Hardware OCZ DDR2 PC2-9200 Flex II 4GB Series
Discussion in 'Article Discussion' started by Guest-16, 31 Jul 2008.
  1. Guest-16
    Guest-16 Guest
  2. The boy 4rm oz
    10 Apr 2008
    Very cool RAM. Sucks about the restrictive manifolds though. Simple solution is running a seperate lower spec pump for the RAM. OR a seperate loop all together.
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    fare! how does it _fare_!
    yeah this is the poncey equivalent of your and you're.
  4. Guest-16
    Guest-16 Guest
    Alright, keep your knickers on.
  5. Fod
    26 Aug 2004
    you only have to ask and they'll be off again ;)
  6. wyx087
    15 Aug 2007
    shame it doesn't allow 4 sticks...... why can't OCZ use a ultra high heatsink instead of going fatter and fatter
  7. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Looks good to me! One would assume that if you're going to get these RAM sticks then you'd already be watercooling the rest of your rig and therefore would have a pre-existing loop (or will be getting these as part of a larger loop) which would mean you'd have a better and more capable pump than that TINY little bay thing...
  8. Guest-16
    Guest-16 Guest
    Yes, very true, however like I said you'd have to use a Y piece of manifold and keep the rest of the system separate otherwise it'll just kill the flow.
  9. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    that pump and rad seems fairly uselss to me, for me, its only feasible use would be to cool the overheated 680i northbridge on my mobo, but then i've not even got my cpu overclocked anymore as the mobo kicked up such a fuss and solely cooling ones northbridge with w/c is tres overkill!
    I have always been dubious of those massive sinks on ram, i had questionned its necessity but atleast those temps are more agreeable than the standard that are fitted on the crucial.
  10. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    I must admit that I am tempted...
    My reapers look good (and perform superbly), but these look better (and perform better as well).
  11. ChaosDefinesOrder
    6 Feb 2008
    I want to see a pair of these plugged into the Maximus II - they look like they have very similar heatsink fin designs...
  12. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Damn, don't you guys have a Eheim pump laying around somewhere? You got all that crap everywhere in the office but not a pump and a good rad. Come on! lets test this again with water in it...
  13. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Hey all,
    Aqua-Pcs is in "DA" house too ;)
    Just as a quick point I would like to make about the pump used in the review is that this was unfortunately faulty - these things happen and XSPC assure me the problem was identified quickly and resolved. As the pump sent to Bit-Tech was a review item this one slipped under the radar :(
    In our defense we must state that the kit was sat @ Bit-Tech HQ for what must be getting on a good “few weeksâ€￾ now and if it was tested / setup more then 1 day prior to the review we would have easily been able to send over a replacement for you.
    As an idea of what it can handle we are running the pump with and XSPC radiator, D-tek fusion V2, DD 8800gtx, and of course the Flex II Memory (which is great btw) off the same 200 Bay pump on our test bench – feel free to come check it out for your self as it will be on our stand at the M-Festival
    And yes we would be happy to replace the pump so you can give it another go ;)
  14. Guest-16
    Guest-16 Guest
    Hi mate, unfortunately we came to test the watercooling about 4pm last night :( We did say it's clearly faulty, but unfortunately there was no time for a replacement. We'll be happy to test a replacement and try it again with the BFG review and add an addendum ;):)
    My email is on the about page - let me know! :)
  15. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya I was going to get these but by the time I had money no one had it in stock and some said it was discountinued so I was like WTF so I got GSkill DDR2-1150 4gb kit instead and well I am very happy with it :)
  16. willyolio
    willyolio What's a Dremel?
    17 Feb 2007
    hmm. since these take up 2 dimm slots each, it ends up being a question of fast ram vs. more ram.
    i'd rather have 8 gigs of much cheaper ram than 4 gigs of expensive, slightly faster ram.
  17. Guest-16
    Guest-16 Guest
    Well tbh 8GBs of "cheaper" ram is still going to cost you as much as 4GBs of this stuff, and we've shown before you don't really need 8GB unless you have a specific requirement in the work you do. Filling four slots can sometimes be temperamental for motherboards and BIOS' too - you won't reach these speeds with four DIMMs that's for sure.
  18. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Along with the above comment, I would prefer to have 8GB of RAM, or the option of 8GB rather than have to tie myself down so much with these. Still, they do look rather good and I am sure that in a lot of circumstances will be used extremely effectively.
    Minor point - there is rather an attack of the apostrophes on the last page!
  19. Neuromancer
    Neuromancer What's a Dremel?
    2 Aug 2008
    Recently got a kit of this for very cheap.
    Bought as an intended WC purchase.
    but it just doesnt matter. I am running a p5Q deluxe just liek the reviewer and at 2.08 vdimm am getting 1200mhz 5-5-5-18. All on auto (except on vdimm as mentioned)
    I dont know what the reviewers were doing wrong. I got googled her looking for cas 4 timings.. I have read 4 cas was only good till 960 on these sticks, (which is diheartening) I just sold 4x1GB of gskill hz that will do 4 cas at 1000mhz... (at more volts they are microns after all and doomed to failure cuz of it) for twice what i paid for these sticks though :) so i guess all in all im happy. the lack of getting 8GB in a system sucks but having a couple of uber quiet low speed 120's in the side panel keeps these sticks cool enough to run faster then anything but ddr3. (although with looser timings the nthe higher voltage microns, which actually... micron made 667 chips until a year ago and then started making 800mhz chips, they stil dont make 1200 mhz chips ;) so when you consider the enormous fail rate of ballistix lets say... and compare it to the fail rate of these (promos? I think ??) Odds are more likely your micron will fail before my 1200mhz ICs will :)
  20. Andy Mc
    Andy Mc Modder
    23 May 2002
    I have this stuff and I'm quite indifferant about it. I had to RMA the first set I had as it was foobar'd (not supprising considering how hard it must be to get good enough silicon for this). I kinda wish I'd just got a decent 8gb set of corsair.
Tags: Add Tags
