News Nvidia responds to AMD’s PhysX criticisms
Discussion in 'Article Discussion' started by Sifter3000, 21 Jan 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. MitchBomcanhao
    MitchBomcanhao What's a Dremel?
    21 Jan 2010
    Is it me or is everyone misspelling AGEIA? it's not AEGIA. not even the nvidia guys know that? or am I missing some name change? :D
  3. woodss
    woodss Yes Louis Wu
    19 Jan 2010
    PhysX does what it says on the tin, regardless
  4. Sifter3000
    11 Jul 2006
    Ha, good spot!
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    To be honest, after the fiasco with Nvidia disabling PhysX whenever an ATI GPU is present, I'm more inclined to believe what AMD/ATI have to say on the matter.
  6. mi1ez
    mi1ez Modder
    11 Jun 2009
    Exactly my thoughts Pete
  7. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    His answer fails to address the Batman A. lock out issue. There'll be more in the future for sure.
  8. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    Never mind all this squabbling, bring on fermi.
  9. knutjb
    knutjb What's a Dremel?
    9 Mar 2009
    Maybe this is a good subject for an unbiased test?
    I don't think AMD or Nvidia would be willing to show how they "know" but it should be possible to dig into it. Seeing that Nvidia has turned off standard direct x features from running on ATI cards, I forget the game, maybe there is something to this.
  10. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    It might "support" multicore, but there is no doubt they are not giving PhysX-on-CPU users as much optimising and accessibility as those who have bought they're own brand of card.
  11. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    which is, as it is their brand and software, their right. but if something is your right, it does not mean that if you do it, people are going to like you.
  12. chizow
    chizow What's a Dremel?
    12 Dec 2008
    The only realistic solution was already provided in an answer by Huddy in the original interview:
    Of course, non-committal on their obligation to support features for their own products.
  13. chizow
    12 Dec 2008
    In that case, you don't have anything to worry about, according to Chris Hook (AMD something something of lies, BS, misinformation etc) your ATI cards have supported physics since at least the 4890....
    http://www.youtube.com/watch?v=NFSUh8OjO-0#t=7m23s
    Because physics are important to them....really.
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    lol *as he inserts the multi core code back into the driver- look there it is!
  15. chizow
    12 Dec 2008
    Its been in the SDK since day 1, if you run Vantage its the part that y'know, pegs all available physical AND logical cores to 100%....y'know the portion that runs at 6-15 FPS because modern CPUs simply aren't fast enough to adequately accelerate physics simulations.
    If it were possible to accelerate advanced physics effects on the CPU, don't you think Intel would've rolled it out with Havok by now? ;)
  16. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Personally, i think Valve had the right idea using Havok to introduce some basic CPU powered Physics into the Source engine games, which enhance the gameplay, rather than dominate it.
  17. confusis
    confusis Kiwi-modder
    5 Jan 2006
    all we need is a copy of the source code and we will definitely find out :)
    (i think chizow is an nvidia fanboy!)
  18. chizow
    12 Dec 2008
    http://developer.nvidia.com/object/physx_downloads.html
    Knock yourself out, it may only cost ya $50K, but even if you got it, would you know what to do with it to "definitely find out"? ;)
    Perhaps, but at least I wouldn't be an ignorant ATI fanboy! ;)
  19. thehippoz
    19 Dec 2008
    yeah was being sarcastic chiz.. and the code for 3dmark was always a bunch of marketing- I mean it artificially inflated scores for nvidia by rewriting code.. it's like hax- what's the point in a bench then.. like messing with the lod bias
    the cpu bench used the gpu as well.. so it doesn't really matter if they claim it uses all cores- physx has always been a marketing tool for them- pretty much nothing that can't be done with havok on todays cpu.. think that's what the guy at ati was getting at
  20. confusis
    5 Jan 2006
    I'd rather be an ignorant ATI fanboy than an ignorant nVidia fanboy.. Had my share of geforces, happy with my radeon :)
Tags: Add Tags
