Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Mister_Tad
    27 Dec 2002
    im lost
    in cpu-z it picks up the wrong speed as the processor continually adjusts speed according to what it is doing (therfore adjusting power consumption) ie. if you are typing something in word it may be running at aroun 300MHz as that is all that is needed but playing a game it runs at full steam (or 1400MHz in the case of a 1.4)
    the rated speed of a P-M is the max speed it will run at, i think the lowest they go is 300MHz, at least that is the lowest i had noticed mine going
  2. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    You get a more accurate reading if you run CPUZ when the cpu useage is at 100%
    This is a Pentium-M running Super PI:
    And this is the same Pentium-M when idle:
    If you leave CPUZ open while using the laptop you can see the core speed jumping all over the place.
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    looks like ive triggered something off here :S
  4. Mister_Tad
    27 Dec 2002
    righto, as i have a 10k drive just sitting there waiting to be filled i thought i would do another install of windows, strictly for fiddling around with (i.e. things like superpi)
    i was wondering what would be the best OS for it, i have 98, 2000 and xp pro
    also in xp pro, for no crap running in the background is it best to turn all services off or are there some that need to stay running. in msconfig what i had been doing is running a selective startup and deselecting System.ini, win.ini, system services and startup items. but are there some services which aid performance?
  5. Xen0phobiak
    8 Aug 2002
    win2k wont use the p4c to the extent that xp will, so 98 or xp, id go with x to get the ht support.
  6. Mister_Tad
    27 Dec 2002
    would HT make a diff in something like superpi? i have run it with it off and on and get no difference, i know there is significant advantages of HT in applications but would benchmarks and general fiddling be diff do you think?
    im kind of leaning towards using 98, just because i havent used it for aaaages with the exception of working for some clients with proper crusty pcs from time to time, haha there was one with 64mb ram and they decided to upgrade to win2k and wondered why everything was so slow, im surprised it even bothered booting up at all with that little ram :D
  7. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Stock P4 - 2ghz dell
  8. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Bumping my post.. BigZ update the chart...
    (Hmm, mabye he doesn't want to be de-throned :D )
  9. Mace
    9 Dec 2003
    zap man, I would kill for your 64 fx :)
  10. Hiren
    Hiren mind control Moderator
    15 May 2002
    XP2000+ at stock speeds. - 1m 8s
  11. Tim S
    Tim S OG
    8 Nov 2001
    I will, once I've done all of my coursework due in for tomorrow... ;)
  12. smokeybox
    smokeybox What's a Dremel?
    11 Dec 2003
    Hi! Here are my numbers...
    Epox 8RDA3+v2.1.Barton2600+@2618(11x238)
    2x256mb Twinmos Twister 3200 2-4-4-8 2.9V (1:1FSB)
  13. olv
    olv he's so bright
    23 Sep 2002
    Thats a nice overclock and nice time you got their Smokeybox :thumb:
  14. Mister_Tad
    27 Dec 2002
    nice time, whats with the crazy font in superpi?
  15. Tim S
    Tim S OG
    8 Nov 2001
    Smokeybox, what vCore are you using, because I know that the 8RDA3+ has issues within CPU-Z where it takes the VDD rather than the vCore.
    Also, what cooling do you have, and what's the max FSB you can run 2-2-2-6 or better at? cause you'd be looking at 37/38s with 2-2-2-6 @ 238fsb. Nice clocks, and welcome to the forums! :cooldude:
  16. smokeybox
    11 Dec 2003
    Hi..
    Vcore is displayed in th picture..1.968...(2.00 in Bios)..
    I use Twinmos Twister PC3200 CL2 memory..(2-3-3-8) with relax timings 2-4-4-8 i can push it to 238..
    I know it ain't the best memory for the job but price was right...
    That was just for benching :rolleyes: ..i usually use this setup..
    Epox 8RDA3+ v2.1
    Barton2600+@2500(12.5x200) 1.85V
    2x256mb Twinmos Twister PC3200 2-3-3-8 2.77V
    ATI 9800SE AIW (Pro mod)
    Zalman WaterBlock,BlackIcePro Radiator,120mm enermax Fan,Hydor pump
    Maxtor 120GB HD ATA-133 .Q-Tec 550w PSU
    About the Font..do not know..always been like that...
  17. smokeybox
    11 Dec 2003
    I can finish SuperPI with 2660MHZ but the score will be still the same.. 39sec... :eyebrow:
    Must be my memory timings.....
  18. Tim S
    Tim S OG
    8 Nov 2001
    lower latency is the key ;)
    combined with good fsb and cpu speed.
  19. OCed
    OCed What's a Dremel?
    14 Dec 2003
    my computer is in my sig and this is what i can get with it (i hear the pic doesnt work, i got 30 seconds)
  20. ZapWizard
    19 Sep 2002
    OCed your image doesn't work.
    (Attachements from one forum will not show up in another forum)
