Windows Nvidia Inspector : Apply changes button missing :?
Discussion in 'Software' started by isaac12345, 24 May 2014.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi all!
    I downloaded Nvidia inspector to fix the slow motion problem one gets with the pc version of naruto full burst 3. However, I am not able to apply any settings as it doesnt show the apply changes button! I thought it was a driver problem and updated to the latest one for my card (335.23). However that didnt help. I also ran it in administrator mode but it still didnt work. Its a really odd problem. Can someone please help me figure it out? It couldnt be because I am running an old crt monitor at 1024x768?
  2. GoodBytes
    20 Jan 2007
    Are you trying to overclock your GPU?
  3. isaac12345
    20 Jul 2008
  4. GoodBytes
    20 Jan 2007
    Looks like the software doesn't support the latest drivers, or you can't set it it to 8, as the max is 4. If you know programming I can help you out implement NvAPI where you can try, by my feeling is that 4 is the max
  5. isaac12345
    20 Jul 2008
    How do you know it cant support the latest drivers? I tried to find the readme but couldn't. And I do know some programming. But would need to set it to 8 as the solution says so. What would I roughly need to do?
  6. GoodBytes
    20 Jan 2007
    'cause everything is disabled on that panel on my side, and about everything beside OC and fetching the GPU information doesn't work.
    And I had a look at NvAPI (https://developer.nvidia.com/nvapi)
