Hardware Nvidia GeForce GTX 550 Ti 1GB Review
Discussion in 'Article Discussion' started by Claave, 15 Mar 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Tangster
    23 May 2009
    Looks like a good card, especially if it's priced a shade lower than £100. Still no folding benchmarks though...
  3. CAT-THE-FIFTH
    CAT-THE-FIFTH What's a Dremel?
    5 Apr 2009
  4. Claave
    29 Nov 2008
  5. CAT-THE-FIFTH
    5 Apr 2009
    :D
    I had a look around on Scan and even the GTX460 1GB and HD6850 1GB cards can be had for a few quid more it seems:
    http://www.scan.co.uk/products/1gb-...hader-1400mhz-336-cores-2x-dl-dvi-i-mini-hdmi
    http://www.scan.co.uk/products/1gb-...-960-stream-processors-dp-dl-dvi-i-dvi-d-hdmi
    The GTX460 768MB Green does use only a single PCI-E power connector so it should be more frugal than most GTX460 cards:
    http://xtreview.com/addcomment-id-13688-view-Green-version-GeForce-GTX-460.html
  6. red4our
    red4our ¿Qué es un Dremel?
    13 Jan 2011
    This looks like a really well priced/performing card. It's benchmark results in some of the tests are only a few fps behind the excellent GTX460 1 Gb and, requiring only 1 connector should mean it sucks less socket-juice and hopefully creates less heat.
  7. wyx087
    15 Aug 2007
    GTX and Ti for a speed-bumped 450? crazy branding monkeys have done it again.
    in that case, why do we bother with GTX anyway? if everyone just start calling the cards by number, hopefully nvidia branding monkeys will see some sense.
  8. Canon
    Canon Reformed
    19 Jul 2010
    I wonder why anyone would bother with this card. Get a 460 on the second hand market, save yourself some money, buy fans with that money.
  9. Flanananagan
    Flanananagan What's a Dremel?
    1 Jan 2011
    Any chance of a bad company 2 benchmark using direct x 10 and comparing the results to direct x 10? Just out of curiosity...
  10. Hustler
    Hustler Minimodder
    8 Aug 2005
    Would be a nice,cheap upgrade/replacement for my Radeon 4850 i suppose..
  11. trig
    trig god's little mistake
    10 Aug 2006
    well, here in the states, newegg has them at $150 plus about $5 for shipping. you can get a MSI 768 mb gtx 460 twin frozr for $150 and free shipping plus a $20 MIR. the 1GB cards are $30 more, but alot of them have a $30 MIR...looks like the price point needs to adjust a bit. it will, it's just the new release. nom on some noobie uninformed dollars...that reminds me...wonder how shau is doing? hope he doesnt swap out his rma for this...
  12. Xir
    Xir Modder
    26 Apr 2006
    So are "El-Cheapo" 1920x1020 monitors, but you refuse to test/recommend those :D
  13. wyx087
    15 Aug 2007
    because those monitors are bad for your eyes.
    i'd love to see a monitor terms explained feature, you can even entrust GoodBytes to write it if BT staff are busy. hopefully there will be less "which LED monitor" threads.
  14. phuzz
    phuzz This is a title
    28 May 2004
    Dear nVidia
    Please stop changing your naming scheme every two days. That will make it easier for people to understand where each card slots into your lineup, and thus we will be more likely to give you money. Complex, ever shifting naming schemes just put people off the entire range of cards, especially us enthusiasts, who don't just spend money on your cards, but also advise other people what to spend their money on.
    Come on nVidia, I'm sure you resort to using shorthand names around the office, why not just pick one simple naming scheme (eg bigger numbers == better) and stick to it eh?
    Signed
    half the bloody internet.
  15. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Dissatisfied with the article -
    1. Very few games
    2. The graphs were not labelled to show which card(Zotac or KFA) was being used.
    3. Only one of the cards was tested. What about the other one?
    4. If you are linking to retailer websites, I would prefer it to redirect the reader to the GTX 550Ti page.
    5. No noise tesing?
  16. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Where did the price estimate of £100 come from?
    On Scan right now they list from £112 to £149 - hardly value for money when compared to the GTX 460.
  17. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Anandtech have a very interesting write up about this cards interesting use of Memory bandwidth vs capacity.
    Essentially it is a 1GB card running on a 192bit memory interface which means one of the memory controllers is running with a abnormal amount of memory
    1st controller - 2 x 1Gb on 2x 32bit channel
    2nd controller - 2 x 1Gb on 2x 32bit channel
    3rd controller - 2 x 2Gb on 2 x 32bit channel.
    Given that memory is normally balanced across the memory channels (thus allowing easier allocation) it will be interesting to see what effect this has on the card under memory bandwidth limited scenarios.
    Anand mused that the the card may be using some for of flex interleaving whereby some of the calls will be split across the 3 channels whilst other will be limited to the remaning capacity on the third controller (the first two will always run out first). Essentially you would have a card that has ~ 98.5GB/s memory bandwidth for the first 768MB of memory and then 32.8GB/s for the remaining 256MB of memory.
    Link to the full article:
    http://www.anandtech.com/show/4221/nvidias-gtx-550-ti-coming-up-short-at-150/2
    Looking at the performance figures (over at anand and here) it does look like a gimped card that should have been launched back when the GTS450 was first out to be remotely competitive (in other words this is what the GTS450 should have been). The GTX460 SE should have been called the GTX550 TI or something like that.
  18. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Yeah, the retail source wasn't very good apparently! They are on average £130 which is quite frankly too much! £100 would have been a very tempting upgrade from my GTS450 for very little money, but not for that much
  19. Xyllian
    Xyllian What's a Dremel?
    24 Jan 2011
    Comes in at the same price as the HD6850 which stomps it across the board, nvidia failed even worse on this one then the GTS450.
    Add in ridiculously bad power consumption and nvidia has another low-end failcard on their hands. It will still sell in tonnes tho due to the extremely powerful nvidia GTX branding, fanboy wars in 3........2.........1.........
  20. Claave
    29 Nov 2008
    1 - It's the same number of games we've been using for at least the last year, if not two.
    2 - As usual, we've graphed the stock-speed card (by down-clocking the Zotac to stock speeds in this case) as this is more useful information. This is what we always do for launch articles and the graph label 'Nvidia GeForce GTX 550 Ti 1GB' should be clear enough that this is the performance of a bog-standard, normal, stock-speed GTX 550 Ti 1GB.
    3 - Addressed above, but I'll add that the cards arrived a bit late to do the full testing treatment for the launch given that we also needed to re-test the comparison cards.
    4 - We didn't have this information pre-launch (as the pages weren't live), but we wanted to let our readers know which of their favourite etailers you can expect stock of these cards at. Surely this is preferable to having no buying information at all?
    5 - As mentioned on the Performance Analysis page, each GTX 550 Ti card is likely to different.
    The estimate came from Nvidia, and was used in good faith. It's not unusual for prices to vary from MSRP, but even our retailer source indicated that the price would be £90-125 so that's what we worked from when forming our conclusions.
Tags: Add Tags
