Pondering about watercooling my next project, input needed.
Discussion in 'Watercooling' started by Jean R built, 12 Apr 2021.
  1. Arboreal
    21 Jan 2011
    You had me at 'ITX version of Da Module'....
    Jean R built likes this.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Just a thrown together blockout, needs a smaller GPU but works out to be 230mm x 270mm x 222mm (assuming the GPU is no taller than the rad). What do people think, worth me continuing in a full blog?
    Esit: sorry for the thread hijack!
    Cheapskate and Jean R built like this.
  3. Jean R built
    Jean R built Modder
    17 Feb 2020
    Don't worry this Hijack is extremely cool :grin:
    The big radiator/s small hardware is growing on me.
    For the GPU, it depends the 3090 is huge, but you can shrink it a lot when converted to liquid cooling to 8.5" or 215.9 mm , so I'm pretty sure that it should not be a big problem.
  4. Jean R built
    Jean R built Modder
    17 Feb 2020
    I hope you will like it.
    Before this thread it was going to be a low volume build a bit out of the norm, but now with the need to pack, proportionally speaking, a huge radiator area, it's getting wild :grin:
  5. Bloody_Pete
    11 Aug 2008
    Just a thrown
    This is what I used as a placeholder card, so it'd need to be something more bespoke to fit properly! I'll have to give it some thought! But you're right, big rads with tiny hardware it becoming strangely compelling!
  6. Jean R built
    Jean R built Modder
    17 Feb 2020
    Cool :cooldude:
    So would you consider a triple 140 future proof?
    I've made various sketches and by using a triple fan setup, the whole thing is still small enough, the longest part being obviously the radiator/s.
    I've tried multiple rads and with a single longer one, as expected multiple radiators allow for more fun with exotic strange/cool configurations :grin:.
    I've tested also some dual 280 configurations, but if it's not needed I would avoid it honestly, it does look strange, but it add so much volume that it lose a bit of the funny factor as it is not that small.
  7. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    Have you considered asking a rad manufacturer for stats on their 140mm products?
    EK have written blog posts about heat dissipation before, Eg https://www.ekwb.com/blog/radiators-part-2-performance/
    With the quality of your last build it'd be worth a cheeky sponsorship request too!
  8. Bloody_Pete
    11 Aug 2008
    I've used a tripple 120 across 4 different builds and around a decade of use, always been fine, although I will note this are the 60mm thick ones!
  9. Jean R built
    Jean R built Modder
    17 Feb 2020
    Thanks for the replies :thumb:
    I will check if I can find more specific info about the rads, thinking about it there are indeed a lot of builds with a single 360 radiator.
    A single 420, even if slightly less fancy, would make the loop extremely simple, maybe even a bit safer on the leak prevention department.
    But a triple 140 allow for some cool configurations.
    Now I'm thinking about using the pump from corsair, but using a smaller reservoir to keep the volume on the smaller side, as I don't think that thermal efficiency would be influenced by it.
    Bloody_Pete likes this.
