News Phobya water-cooled case design competition - the best concepts so far
Discussion in 'Article Discussion' started by Lizard, 16 Nov 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. slackda
    slackda Is aiming for a Headshot!
    23 Aug 2010
    some smart looking designs there, want to get one in, but struggling to find time around my revision :(
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    Really need to get cracking on this while the girlfriend writes her magazine articles of an evening!
  4. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    This is a competition that I did consider entering but although in my head I know exactly what I want, when it comes to putting it on paper I am lost. Some amazing designs already by the forumites ensure this will be a close run contest and I cant wait to see all the final designs.
  5. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Some very cool designs. thanks for the feedback I had on the thread! Most of the designs are spectacular, but I like mine the best. LOL.
  6. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    I have some ideas for this too and am working on a few virtual mock ups.
    I am quite excited since I recently got a new SilverStone Raven RV02 case. If you are familiar with that case then you wont be suprised to know where I will get my format inspiration from :D
  7. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Although I like all the designs and thoughts behind it. I find that some case designs are to big and impracticable to be made in fabrication.
    If I look realistically into the future, 10 3" drive bays or five 5" drive bays are also overdone since you can do enough with 4x2TB drives and one br/dvd burner. Seeing the increase in Tera-bytes every year. A year from now you could predict that five 3" and two 5" drive bays are enough, not to mention the usb3.0 external device possibilities. To really stand out design wise you should probably aim at a mid tower design where one could fit in a 360 rad loop, the primary reason for this being all the WC cooling stuff is jammed into big towers most of the times. Do it in a mid tower and you have struck gold.
    Thoughts?
  8. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Don't these get put into production? If so some of the designs are not starters, although they look great they are hugely impractical. Not sure were I would be able to put he LiquibOx. My favorite design is the one by anakha.
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    My concept is a midi-tower actually, allthough it has space for up to 10 5.1/4" bays. The whole case is 500x225x500mm (h x w x d). That's just 50mm higher/deeper and 10mm wider then a Antec Threehundred and far from the measurements of a full-tower.
  10. Combatus
    16 Feb 2009
    They are only concepts at this stage - if you think it would be impractical then by all means vote for your favourite or submit something you think is better ;-) They are big, but water-cooling radiators aren't getting smaller so it stands to reason that the designs will need to be large. However, as jrs77 has shown, it's not impossible to design something that's the same size as a midi tower.
  11. alexdcd
    alexdcd Laptop Specialist
    24 Feb 2006
    Im kinda interested in putting a few days of work in on SolidWorks then Render in KeyShot,
    but.... who are these guys, never heard of them before and the company info provided is very, very suspicious?
    Just wondering if it is worth the effort for a no-show?
    Only one product released two years ago with patent still pending!
  12. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Have had a few concepts, no time since it's ENDING on the day my A levels end.
    How evil, bit.
  13. [USRF]Obiwan
    9 Apr 2003
    Well I managed to put a 240 rad, reservoir, Eheim pump, dvd drive, 3 hd's, CPU block, Chipset block, gpu block and 40x4 lcd into a LILI PC60. (old model) So you don't need to go big, just think very hard on efficient spacing.
  14. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    If you look through the thread, you can see most people are trying to make the case compatible for at least two radiators, plus a bunch of DVD drives and HDDs. This means making the case bigger, much bigger in some cases :)
  15. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    I love the stretched Antec 300 look of jrs77's design, would definitely consider something like that for big water cooled systems if it actually makes it to market.
Tags: Add Tags
