Case Mod - In Progress Poor Man's PC MOD - Finish..
Discussion in 'Project Logs' started by jay2, 22 Oct 2012.
  1. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    Convection isn't a problem here IMHO. In active airmovement it's almost doesn't matter. Only problem could be when warm air from psu sucked inside case by fans
    send from my BLADE via tapatalk
  2. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    Ambient air sucked inside psu thru my side window case (metal mesh with air filters) and push hot air from PSU out of my case (bottom mesh PSU).
    (bottom view)
    next time i'll make another fan hole at the bottom case and put my yateloon to exhaust hot air around vga card.
    Negative air flow fans ...negative air flow fans :D
  3. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    Epic budget modding here mate, i love the sleeve on the coolermaster style legs you made. One question though and thats why does it look like your cpu cooler is tilted, did it take a knock or is it just the photo angle???
    Epic work mate :thumb:
    Rip
  4. Julien Pod
    Julien Pod What's a Dremel?
    23 Oct 2012
    Very funny the way you used shoe laces !!!
    And pretty result by the way :)
  5. jay2
    3 Oct 2012
    I found 2nd hand xigmatek dark knight (without 1155 bracket) for only 15$. So instead of using intel standard cpu cooler, i took 775 xigmatek dark knight. And luckily my asrock mobo has Combo Cooler feature so i can use 775 HSF on 1155 socket, although yes the mounting hole is a little bit tilted :)
    :D
    ppl can do anything with everything they have when they really want something badly.
  6. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    My apologies I must have misred your post, I thought you were pushing air through the top and using your PSU to pull it through the bottom. Please ignore what I wrote above about the airflow.
  7. jay2
    3 Oct 2012
    thats alright, no need to apologies :thumb:
    a little progress:
    since i had to sell my dremel like rotary tool to survive untill next salary day :waah:
    I use a knive to drill some holes on font case
    Marked non food kitchen knive. Make 3 holes :dremel:
    [​IMG] [​IMG]
    For this... fighter pilot style switch from local market and my diy fan controller. I forget to buy one more potensio knob :wallbash:
    I use the switch to change fan voltage from 12V to 5V incase i need total silence for movies. Fan controller needed when i play some stealth game. Full rpm only for benchmarking (which is i never did) and for full action game (full speaker volume to cover 44++dB yateloons).
  8. Ripitup121
    18 Aug 2010
  9. jay2
    3 Oct 2012
    So far, it still better than intel stock HSF..
  10. Cheapskate
    13 May 2007
    Doing great.:thumb: Seeing this makes me want to do another $0 case. The towel rack is brilliant!
  11. Kasius
    Kasius Bringin' the dremolition
    16 May 2003
    Imaginative, love it :dremel::thumb:
  12. jay2
    3 Oct 2012
    Do it :D love to see your mod design..
    :dremel::rock:
    I'm thinking to get water cooled... tomorrow is salary day and now i'm calculating some impossibilities (240 rad, standard pump, low end cpu water block, NB block, vga block, normal reservoir)
    naaah, i guess I'll just buy some tubing first, and several cheap fitting... :)
  13. Vloyadkin
    Vloyadkin What's a Dremel?
    10 Aug 2012
    I really like this mod and your ingenuity(?) (spelling pad)..
    Rated and subbed :thumb:
  14. jay2
    3 Oct 2012
    :thumb:
    I got packages from china... i'll install em tomorrow :)
  15. jay2
    3 Oct 2012
    3 bay reservoir... less than 2$, i'm not measuring anything, if it's not fit, i'll use it as my tool box, but then it fits perfectly :D i'm glad
    [​IMG] [​IMG] [​IMG]
    I'll buy 5$ submersible pump tomorrow...
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Some really cool ideas dude, loving the fan mounts and the towel rack base. :D
  17. WALKYRIE
    WALKYRIE What's a Dremel?
    29 Aug 2012
    I love those full black matt Yate-Loon Fans, me too have lots of Yate-Loon 120 and 140mm
  18. jay2
    3 Oct 2012
    Updates... :)
    My beloved Xigmatek Dark Knight
    more fins down
    And.. tadaaa... I'll tidy up this thing later...
    [​IMG] [​IMG]
    :rock:
    :rock:
    legoman likes this.
  19. HobbieZones.com
    HobbieZones.com What's a Dremel?
    13 Feb 2011
    Very good idea to take a stock cpu cooler and mod it to water.
    Just be sure to do a leak test then install.
    Looking GOOD.
  20. jay2
    3 Oct 2012
    Leak test passed :thumb:
