Hardware PC Hardware Buyer's Guide May 2011
Discussion in 'Article Discussion' started by arcticstoat, 10 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    GTX 590 most powerful card?
    i thought that was the HD 6990....
  3. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    I wouldn't pick up a C300 nowadays, especially with the Crucial M4, the Intel 510 and the immense OCZ Vertex 3 available at similar price points.
  4. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    Erm........... gtx590? Id say its an even coin toss between that and the 6990, wouldnt you? Otherwise, nice lists of kit made.
  5. Shayper09
    Shayper09 Swimming in Deionized.
    14 Jun 2010
    Hd6990>Gtx590
    Why you ask?
    I prefer my computer not to explode when given something challenging to do...
  6. Parge
    16 Jul 2010
    Surprised you didn't opt for a 5850 Xtreme @ £100 over a 460 GTX!
  7. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    if I wanted a photo- editing machine(multi-tasker, some film editing - no gaming) with tons of storage should I look at the set up for the Gaming Workhorse or the All Rounder?
  8. Luay
    Luay What's a Dremel?
    13 Jul 2010
    Thanks Bit-Tech and respect to not recommending a new part until you get your hands on it, such as the Crucial M4 SSD 64GB which is $30 more expensive than the C300.
    Not optimistic about the SIlverstone Raven 03 when the reviews come out.
    GTX590 is hard to find. I'd change the motherboard to Pro (2 pci-e2.0 x 8), and go for HD6950 2GB CF.
    I would recommend the Asus Proart 24" 1920x1200 ips display.
  9. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    You guys seriously need to review the OCZ Vertex 3 Max IOPS SSD. I think that you should choose it for premium player rig.
  10. Cei
    Cei pew pew pew
    22 Mar 2008
    Phew, my system is still current despite being bought in January. Was expecting it to be obsolete by now...
    Glad to see the R3 is available in the US now too!
  11. Luay
    13 Jul 2010
    One more thing about the cooler. You haven't mentioned Thermalright's SIlver Arrow, nor Noctua's NHD14 & NHC14, so I'm not sure what you guys make of them compared to the Dark Rock, unless you haven't reviewed them yet. Thanks as always!
  12. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    LOL the 6990 fanbois start it off again. It has no place on this elite list.
  13. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    probably has been stated before, but can we add speakers, headsets and monitors to those lists? I'm sure you've already got a stack of decent recommendations and they wouldn't change month to month....plzthanks
  14. KiNETiK
    KiNETiK What's a Dremel?
    7 Apr 2011
    560Ti over a 480GTX? You can get a standard 480GTX for same price as this 560Ti or pay a little more and get a Gigabyte SOC addition which will give you near on 580GTX performance...
  15. wyx087
    wyx087 Multimodder
    15 Aug 2007
    monitor: Dell U2711
    :thumb:
    Bit-tech concluded with 590 being faster than 6990, they are obviously not going to do a U-turn in a hardware recommendation article.
  16. DbD
    DbD Minimodder
    13 Dec 2007
    With the Z68 motherboards coming out tomorrow if I understand correctly I would have thought the best thing to do right now is wait a few days (I am about to do a partial build and that's what I am planning to do).
  17. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    The Crucial M4 is generally ~£40-£60 cheaper than the other two drives, which are roughly the same price.
  18. Pete J
    Pete J Employed scum
    28 Sep 2009
    I was wondering how quickly this would be brought up. First post, no less! You have to remember that in the BT tests, the 590 fared well against the 6990 and was comparatively quiet.
    Not true. Most other sites have the 6990 beating the 590.
    Damn good point! Though they haven't reviewed it yet...
    The 480 would require a more powerful PSU (extra money right there) and a stock version would be louder than a 560.
    Sloth likes this.
  19. technogiant
    technogiant What's a Dremel?
    2 May 2009
    Trouble with the motherboard you've chosen is the lack of any possibility of crossfire/sli because the second slot is only X4 electrically. That really limits the possibility of making a gaming powerhouse by using two more buget minded overclockable cards.
    For instance my current system a Foxconn X38a chipset mobo socket 775 has two pciex16 2.0 both of which are x16 electrically even when both populated......I'm using an sli patch as the mobo chipset doesn't normally support sli and have two palit 2gb gtx460's sli'ed together and OCed to 820MHz from the stock of 675MHz.....matched with a Q6600 @3.5GH and 8Gb DDR2 this would shame all but your most expensive build in gpu limited gaming scenarios.
    It really does play Crysis.......at max settings and 1920X1200.
  20. bogie170
    11 Aug 2008
    +1 on the crossfire issue. I just bought the Asus P8P67 Deluxe as it has its own optimised PLX crossfire engine embedded into the mobo for more performance.
Tags: Add Tags
