ...
    So it's possible using the VFDs commands then ?
  6. Cheese
    Cheese Doc
    6 Oct 2001
    You can trigger them on and off in screens fine... but you can only use one as an 'any time trigger' say for notification on email.
    LCDC doesn't understand the binary way in which the VFD turns its GPO's on and off, you can cheat and used a fixed binary value as the on/off code and thus use one GPO as a normal GPO in LCDC. To control the others you can plop the control codes in command lines in the screen builder (to make a GPO come on when a screen comes on for example), but you can't do much else with them...
    Rob.
  7. TAG
    7 Aug 2002
    yeah thought there was a problem with them
  8. Tau
    Tau Sharingan!
    17 Nov 2002
    Is there a comprehensive list of the commands for this vfd? Obviously there is the manual, but the command codes in that seem to differ from the ones you use in LCDC?
    I.e. I'm trying to design my own screens using variables from the MM5 plugin. I can get the variables from dissecting the other definition files, but then to make stuff display where i want it to seems to be a lot trickier!
    Tau
  9. Cheese
    Cheese Doc
    6 Oct 2001
    See the bottom of the readme file in the zip with my example files in it...
    [##x] - sends character with the decimal vale xxx to the display. For example [##65] would send an 'A' to the display as 'A' is the 65th character in the ASCII character set.
    [##16][##x][##y] - Sets the cursor (x,y) position in the display. Using the normal 5x7 font {see [##29] for changing to this font} (0,7) is the first character on the top line. So to make LCDC print 21x4 characters on a screen in the normal font line one must be started with [##16][##0][##7], two [##16][##0][##15], three [##16][##0][##23] and four [##16][##0][##31] to start the cursor in the correct place for the four lines. You can see this done in the 'simple example' file (www.bit-tech.net - reviews - modding - noritake graphic vfd - page 2).
    [##17][##left][##top][##right][##bottom][##200] - draws a white rectangle from coordinates (left, top) to (right, bottom) {where the top left of the screen is (0,0) and bottom right (125,31)}.
    [##18][##left][##top][##right][##bottom][##200] - as [##17] except that the rectangle is black.
    [##19][##left][##top][##right][##bottom][##200] - as [##17] except that it inverts the area in the rectangle.
    [##20][##left][##top][##right][##bottom][##200] - as [##17] except that it just draw the outline of the rectangle.
    [##21][##left][##top][##right][##bottom][##200] - as [##17] except that it draws a black outline of the rectangle.
    [##22] - makes pixel at current cursor white.
    [##23] - makes pixel at current cursor black.
    [##24],[#delay10],[##length],[#delay1],[##data1],[#delay1],[##data2],... (as seen in the event section of screen builder) - here the commas are in place to separate commandsinthe event builder, the character is not sent to the display. This writes 'length' graphic byte to the display. [#delayxx] delays sendingany more information to the display for xx milli seconds. [##26][##0] before drawing makes the display draw the graphic bytes horizontally, [##26][##128] before drawing makes the display draw the graphic bytes vertically. See the display's manual for examples.
    [##25] - resets the display.
    [##26][##0] or [##26][##1] or [##26][##2] or [##26][##3] - when writing text this sets how the text is introduced to the screen. [##0] overwrites anything previously in the write area, [##1] AND's the new text with the old (only pixels which were previously white and are white in the new line of text stay white), [##2] OR's the new text with the old (displays all old white pixels and all new) and [##3] XOR's the new text with the old (as OR but where the AND write mode would leave a white pixel XOR leaves a black). A good example of using these write modes together is writing text with an outline. Draw the text you want outlined 9 times with OR mode on; at (x-1,y-1), (x-1,y), (x-1,y+1), (x,y-1), (x,y), (x,y+1), (x+1,y-1), (x+1,y), (x+1,y+1) then set the write mode to XOR and write the text at (x,y).
    [##27][##248] to [##27][##255] - sets the brightness of the display from OFF {248} to max {255}.
    [##200] - Neither command nor character 200 exist in the command set of this display. Sending character 200 makes the display wait 50us and print nothing on the screen. This is used after drawing rectangles (to give the display time to finish drawing before the next command) and at the end of lines in the screen builder to stop LCDC's sending spaces to the display.
    Where I talk about pixels 'being turned white' read 'being turned on' really, and 'black' off.
    Rob.
  10. Tau
    Tau Sharingan!
    17 Nov 2002
    Hehe, now thats service! I got a reply in just a few minutes!
    Cheers Rob :D
    Tau
  11. Avatar28
    Avatar28 What's a Dremel?
    18 Mar 2002
    Hey, I was wondering. Is it possible to get a darker blue out of this VFD than what's in the pictures in the review? I'm trying to keep everything a darker shade of blue for my system to keep a consistent theme.
  12. TAG
    7 Aug 2002
    yes u can get a very nice looking blue and get rid of the cyan color by adding a red filter to the blue one shipped with the display
    Not sure they actually do the kit (display+cables+filter) anymore though
    So thing to remember is blue+red filter makes a nice true blue color
  13. TAG
    7 Aug 2002
    Actually i got i wrong, thought there was something about adding a red filter to the blue one though but couldnt find it :(
    So here's what mashie managed to get w/ a darker blue filter:
  14. Funks
    Funks VFD man
    22 Jul 2002
    Colour Filter Materials
    Hello Avatar28,
    Yes you can change the colour of the VFD very easily to almost any colour you want, red through to violet. :clap: The filter we supply comes from the company Lee Filters. www.leefilters.com
    We use one of the blues shown on this page http://www.leefilters.com/LP1.asp?PageID=22 and the Deep Blue 120 will give you a very nice dark blue on an almost black background.
    Lee Filters are available in the US, see their home page http://www.leefiltersusa.com
    They also have dealers in Tennessee see here http://www.leefiltersusa.com/LightDealers/LightDealersTN.html , so you may be able to contact them and acquire just what you need.
    The slight downside to all this is that you want something just a few inches square, and when we buy this material it on a roll, 24ins wide and several feet long!!
    Perhaps you can balagg a sample or 2, or get together with a few others and purchase a small quantity, and divide it up.
    In the UK there is a company MAPLINS that have similar filter material (I expect it comes from Lee Filters!)
    http://www.maplin.co.uk/products/module.asp?CartID=030131085555364&moduleno=30534&modulecode=
    Look for Maplin code QZ71N Lamp Gel Dark Blue price UKP 4.99
    Find it under Disco lighting
    :idea: Other possibilities are to use Acrylic or Polycarbonate sheet of a suitable colour and material thickness. Working with these sheets involves a little more cutting and shaping, but can give a very nice finish and appearance.
    Hope that this helps you and others,
    Phil Dakin
    Itron (UK) Ltd
    EDIT: The links should work OK, now. :rolleyes:
  15. Funks
    Funks VFD man
    22 Jul 2002
    Kits Still Available
    Hello TAG,
    We certainly do still sell these kits, we've shipping up to 10 a week all these months later, so there's lots modders with these in their cases! :hip: :geek:
    If anyone else is needing a kit, go to page 1 of this discussion and also read the review and you'll find the "How to Order"; or just mail me!! :D
    Phil Dakin
    Itron (UK) Ltd
  16. Avatar28
    18 Mar 2002
    Thanks, Phil. Three of those guys are in my area, so with any luck maybe I can get it from one of them. I'll also check into my plastics dealer and see if they have any thin sheets of dark acrylic. Now, just gotta get the $$$ to order one of these bad boys. Probably the next thing on my list, actually, now that I've got the case.
  17. Arlof
    Arlof What's a Dremel?
    2 Aug 2002
    LCDC V1.3 Support For .DEF file.
    I'm not sure if anyone else has upgraded their version of LCDC, but if you do you'll get a message that pops up telling you your definition file is out of date!
    Is there any fix or perhaps a new .def file out there?
    Regards,
    David
  18. Cheese
    Cheese Doc
    6 Oct 2001
    Re: LCDC V1.3 Support For .DEF file.
    Sorry, I don't have one of these displays anymore so I didn't notice...
    In a couple of minutes the first post should have been updated with working files (NiceExample5), if they don't work then I'd use an older version of LCDC :)
    Rob.
  19. evilgreenie
    evilgreenie Standby for Main Engine Burn
    30 Aug 2002
    This could be either due to a mistype in an installation directory, or just the version number in the definition file that needs editting. I don't think the definition file needs major surgery..
    Check out the thread in the LCDC forums
  20. Cheese
    Cheese Doc
    6 Oct 2001
    Re: Re: LCDC V1.3 Support For .DEF file.
    Umm see above, think I've already solved the problem :)
    Rob.
Tags: Add Tags
