Cooling Pete's Watercooling log/how-to. UPDATE: UPGRADES!!!
Discussion in 'Hardware' started by Bloody_Pete, 10 Jan 2011.
  1. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    :cough: dibs on the HAF :cough:
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Only if you want to collect it from Bristol...
  3. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    OK Elysium is huge, but what about the slipper :)
  4. Bloody_Pete
    11 Aug 2008
    Don't dis my slippers, they're awsome... :p
    Any guess the TV show?
  5. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    Mythbusters?
  6. Bloody_Pete
    11 Aug 2008
    Pump top is done :)
    With fittings:
  7. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    My pump top!! What have you done to it!!! :jawdrop:
    Looks awesome :thumb:
  8. Bloody_Pete
    11 Aug 2008
    made it look amazing :p
  9. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    Go on Pete :)
    Is it possible to spray paint this top ? Completly to red or yellow with some uv paint ???
  10. Bloody_Pete
    11 Aug 2008
    I used Plastikote spray paint. Gave each one 4 light coats of undercoat, left it over night, then sanded it lightly (if you apply any kind of pressure the paint will come off) and then 4 light coats of the colour, leaving it to dry over night :)
  11. Bloody_Pete
    11 Aug 2008
    I forgot, I've taken shots of my fans too :)
    I think they're really pretty :)
  12. Guest-56605
    Guest-56605 Guest
    Very nice :thumb:
    Tis a shame they're GT's :p
    :hehe: :hehe: :hehe:
  13. Combatus
    16 Feb 2009
    Looking forward to seeing the Elysium with water-cooling gear inside - I just finished bit-tech's review. Very good case for the cash!
  14. Bloody_Pete
    11 Aug 2008
    These ones are silent, I promise you :) I'm going to buy one of the 3000rpm ones when I sell some of my parts to see what it's like :)
    It's very very good :) Suprisingly light for such a big case too, as it's about the same weight as my HAF 932.
    Keep an eye out, as I'll have this finished as soon as my new GPU block arrives :)
  15. Combatus
    16 Feb 2009
    I think the HAF is about 2KG lighter but once you get over 10KG it all feels the same really - too darn heavy!:D
  16. Bloody_Pete
    11 Aug 2008
    Doubly so once you fill it with components and watercooling gear. Even my HDD caddy felt like it was nearly 1Kg once I had my 3 1TB and 2 SSD's installed...
    I love the window on it though, one of the best I've seen to date.
  17. Bloody_Pete
    11 Aug 2008
    GPU block is finished :)
    I also painted the rear plate:
    Looks good I think :)
  18. bulldogjeff
    2 Mar 2010
    Tell ya what Pete, you've done a nice job on that lot mate, looking really good.
  19. Bloody_Pete
    11 Aug 2008
    Thanks buddy :) Turned out really well :)
  20. Bloody_Pete
    11 Aug 2008
    Another little update.
    Firstly, here's the finished graphics card:
    Secondly, I've now installed all the components:
    So tomorrow it'll be fun with tubing and tube sleeving :) And to finish with some mesh to cover that nasty mass of wires :) Stay tuned...
    Also, nearly at 10,000 views!!!!!
