Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Tim S
    Tim S OG
    8 Nov 2001
    Spam and offtopic discussion will be removed on sight.
    Update...
    I do not manage the results table myself, so please don't email me regarding the table being updated. If you spot inaccuracies or problems with the results table, please email Fr4nk with your queries/problems.
    Thanks
    The only way to really do any form of results thread, is using screenshots of programs such as CPU-Z and other such programs.
    Rules
    Due some possible flaws in the way this challenge is run, I've had to introduce some rules. Thanks to Jaguar_Infinity for bringing some of these possible flaws to my attention.
    • You must include a screenshot for your result to count, there are many places to upload it, I've offered to host them too... uploadit.org is also available to upload files for free, so there are no excuses!
    • You must use the linked version of SuperPI which is linked in this thread, *nix users: you need to run Wine to get it to work.
    • Take your screenshot before you hit the "OK" button where it says "PI calcluation is done" because it's possible to edit the numbers which are returned in the main program view.
    • Please include the following information about your system:
      • Processor
      • Motherboard
      • Cooling
      • Memory, timings, and dividers (this information can be found out using CPU-Z)
    CPU-Z
    download
    CPU-Z is a freeware that provides some information on your system :
    • Processor name and vendor
    • Core stepping and process
    • Processor package
    • Processor current core voltage
    • Internal and external clocks, clock multiplier
    • Partial overclock detection
    • Processor features, including supported instructions sets.
    • L1 to L3 cache information : location, size, speed, technology.
    • Motherboard information : name, vendor, BIOS, chipset, memory, AGP.
    • Memory information : size, type, timings, specifications.
    Super-PI
    download
    This program tests how fast you can compute pi to x number of decimal places, for the purposes of this thread, we'll use 1M decimal places.
    Run Super-PI and compute PI to 1M decimal places, then start up CPU-Z and take a screenshot of your desktop and trim it down to size so that you still have your desktop in the background make images no larger than 1024x768 please, anything larger please post as a link. Also post some system specs (CPU stock speed, overclocked speed, vcore at that speed & stepping/week number (if known), RAM, fsb, voltage & timings (if known), motherboard, cooling and temps)
    If you get an error in computation of PI, it means your system is not a stable overclock, as it's making computational errors, keep trying til you get it to run without any errors. :)
    Top 30
  2. Tim S
    Tim S OG
    8 Nov 2001
    I'll shoot away with my latest, stripped XP down to as bare as I could get it, practically all services turned off.
    before this, I was hitting 47s with windows not tweaked at all
    specs:
    Barton 2500+ AQXEA 0331UPMW @ 2310 (11x210) 1.775v
    Abit NF7-S
    Alpha PAL8045 with Akasa Nebula Fan
    2 x 256Mb PC3200 Twinmos with winbond, in dual channel @ 210 7-3-3-2, 2.9v
    Temps: delta 14'C idle, delta 16'C load (difference between case and CPU temp)
  3. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    It's a huge image I know, I can't seem to do jpg compression right. If some kind soul wants to recompress it for me I'd be most grateful. Anyway, specs in sig.
    edit: I've shrunk it down to around 110k /bigZ :)
  4. Tim S
    Tim S OG
    8 Nov 2001
    haha couldn't let you beat me :p :p
  5. Will
    Will Beware the judderman...
    16 Jun 2001
    Here's mine :blah: not sure how good it is since nobody's posted a similar speed of cpu, but my system is in need of a format and a good tweak anyway.
    I need a new cpu as well to compete ;), a recent stepping XP2500 would do nicely...need another £60 or so though :waah:
  6. olv
    olv he's so bright
    23 Sep 2002
    Hmmmm i dont think i'll post mine!
    It's a similar time to Will's and its a XP2400 lol. Damn this crappy mobo, doesn't allow voltage adjustments. Its a matter of form over function in my case (pun intented!) lol
  7. Mister_Tad
    27 Dec 2002
    bah, i have all my bits packed up in a box ready to go back to the uk :grr:
    but when i get back i shall pwn you all
    mhuhuhhahahaaaa!
    (hopefully, because ill look pretty silly if i cant after posting this :D )
    system im on right now: Athlon 1200, 256mb PC133 = 2:02 :rock:
    Lappy: P-M 1.4GHz 512mb DDR333 = 0:58
  8. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Heres what such a low FSB gets you :( Stupid board not unlocking multi :waah:
  9. maki43
    maki43 I can touch my toes 1,2,3
    8 Nov 2002
    It should be better but my power supply has the core voltage jumping from 1.85-1.95 :blah: as well as the cpu being overclocked too much and cannot reach 2511mhz ne more :( Plus the crappy kt400 not being able to reach 200mhz :waah:
  10. Tim S
    Tim S OG
    8 Nov 2001
    tis still a nice score though :cooldude:
  11. Darv
    Darv Bling!!
    12 Aug 2002
    XP2400+ on an Asus A7N8X.
    Could probably get it to do more but never really tried. It wont go higher than that on the FSB though :waah:
  12. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i get 49s with my 2500@ 2.35 gig (205x11.5) when all my apps are running (all the sys tray stuff, AV etc, running irc, mbm, outlook, firebird, watching stargate etc :D)
    i dont really see much point in shutting everything down to benchmark, its never going to be like that :p might as well find out how much 'spare' power i have after running all the other stuff :)
  13. Tim S
    Tim S OG
    8 Nov 2001
    I couldn't resist posting this one :D
  14. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    mines about 40secs with my p4, just got my new hsf so will edit this post asap with my result
  15. Tim S
    Tim S OG
    8 Nov 2001
    Managed to get 2500Mhz, but superpi was no quicker... still 40s :blah:
    Upped my 3dMark score to over 10500 from my poor lil GF3 :cooldude:
  16. eek
    eek CAMRA ***.
    23 Jan 2002
    do i win? :D
    :rock:
  17. Tim S
    Tim S OG
    8 Nov 2001
    sweet time dude! :D
  18. AXiSShOOteR
    AXiSShOOteR What's a Dremel?
    30 Sep 2003
    XP1700+ @ 2314mhz
    2*256 DDR PC3200
  19. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    congrats guys my lowest is 50 seconds so far, but im worjking on it!
  20. Tim S
    Tim S OG
    8 Nov 2001
    50s is still a damn good time, I'm gonna give it a run on this system I'm running at the moment with my main rig being down for it's immersion into the wet stuff ;)
    Tbird1000 yoooohoooo!!! :D
