He's better off just getting an Antec KÜHLER H₂O 920 Jeff Sandy Bridge doesn't really warrant full blown watercooling and secondly he swaps his kit like he wishes he might swap his women lol
You better be upstairs where she can't see you typing this mate, because when she's finished with you, you'll be so dead we will have to bury you twice.
The waterblock has two 4-pin PWM connectors running out of it for connection to the pair of 120mm fans. There’s also a single 3-pin fan cable, which provides power to the pump, and a USB motherboard header cable, which provides power for the attached cooling fans, as well as data on coolant temperature and fan speeds.
Now the brain is working. Thanks bud. Reading so much about the H80 going wrong so will stay clear of them now. Will definitely give this a go
Mark, have you seen this? He reckons it dropped his temps by around 10 degrees. I admit, the thought that I wouldn't be able to buy your H50 had occurred to me. It might be worth checking out though.
To be fair mine was a bit simpler to do as I didn't have to unscrew anything or dismantle the pump housing, i just yanked the pipes off the barbs! lol
