Portable One Plus One Community
Discussion in 'Hardware' started by MSHunter, 1 Oct 2014.
  1. Shirty
    18 Apr 1982
    The bamboo case is only available if you filled out a form a while ago, so it's just there to tempt you now :D
    Get an official flip cover, they're awesome.
  2. Speed
    Speed Multimodder
    13 May 2004
    Ah I see, I gave up anyways and ordered a regular case.
  3. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Looking to replace my nexus 5 as im getting a bit bored of it, i have a look at all the top phones from iphone 6 plus to HTC one m9 but they are all priced ridiculously. The one plus one is reasonable but im not sure about it, some of you guys have had it for a while so should i or shouldn't i get one??
    Edit: im on the three network
  4. Parge
    16 Jul 2010
    What are your concerns?
  5. flame696
    15 May 2009
    Concerns are build quality seen some threads on the one plus website which have got me a bit concerned.
  6. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Build quality is not an issue imho, far nicer build than a standard Sammy, for example...
    There is a minor issue with yellow screen tint - it's not too bad on most models and may even be fixed in latest batches... but if not simply set this app and forget: https://play.google.com/store/apps/details?id=com.aaahh.yellow
    The 1+1 only supports one 4G band that 3 uses though, so 4G coverage might not be great. I personally am on O2 and have no 4G, it's not a biggie for me as I don't consume much data, but might be important to you.
  7. flame696
    15 May 2009
    that is the other issue i do use a lot of data when im out and about so that might be a concern
  8. Shirty
    18 Apr 1982
    It definitely works best if you're on EE for 4G.
  9. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    I've received a new invite today - if anyone is looking, PM me.
