Modding Post your Cell Phone Modifications
Discussion in 'Modding' started by ZapWizard, 10 Jun 2003.
  1. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    /me wishes i had a phone to mod.
    anyhow, cool one with the screen Bard, when I first saw it I thought "Damn! Bard's phone has awesome graphics if it can render a gradient that well! And good resolution!"
  2. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    This isn't really a mod, but can i get a phone not intended for US and use it over here? ie: if i get a gsm phone for Europe, can i make it work over in the States with the right sim card?
  3. inder
    inder Mr.Modtown
    17 Jul 2002
    Nope... not unless it is triband and unlocked for use with any network provider
    The US has its own band that GSM phones operate on, that is totally different to the two here in Europe :)
  4. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    European phones use GSM 900 and 1800, and US phones use GSM 1900 (MHz). Some phones are tri-band, though, and can be used in both Europe and the US.
  5. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    OK, I got a questiin for all you phone hacks. I got a 3210 which will not hold a network signal. Any easy fixes?
  6. GT3_GOD
    GT3_GOD What's a Dremel?
    6 Nov 2001
    I had this with mine, the internal ariel wasn't attached properly inside as it had a small piece of plastic missing, I hot glued it down and it works perfectly.
  7. bushd
    bushd What's a Dremel?
    9 Nov 2002
    To be able to use a U.S.A. phone anywhere else, one it must not be GSM; two it must be capable of going on the network type you are wanting to use. Then, say you take a sprint phone, you must get the MSL, master subsidary lock code. I know in the U.S.A. even if you have it, others won't let you use it.
  8. Darkside
    Darkside What's a Dremel?
    16 Nov 2002
    I modded my Nokia 8210 to blooo leds, and it's very bright.
    Also have Nokia 3210 modded to vibrate motor (bought on ebay for abot £2.00) used software to enable vibrate function.
    3310 unlocked with Dejan Flasher, changed leds to purple, then sold it :lol:
    Will put pic of 8210 up later (when I find it)
    Darkside.
  9. Devil_H@ck
    Devil_H@ck What's a Dremel?
    13 Jul 2002
    How hard is it exactly to solder other leds in a Nokia 3210?
    And what solder would be needed (fluid core, non fluid core, ...)?
    I've got a Weller SP20 (I think, to lazy to check, it's not the SP16, it's a bit larger), the tip is 2-3mm wide, would I be able to do it with that?
  10. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    i have a P800 that i have totally de-oranged -- hacked the start-up logo-- is custom :) and i have taken off the orange logos and unlocked it myself :D
  11. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Had my 8210 bloo LED modded. Was nice and bright.
    It used to be bright enough to light up my whole room. In a club, it just used to light me up blue when switched on :)
  12. GT3_GOD
    6 Nov 2001
    Oh btw, anyone know how/where to get a Sony Ericsson T300 unlocked for as cheap as possible?
  13. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
  14. cderalow
    cderalow bondage master!
    23 Jan 2002
    at what I paid for my V70, it's not getting messed with; as it stands it came with an inverted LCD and blue backlighting, so I can't complain about that.... though I really need to do something about my antenna, as I've bent two now.... :rolleyes:
  15. Kevin
    Kevin What's a Dremel?
    6 Jun 2001
    my friend inverted his 8210 LCD and changed the LCD to white so it looks abit like the v70 display.
    my 8855 comes with white LEDs by default so i don't need to mod them much
  16. Spyder
    Spyder What's a Dremel?
    30 May 2003
    Yes I know what you mean on my V60c I destroy antennas left and right. I purchased a new short rounded off antenna but have not taken the time to put it on. From an engineering stand point I will probably loose some signal strength so not sure what is worse less signal or broken antennas, :wallbash: It will be nice to stop bending a breaking the stock ones! :D I will let you know how it works out.
  17. Drastik
    Drastik Minimodder
    10 Jan 2002
    i have an ericson A1228 what can i do to it, such as making it vibrate, software mods or anything.
  18. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    i just got my first cell today (yesterday now since its 6am eastern us time) its a motorolla :)
    i hope to mod the leds, green just doesnt cut it
  19. Devil_H@ck
    13 Jul 2002
    Personally I think green rox, but the standard green leds are always so dim :(.
  20. Sp!
    Sp! Minimodder
    6 Dec 2002
    I' tryed to mod my 3210 and lost all the new bloo leds and dripped solder on one of the chips and supprisingly it never worked after that.....
    To that end I have a spare 3210 vibration motor and data cable if you want to make me an offer ;)
