Cooling Pete's Watercooling log/how-to. UPDATE: UPGRADES!!!
Discussion in 'Hardware' started by Bloody_Pete, 10 Jan 2011.
  1. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    looks good dude, see what you mean about the top panel being in two sections and by chance where any of those photos ones you where trying to show me, also the case is HUGE!
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yup, they're the ones :) Its truely massive :p
  3. Bloody_Pete
    11 Aug 2008
    Just hit a snag, was trying to remove the rear fan and the 2 bottom screws are in insanesly tight, as I've managed to strip the screw heads :( boll*cks!!!!!
  4. thetrashcanman
    18 Nov 2010
    oh bloody hell, why where you removing the rear fan anyway, where you going to braid the cable from that as well or something :)?
  5. Bloody_Pete
    11 Aug 2008
    Yeh, I was going to braid it, no nasty cables... I may just have to do it while its in the case now unless people have suggestions...?
  6. Bloody_Pete
    11 Aug 2008
    Just braiding various cables, and I've come to the front pannel audio cable. Question is, do I need the ZC'97 connector, or can I simply cut it off?
  7. Big Elf
    23 Apr 2009
    Can you tape it up and hide it?
  8. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    I've heard you can cut it off. But I would just tape it away.
  9. Bloody_Pete
    11 Aug 2008
    Well I want to braid the cable, so removing it would make life massively easier...
  10. Sponge12349
    12 Apr 2010
    Does the braid fit over the connector when you pull it back in line with the other cable?
    (assuming its like this..)
  11. Bloody_Pete
    11 Aug 2008
    It will, but trying to get both in the braid will be a huge pain plus the bulge will look rubbish...
  12. Sponge12349
    12 Apr 2010
    Where is the port on your motherboard?
    On my P6T its right along the bottom edge(which I think is standard). Also my utgard has a little hole just under the motherboard which I use for this purpose. In my case(no pun intended), The bulge would not be visible.
  13. Bloody_Pete
    11 Aug 2008
    I'm using a Asus Xonar DS...
  14. Sponge12349
    12 Apr 2010
    What about taking the end plastic connector off then tape the wires so they don't touch?
  15. Bloody_Pete
    11 Aug 2008
    I'm just leaving it for now, my paranoia is too rampant to remove it :p
  16. Guest-56605
    Guest-56605 Guest
    Personally I never bother with the front panel audio connections anyway and just cable tidy them out of the way, the Aego M's have a headphone jack on the sub so I use that :thumb:
    Are you fretting about your nice shiny new case already Pete???
    You've only had it 5 minutes :hehe: :p
  17. Bloody_Pete
    11 Aug 2008
    Gah, why didn't I think of that??? My SP2500's have a headphone output too!!! Urg!
    And you'll love the cable management I've done so far...
  18. Bloody_Pete
    11 Aug 2008
    Managed to beat the screws, so I'll take some pics later :)
  19. Bloody_Pete
    11 Aug 2008
  20. thetrashcanman
    18 Nov 2010
    looks awesome mate, can't wait to see the rest of the rebuild
