Gaming Professor Layton and Pandora's Box Review
Discussion in 'Article Discussion' started by Claave, 4 Oct 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Yoy0YO
    Yoy0YO Lurky Lurker
    20 Mar 2009
    Its really nice to see that you'd review DS games, I hope to see Scribblenauts up here soon :D
    I thought it was a disappointment myself when the ending "turned out to be a dream" of sorts.
    I still find it hilarious after one game how Layton thinks of how this simple object can become a puzzle.
    Thanks bit-tech!
  3. Radical_Monkey
    Radical_Monkey Dremel > Lightsabre
    27 Feb 2008
    Great review! Didnt play the first one but after reading this review I think I might get both.
    Also I think the answer to the riddle is 16?
  4. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Nope. Miles off.
  5. loftie
    loftie Multimodder
    14 Feb 2009
    Good review, I was wondering what all the hype over these games were, i may now have to get one.
    I got 34 as my answer
    CardJoe likes this.
  6. alecamused
    alecamused Minimodder
    22 Apr 2008
    my answer would be 34 as well
  7. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    ok, let's type as i attempt to solve that riddle here.
    The clock has 4 digits, and 3 or more in a row have to be the same. This means that digits 2 and 3 are always included. I'll use digit 2 as a key to start counting...
    • 00: 10
      This is a real winner. 00:00 through 00:09 are good, so that 10 points
    • 01-05: 1 each, 5 total
      only 01:11 works here, one point. The same goes for 2, 3, 4, and 5
    • 06-09: 0
      The 3rd digit is limited to 0-5 in range, so for these hours 2 and 3 will never match, meaning no points.
    • 10: 1
      This one gets a point for 10:00, after that, no cookie.
    • 11: 10
      another winner! 11:10 through to 11:19 get the nod, for a total of 10
    Total: 26
    Oh, and the clock goes through this cycle twice per day, so let's not forget making it 52 :thumb:
    Sounds like this is a game for me... too bad i dont own a DS :duh:
  8. duc
    duc What's a Dremel?
    9 Jan 2006
    same here
  9. mauvecloud
    mauvecloud What's a Dremel?
    4 Nov 2008
    A 12-hour digital clock would not display a 0 hour - the hour goes from 1 to 12.
  10. CardJoe
    3 Apr 2007
    The correct answer is:
    34
    Reasoning:
    Obviously there the usual lot 01:11, 02:22 through to 11:11, plus 12:22, then there's 10:00 too. The ones everyone always misses are the 11s - 11:10, 11:12, 11:13 through to 11:19. That gives 17, all which occur twice in a 24 hour period on a military time clock, giving the final answer of 34.
    +rep to the first correct answer.
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    hmm all the answers are on the first site in google.. that's what I hate- I would use that walk through religiously
  12. Blannor
    Blannor What's a Dremel?
    25 May 2007
    Whoops, missed the "in a row" portion of the puzzle, never mind me.
  13. Xtrafresh
    27 Dec 2007
    Depends on the clock i guess...
    I was actually doubtful of the answer, as i did make the assumption that the first digit would be displayed if it's a 0. (01:11 instead of 1:11)
    gah, good thing i dont have a gameboy. :clap:
  14. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    My guess is 32... but hey... what can you do?
  15. The boy 4rm oz
    10 Apr 2008
    We just got a heap of these games in store last week, I spent some time playing it on our display console, it is very addictive lol.
  16. mauvecloud
    4 Nov 2008
    I've never heard of a digital clock or watch that was actually made to display a 0 hour when in 12-hour mode. I sent my rental copy back last week, but I found some shots of that puzzle (which is only in the US version, not the UK version; not sure what it was in the japanese version), and the only confirmation that it uses 12 instead of 0 is in hint 3. I guess we should say that the puzzle is badly worded, especially when a lot of the puzzles require challenging assumptions you may have about them.
  17. CardJoe
    3 Apr 2007
    IIRC it does mention military time in the question, i.e. "Zero hundred hours".
  18. delriogw
    delriogw What's a Dremel?
    1 Aug 2007
    if it's military time then each time would NOT occur twice within a 24 hour period.
    after 12 noon you're into 13.00 and so on.
    so you'd have 13.11, 13.33, 14.11, 14.44, 15.11 15.55, 16.11, 17.11, 18.11, 19.11, 20.00, 20.22, 21.11, 21.22, 22.02, 22.20, 22.22, 23.22, 23.33
    i think that's all of them
  19. mauvecloud
    4 Nov 2008
    I found screenshots here: http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle005.html, and the puzzle says "the clock in this puzzle displays time on a 12-hour scale, not on military time". That definitely precludes 13:33 etc. (13:11 doesn't work because the digits have to be in a row), but it doesn't completely eliminate the possibility of a digital clock that shows hours 0-11.
  20. delriogw
    1 Aug 2007
    well everyone kept saying military time, but i stand corrected.
Tags: Add Tags
