Case Mod - Complete ⭐ Phantom Plane
Discussion in 'Project Logs' started by AKMod, 24 Feb 2020.
  1. AKMod
    AKMod Modder
    29 Mar 2018
    Hello everyone,
    I’m AK from Taiwan.
    I try a bold concept, transform the mini-ITX case into EATX, will bring a bit of Cyberpunk concept.
    Spec:
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ASRock X570 AQUA
    Seagate Firecuda 510 2TB
    Antec KATANA DDR4-3200 8GX4
    Antec HCG Gold Series 750W
    Antec STRIKER
    Antec Prizm 120 ARGB
    Antec PRIZM COOLING MATRIX 240 ARGB
    Watercooling:
    Bitspower Brizo VGA water block
    Bitspower D5 Vario Pump
    Bitspower Leviathan SF 360 4xG1/4" Radiator
    Bitspower Leviathan SF 240 4xG1/4" Radiator
    Bitspower Fittings
    Thanks AMD, ASRock, Antec, Seagate, Bitspower support.
  2. AKMod
    AKMod Modder
    29 Mar 2018
    • Some hardware photos
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ASRock X570 AQUA
    [​IMG] [​IMG]
    Antec STRIKER
    Bitspower
    CSZModified likes this.
  3. AKMod
    AKMod Modder
    29 Mar 2018
    • Sample
    First plan the style of the waterway board, and the layout of all hardware.
    greensabbath and Cheapskate like this.
  4. AKMod
    AKMod Modder
    29 Mar 2018
    • Processing drawing
    Structural design in the waterway plate presents a complete back plate, adopt dual waterway parallel connection design.
    D5 pump armor, directly combined with front waterway plate structure.
    Side cover retains original design.
    Back cover and front cover design.
    ivory2k19 likes this.
  5. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    :roccia:
    AKMod likes this.
  6. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    can't wait to see the final result!
    AKMod likes this.
  7. AKMod
    AKMod Modder
    29 Mar 2018
    • Assembly
  8. AKMod
    AKMod Modder
    29 Mar 2018
    • Cutting
    Since the two back plates in the middle are changed to water channel plates with a thickness of 15mm, the diameter of the aluminum pillar needs to be modified to make it stable.
    Cheapskate likes this.
  9. AKMod
    AKMod Modder
    29 Mar 2018
    • Water board
    Because it needs to support the overall strength, the material is 10 mm POM.
    CNC overall groove.
    D5 pump armor is also made of POM material!
  10. AKMod
    AKMod Modder
    29 Mar 2018
    • Test assembly
    The chassis is stretched, so the power supply is disconnected, and a 15mm aluminum base will be combined in the future.
    Dot_Kappa and Cheapskate like this.
  11. Cheapskate
    13 May 2007
    Awesome. :D
    AKMod likes this.
  12. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks bro!
  13. AKMod
    AKMod Modder
    29 Mar 2018
    • Assembly
    BTW new workshop in progress!
  14. Cheapskate
    13 May 2007
    Was the PCIE cable too short?
    Your work space just seems to keep getting bigger. I slightly suspect it's not a computer shop. :lol:
    AKMod likes this.
  15. BigShadow
    BigShadow What's a Dremel?
    10 Feb 2020
    Is looking good, what is the black part made of?
    AKMod likes this.
  16. MrFlibble
    MrFlibble What's a Dremel?
    13 Nov 2019
    :jawdrop::jawdrop: Awsome
    AKMod likes this.
  17. AKMod
    AKMod Modder
    29 Mar 2018
    Hello, does the black part refer to the waterway back plate?
    That is made of pom.
  18. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks man!
  19. AKMod
    AKMod Modder
    29 Mar 2018
    600mm PCI-E extension cable
    Thanks to Li-Heat Industry Co., Ltd. support.
  20. AKMod
    AKMod Modder
    29 Mar 2018
    It's the workshop yes XD
    there is a custom PCI-E extension cable.
