Other Parkside Power Tools
Discussion in 'General' started by DeadP1xels, 5 Mar 2023.
  1. DeadP1xels
    30 Nov 2009
    Unfortunately, got quite a lot of work to be done in the garden to get it child safe and a reasonable place for the summer, bunch of donated timber to achieve such a job but I REALLY don’t fancy going at it with a hand saw…
    Lidl shop today so I walked down the coveted “middle aisle” £44.99 for a Parkside battery circular saw and £24.99 for the charger and battery which I could also use on the £29.99 Impact driver…and more!
    seems reasonable to me…
    or is it?
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    6 of one half a dozen of t'other.
    It ain't great stuff, but it's not terrible either and if it works when you get it home you'll get a good few years worth of casual use.
    Obvs. they're built down to a cost, but if you're not expecting Makita quality, back up / customer service and longevity they'll serve as basic DIY grade tools.
    Arboreal likes this.
  3. David
    7 Apr 2009
    They're generally fine for home use. Are they the best? No, of course not. Do you need the best? Probably not.
    I'm sure everyone would love to have Makita, DeWalt or Milwaukee tools but, at three to five times the price for one-off or occasional use?
    GaryP likes this.
  4. Arboreal
    21 Jan 2011
    Parkside do some great stuff in their 20V range.
    We're Makita at work, but have some really good Parkside gear.
    I have a 12V mini circular saw for plywood etc at home, and my Dad has some 20V kit.
    He needed an impact driver but wouldn't use it enough to go Makita and bought it for £60 including a battery and charger.
    He already had batteries and charges as he had 2 excellent tiltable LED torches and a 2 piece air pump set (HP for tyres and LP for inflatables).
    They are fine for DIY/home and lighter work use, but probably won't take the pasting a top tier tool would take.
    **EDIT** Seems we have a pretty similar view on this!
    GaryP likes this.
  5. GaryP
    GaryP RIP Tel
    31 Aug 2009
    This, same with their hand tools, handy for in the boot of the car but wouldn't want to earn my living from them.
  6. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Use and abuse em, when they die just keep your receipt handy, they offer a no quibble returns policy.
    IanW likes this.
  7. Krikkit
    21 Jan 2003
    Most of the Parkside stuff is reasonable for DIY the two exceptions of the ones I've used are the circular saw (battery not up to running it cutting anything more than about 5mm ply) and their mains-powered air compressors.
    The circular I'd get a cheap second-hand mains one, try FB marketplace.
    Otherwise crack on!
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Almost all of my stuff is parkside and us great for moderate use, only thing I have had that failed was a sander which they would have replaced if I hadn't lost the receipt but I took it apart and fixed it anyway.
    I have two circular saws, the big one works fine but you need the 4ah battery really for the small skill saw or you are limited to what thickness you need to cut, is that the one you have Kriklit?
  9. legoman
    legoman breaker of things
    28 Feb 2010
    Have to say with my Ryobi's if I run more power hungry tools so impact gun, SDS or circular saw, they really struggle, with a small battery, lob in a 5ah, and they work really well.
