Case Mod - Complete ⭐ Phantom Plane
Discussion in 'Project Logs' started by AKMod, 24 Feb 2020.
  1. kim
    kim hardware addict
    10 Jan 2016
    like @BigShadow mentioned, I'm not particulary a fan of this Antec case, but with your choice of hardware and with the massive redesigning you did, the final result on the last picture is awesome :rock:
    AKMod likes this.
  2. AKMod
    AKMod Modder
    29 Mar 2018
    • Phantom Plane
    [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  3. BigShadow
    BigShadow What's a Dremel?
    10 Feb 2020
    I just would change 2 things in the build, first is the colour pink to red or blue and second just change it to my house it would be so much better with this changes! But serious is really good from a case that really doesn't seem that good to a epic build, great work!!
    AKMod likes this.
  4. kim
    kim hardware addict
    10 Jan 2016
    :thumb: always a fan of your mods:clap:,
    AKMod likes this.
  5. AKMod
    AKMod Modder
    29 Mar 2018
    Video coming!
  6. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you man!
  7. AKMod
    AKMod Modder
    29 Mar 2018
    I am grateful for your support.
  8. Mizuwari
    Mizuwari In vino veritas
    19 Sep 2018
    Lovely, it is ! :thumb:
    I just have one question, about your logo on the PCI Riser : how did you manage to get it there ? Did you paint it by hand, or with a template, or is it some sort of thermotransfer ?:oldconfused::idea:
    AKMod likes this.
  9. AKMod
    AKMod Modder
    29 Mar 2018
    Hi, this is UV printing!
    Dot_Kappa and Mizuwari like this.
  10. Mizuwari
    19 Sep 2018
    Great to learn that! Thanks for sharing the technic! :clap:
  11. AKMod
    AKMod Modder
    29 Mar 2018
    You're welcome, I also learned a lot here!
  12. Cheapskate
    13 May 2007
    Another MOTY worthy rig from you. :D It's absolutely beautiful. The pink edge effect plexi is a fantastic touch. It gives just a subtle hint of color. I'm curious if adding a bevel would make it more visible from the side.
    AKMod likes this.
  13. wpk136_STT
    wpk136_STT Sorry, my English is translated by Google.
    26 Mar 2020
    整个机箱拉长了也挺好看的!!侧盖这些钣金是重新做的吗?
    AKMod likes this.
  14. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Apparently google is in quarantine.
    For those who do not know Chinese: The whole case is elongated and looks beautiful! ! Are these sheet metal side covers redone? :grin:
    Dot_Kappa and AKMod like this.
  15. AKMod
    AKMod Modder
    29 Mar 2018
    Thanks so much for your support!
    Adding the bevel effect will be more obvious, but the front will not appear transparent.:clap:
  16. AKMod
    AKMod Modder
    29 Mar 2018
    你好, 是的我重新打樣折彎拉長版的鋁件板金, 想保持原始機殼的感覺!
    Hello, yeah I make and bent the elongated aluminum sheet metal, and wanted to keep the original case feel!
  17. wpk136_STT
    26 Mar 2020
    你这样的改造证明了这个itx机箱就算是改成ATX机箱也是很帅的!!!整体的那种机械感更强了!!!
    Your transformation proves that this itx case is very handsome even if it is changed to ATX case!!
    AKMod likes this.
  18. AKMod
    AKMod Modder
    29 Mar 2018
  19. Cheapskate
    13 May 2007
    The edge plexi is too expensive to casually experiment with, so I just wanted to know if it would work. ;) I agree with your design choices.
  20. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you man.
