Cooling Pete's Watercooling log/how-to. UPDATE: UPGRADES!!!
Discussion in 'Hardware' started by Bloody_Pete, 10 Jan 2011.
  1. bagman
    bagman Minimodder
    18 Apr 2009
    I really need to get my water cooling rig back together, air cooling just doesn't cut it for me. Keep up the good work Pete. Glad you are making me going back to water cooling.
  2. DarthBane
    DarthBane What's a Dremel?
    3 Jun 2011
    Pete, I'm thinking of having a go at water cooling after looking at this! :D What is the Xigmatec like to work with?
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Fairly good,very spacious :) the only realy cons are the reinforing strips behind the HDD mounts and the reinforcing strips on the front pannel. And how damn tight they tighten all of the screws!!!
  4. DarthBane
    3 Jun 2011
    Thanks Pete :thumb:
    Do you think you could fit another rad in there by removing some of the hd enclosures at the bottom of the case?
  5. Buck_Rogers25
    Buck_Rogers25 Minimodder
    6 Feb 2002
    *sniffs* I miss tygon *sniffs*
    So bloody expensive now though. Looks great so far mate.
  6. Bloody_Pete
    11 Aug 2008
    You could fit a 240mm rad, but you'd have to drill a fan hole. Personally I'm put it upright in the 5.25" bays though. Why would you need that much cooling anyway?
    My Tygon tubing is now for sale...
  7. DarthBane
    3 Jun 2011
    I probably won't tbh! But planning ahead i may go SLI and then move the GPU's onto a seperate loop.
    do you think that would be excessive?
    On a side note whilst i have your attention!:) can you recommend any other cases for watercooling?
  8. Bloody_Pete
    11 Aug 2008
    Depends on your budget and your coling needs...
    Big Elf likes this.
  9. Buck_Rogers25
    6 Feb 2002
    Mate if your Tygon really is for sale, PM me with the details :).
    Bought a load of this UV Blue PVC stuff for 83p a metre and it's perfectly usable, but god do I miss the Tygon. Dug some old stuff out and cleared it up for a few bits on my current build, just so I have a piece of hose I can squeeze to bleed easily.
    Oh and there's no such things as too much cooling.
    :dremel:
  10. Bloody_Pete
    11 Aug 2008
    Check my forsale thread in the marketplace :)
    And there is, as if your cooling a 2500k and a 560TI, a 360mm will be more than enough...
  11. Buck_Rogers25
    6 Feb 2002
    Cheers, I'll have a look.
    Aye I know, but I'm a bit of a passive freak. That rads the aquacomputer 1800, meant for 12 x 120 fans, but I run it with none. Not superb temps but silence is more important for me. Got two 360s, one of which will be going on a Q6600 + 2x 8800 GTXs I'll be doing soon as a replacement HTPC box, that's definetly going to need fans :).
  12. Bloody_Pete
    11 Aug 2008
    My machine is practically silent, my GF's xbox 360 makes way more noise...
  13. donok
    donok Every Little Helps .....
    16 Feb 2011
    Any ideas for a i5 2500k with gtx 580 in SLI
    Will a single 360 RAD work or should I go dual loop ?
  14. Bloody_Pete
    11 Aug 2008
    I'd say a RX360 will work with some good fans :) Whack it on one loop with a D5 for high flow and you'll be sorted :)
  15. donok
    16 Feb 2011
    what if i go 3 way sli ?? just turn the fans up or hang a 360 off the back ?
  16. Bloody_Pete
    11 Aug 2008
    What case are you using?
  17. donok
    16 Feb 2011
    nothing as of yet. believe my mate wants it all in a corsair 700D
  18. DarthBane
    3 Jun 2011
    That was my thought exactly!:clap:
    Now i just need to save up for 6 months :waah:
  19. Bloody_Pete
    11 Aug 2008
    Oooh I know one guy on here runs 3 580's off a RX360 with good temps in a 800D, and he's looking to add another rad for CPU, which is a pain for those cases. I'd personally say a RX360 and a RX240 just to be sure, but it's going to be a squeeze + modding in a 700D
  20. Bloody_Pete
    11 Aug 2008
    There is when you spend too much money...
