Project "aevitas" Sick and tired of waiting!@
Discussion in 'Project Logs' started by aevitas, 5 Jun 2005.
  1. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    Do it any way YOU want to! I think it looks nice the way you did it now. But it's your case so make it the way you like it most. :thumb:
    bij mr.X trouwens veeeeeel acryl :D
  2. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    These images don't do it justice, but it looks like this to some effect:
    See how the letters look like they are pretty deep, and lit underneath the plexi. They aren't actually on the surface, but under it.
    Basically, the letters are lit, and then reflective plexi or w/e is in front of it. The plexi is a little in front of it, like 2-3mm maybe? The lit letters shine onto the plexi's back, and results in a cool effect.
  3. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    SMALL UPDATE 19-06-05
    I haven't had any time (material) to start on the sidepanel yet. I am going to pick up 2 pieces of plexi this thursday for a minor 3 euro :thumb:
    Also this is my orderlist for my WC stuff (and some mesh/plexi). It might change a bit but you'll get an idea of what I am going to use.
    Some tools I bought this week:
    My dremel Multipro is on order so I will have that within 2 weeks (they said lol)
    Anyway.. I also made the decision to wait for the Crossfire mobo + card. But I will order my x850xt/pe pci-e as soon as my new paycheck is in.
    Like I said.. I am going to pick up the plexi thursday so after that you can expect an update :naughty:
  4. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    nice stuff
    buying at freezinghardware eh
  5. aevitas
    6 Mar 2005
    It's been a while since I updated my thread. To be honest it's cause I was working allot and had other stuff to do. But I haven't been sitting still. I ordered my watercooling which arrived yesterday. The order came from FreezingHardware I ordered my sapphire ati x850xt/pe platinum pci-e thursday so I should get it tomorrow :naughty:
    Here are some pics of the watercooling:
    The Innovatek Cool-matic x850:
    The Eheim 1046, the mounting plate and the cover for the pump:
    The Black Ice Pro III radiator:
    The Innovatek Fass-o-matic reservoir, 7 colorLED and the mounting plate:
    Alphacool NexXxoS XP Bold:
    The barbs and 3 meters of black hose:
    I also got my dremel and it's a very cool machine :dremel: :
    I'm going to start on the sidepanel tomorrow cause I also got 2x AC Ryan clear plexi + 2x AC Ryan meshpanels :naughty:
    Get ready for allot of updates and more frequently also :dremel:
  6. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    Its always awesome to see new tools and awesome watercooling hardware! The case is very nice, a bit big for me, but nice anyway.
    Good luck with your mod.
  7. SteakTheMooCow
    SteakTheMooCow What's a Dremel?
    12 May 2005
    What model Dremel is that? Mine's a 395 but it goes up to 37,000 RPM?
    Is it possible the different country's voltage/amp ratings could make the dremel spin slower? (odd though?)
  8. aevitas
    6 Mar 2005
    Well a month or so has passed.. and I still don't have my videocard :wallbash:
    BUT don't worry.. it will be delivered today.. I got our dining room ready for everything.. I'll be spending the next week here allot and I'll try to keep updating the thread as much as possible..
    Here you can see all the hardware and my space I'm working on atm..
    I'll keep you informed.. I can FINALLY start.. phew :p
  9. kergareth
    kergareth Minimodder
    6 Jul 2004
    Cats are walking staticballs of death. At no time should they be allowed near components. Ever.
    Lizards on the other hand are static-less and look cooler (at least IMO).
    BTW this has the potential to be a very sweet mod.
  10. aevitas
    6 Mar 2005
    Oh yeah.. I went to work @ 17.45 and guess what got delivered @ 18.00 @ my house.. yes.. a present from god :D :D
    I'm quite busy these 2 weeks since I gotta arrange stuff for my new study (lawschool :p )
    I'll keep you guys informed and up to date as much as possible..
    aevi out (going to sleep after being awake for 30 hours :sigh: )
  11. Jipa
    5 Feb 2004
    Oh boy where do you get money to all that hardware :/ Drool that case, I hope you treat it nicely and make all mods with patience! Good luck with this one.
  12. aevitas
    6 Mar 2005
    I put my mobo + ram + soundcard in my case. Nothing more, because I have to wait for one barb for my pump because it was the wrong one.
    Here are some pictures:
    I removed my stock cooler from my videocard:
    Also I prepped the watercooling for tomorrow/day after.
    What i need to know is.. would this be a good loop for my watercooling? It's just an example, because nothing is in its right place atm.
    I'm hoping to start on my window and other stuff and to have my pc done around next week.
    greetz
  13. shinkaz
    shinkaz What's a Dremel?
    7 Aug 2005
    good job, great hardware :D
  14. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    Yeah, the hardware is uber, glhf on the case. Lookin' good.
    Welcome to the forums shinkaz.
    -Rob
  15. Franklin
    Franklin Minimodder
    24 Oct 2004
    Lian Li V-2000 is a very good choice aevitas :D
    The case looks big, but it isn't difficult to fill the entire case with hardware I can tell you. Good luck with your mod.
    Are you still looking for some plexi? Take a look at Coolcase or at bouwplastics
  16. Bluefan
    Bluefan test 123
    25 Feb 2005
    you forgot to order a zalman NB heatsink, this one is a noisy one :cooldude:
    Where did you get all the WC stuff? (welke winkel heb je genomen?)
  17. aevitas
    6 Mar 2005
    @ Franklin. Thnx man, I already have the plexi.. I ordered it at FreezingHardware and got one UVBlue and 2 Clear..
    Mayb we should meet and have a LAN with our LL's when yours and mine is done :D
    @ Bluefan. What do you mean with I forgot to order a zalman nb heatsink? I have the nexxos bold for my cpu.
    I ordered my WC gear at FreezingHardware also.
    @ all the others. I'm hoping my hdd's + ccfl's will come today.. I also ordered a large molding strip for my sidepanel cause I still haven't got any..
    Till next time (will be soon) :clap:
    aevi
  18. Bluefan
    Bluefan test 123
    25 Feb 2005
    I mean the little fan on the northbridge is noisy, is it going to be replaced by a silent one? :confused: (like the zalman I mentioned)
  19. Franklin
    Franklin Minimodder
    24 Oct 2004
    My pc will probably be on the Hektik festival in Eindhoven. ( 18-20 November )
  20. aevitas
    6 Mar 2005
    Today I received the last barb thinking I could continue putting the parts in but it's the wrong one.. :waah: so they are sending it tomorrow..
    I also got my fans for my radiator:
    But because I got the wrong barb again I can't continue.. I'll try doing some small stuff today..
    Till then, greetz
