Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Tim S
    Tim S OG
    8 Nov 2001
    no, I'd say it has a 50% chance of dying within 2 months, 75% chance of dying within 3 months, and then 99% chance of dying within 6 months. :rolleyes:
  2. Tim S
    Tim S OG
    8 Nov 2001
    back on topic....
    w00t! I knew I could do it, and I didn't need as much speed as I thought I would! :cooldude:
  3. Tim S
    Tim S OG
    8 Nov 2001
  4. maki43
    maki43 I can touch my toes 1,2,3
    8 Nov 2002
    Tomorrow i should have some new times as im the proud new owner of a Abit NF7-S so im going to see what sort of difference it will make. Should be able to increase the fsb to 220mhz from 185 and mayb more head room for overclocking. As well as my new modded case with 8 extra fans, might be better than 49s :hip:
  5. maki43
    8 Nov 2002
    this isn't the spanish inquisition ;)
    Would be nice tho as its very impressive and ull be hailed as the overclocking king! or very lucky :D
    BigZ - just thought of something. Why dont u take the time of each indervidual and put it in your first post along with thier clock speed?
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    bigz i have to admit to defeat to you on super-pi, 40s is my best but i cant prove it, weel pld m8 :rock: :rock: :rock:
  7. Tim S
    Tim S OG
    8 Nov 2001
    If I get chance tomorrow, I'll do this mate, gotta be up early and gots a lot to do tomorrow, I'll have a go though! May take a little time :)
    Cheers buddy! :rock: :cooldude:
    I still think there might be a bit more in this chip, I should be able to lower the voltage on this speed tomorrow after 24 hours burning in :) If it works at a lower voltage still, I'll be trying for 225fsb (ish) :D
    I'm limited to a certain extent by my RAM, I don't really want to have to drop the 2-2-2-11 timings down, it'll do 2-2-2-11 up to 230Mhz, so I'll hit a ceiling at some point :) It's whether it'll post at 230x11.5, I'm taking it gradually, so not to damage the CPU by putting too much voltage through it too soon to force more speed out of it. I seem to be able to get better overclocks from being patient and slowly increasing speeds, two days ago, I couldn't post above 2400Mhz (after a saga over me trying to get more fsb from using d10 rather than d18 bios) all of a sudden, I'm over 2500Mhz by a good distance, with exactly the same voltage, and I have a feeling there is still a little bit more to come from this baby :baby: :hip:
  8. olv
    olv he's so bright
    23 Sep 2002
    still standard cooling. saving up for a prommie see what this chip can really do :D
  9. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    What the error
    'NOT CONVERGENT IN SQR' stand for ?
    Took my FSB from 156 to 157 and I get this error. Altho the temps remain the same, even 2C lower actually at full load.
  10. sinizterguy
    25 Jul 2002
    Increased the voltages by 5% error went away, and I upped FSB to 158.
    Cpu @ 2853 MHz
    Volt = 1.504 to 1.536
    Temps = 52-54C at full load (same as before)
  11. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    5% jump? That's pretty major for a 1 mhz difference
  12. sinizterguy
    25 Jul 2002
    Thats the only option I have on my mobo. Or I would have tried a lower amount.
  13. Tulatin
    16 Oct 2003
    Ah. What mobo are you stuck with this on?
  14. sinizterguy
    25 Jul 2002
    Abit BE7
  15. Tulatin
    16 Oct 2003
    Ah. I suppose the bios is like the BH7s then (i have one, dead bios)
  16. sinizterguy
    25 Jul 2002
    Not sure, but should be.
  17. Tim S
    Tim S OG
    8 Nov 2001
    It means there is a calculation error due to the CPU not having enough juice to perform stabilly at that particular FSB :)
  18. Tim S
    Tim S OG
    8 Nov 2001
    and what's that supposed to mean? :rolleyes:
    I'm getting close to the end of my teather with your constant thread trashing, it's beginning to piss me off if you didn't already work that one out for yourself...
    back on topic again
    I can hit ~2.59Ghz with this baby, but sadly, it's not stable enough for 24/7 running. :(
    This was more for the overclock than the superpi score, as you see, no improvement with an extra 50Mhz core speed :)
  19. maki43
    8 Nov 2002
    Just got my ne board in and got it down to 44s, quite pleased but ram needs to be upgraded now. Can get 230 but just reboots :waah:
  20. penski
    penski BodMod
    29 Aug 2002
    i'd just like to point out that it took me 1m 32s.
    XP 1800+ JIUHB @ 1533.4MHz (nought point four megahurtz overclock, yo)
    512Mb PC2100
    MSI KT3 Ultra2
    *n
