Hardware Overclocking Intel's Core 2 Quad Q6600
Discussion in 'Article Discussion' started by Tim S, 25 Jul 2007.
  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    As if BT wasn't my home page in FF. ;)
    So I think I'll wait a couple of weeks and take the Q6600 route then. Maybe some more RAM and replace those IDE HDDs with SATA2s...
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    lol, wise man ;)
    Be sure to try get a Q6600 with the G0 stepping ;)
    Im waiting another week or two before I get mine, hoping that the earlyer steppings will have been shipped and paved the way for the better G0's :D
  3. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I ordered my q6600 back on the 22nd. Also ordered some ram and a cooler. got the cooler and the ram. but the cpu according to the website has not shipped. When I call in, im told it has been shipped but from a wherehouse that does not intergrate with the webpage so I cant see that it shipped and I cant see a tracking number. So I have no idea when its going to be here. all i can say is that they had better be telling the truth when they say its shipped....
  4. salesman
    salesman What's a Dremel?
    29 Apr 2007
    DDR3
    I'm interested to see how well ddr3 turns out once the Micron Z9 modules hit the market
  5. francisl1420
    francisl1420 What's a Dremel?
    23 Jul 2007
    Is there anyway to ensure that you get a Q6600 with G0 stepping?
  6. perplekks45
    9 May 2004
    Call your dealer and ask for it. :)
    Or better e-mail them so you have something you can show them later if they didn't deliver a G0.
  7. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
  8. DarkJedi
    DarkJedi What's a Dremel?
    29 Jul 2007
    Argh... I was just about to order an E6850 when I read this. Now I don't know :/
    quad core and over clocking or dual core and stock... decisions, decisions :( Advice pls?
  9. THRASHER2
    THRASHER2 Pimpin' Deals 24/7
    15 May 2007
  10. Delphium
    18 Mar 2007
    Well Seeing as the Q6600 appears to be very clockable, achieving speeds greater than that of the dua core at stock, then id say go for Quad ;)
    Prime example above from THRASHER2 :D
    Very nice!!
    I would be interested to know what voltages you used ;)
  11. perplekks45
    9 May 2004
    And temps. :)
  12. DarkJedi
    29 Jul 2007
    Me too :)
    I'm pretty sure I'll be going quad core now. Does XP Pro support 4 cores or only two? Don't particularly like Vista yet (seemed a bit lethargic, but that may be my current hardware's fault slightly) and would prefer to keep XP as my main OS until Crysis comes out at least.
  13. Tim S
    Tim S OG
    8 Nov 2001
    you can run four cores under XP just fine - I did for around six months before I plucked up the courage to move to Vista. :)
  14. DarkJedi
    29 Jul 2007
    I've made my choice then.
    Four cores here I come :D
  15. THRASHER2
    15 May 2007
    I will get the Info later tonight (When its cooler) :rock:
  16. completemadness
    completemadness What's a Dremel?
    11 May 2007
    XP pro limits you to 2 physical proccesors - I think most of the vista packages do too
    So that means you can have 16 cores on XP when they get octo cores out :D
  17. rufiosab
    rufiosab What's a Dremel?
    1 Aug 2007
    Yeah, i had the e6850 on my shopping list till i read this!
  18. timmythemonkey
    timmythemonkey Monkeymodder
    27 Apr 2006
    I know I'll be going for a quad core (probably Q6600) DDR3 setup just as soon as motherboards with PCI-Express 2.0 come out... oh when will the wait end. Otherwise with my luck by the time I fancy upgrading my graphics card again my motherboard will be incompatible.
  19. Delphium
    18 Mar 2007
    Expect to see boards and devices that are PCI-E 2.0 released mainstream in 2008, so if you can wait 6months ;)
  20. Dogers
    Dogers What's a Dremel?
    3 Dec 2006
    Is there an ETA on this? :)
Tags: Add Tags
