Project Anima Mundi
Discussion in 'Project Logs' started by endscape, 6 Mar 2007.
  1. endscape
    endscape Minimodder
    28 Jul 2003
    I think I'm only going to paint the two pieces that hang the drives together, but I haven't really decided, I sort of like the whole clear deal.
  2. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    sweeet!
    I like how you sollved the I/O port situtation
  3. endscape
    endscape Minimodder
    28 Jul 2003
    or...
  4. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Plan b it looks like it will give more support to the panel and it will hide the fans from that angle.
  5. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    bb also looks much better. i like this, keep going.
  6. endscape
    endscape Minimodder
    28 Jul 2003
    Looks like B is the popular choice.
  7. Supra55
    10 Oct 2006
    Yup by 2 votes :D
  8. endscape
    endscape Minimodder
    28 Jul 2003
    A little foot work. For whatever reason this plexi just does NOT like to be flame polished. I think I'm going to have to break it apart and do it piece by piece to get some sort of a decent finish.
    Next thing I have to do is decide on a color scheme so I can start painting and lighting this thing. Should I go with black paint and white lighting like I planed with Oracle? Or maybe red paint with some red high lighting and white main lights? Some shade of gray for paint? Thoughts? Suggest paint color, pinstripe color, main lighting color, and highlighting color please.
  9. Supra55
    10 Oct 2006
    Well on the feet why don't you use a dremel finishiong abrasive buffs they work just as well to start the polsih THEN finish with the flame or just see Stuv's worklog.
    For the color maybe a black dye or so and then instead of using pinstripers use some masking tape and so to block of your pinstripe design and then use some bloody red acryl dye thats still somewhat see through. For the main color... IDK maybe red with some purple highlights?
  10. endscape
    endscape Minimodder
    28 Jul 2003
    I like the dye idea, I'll look into that.
    RE: polishing, for whatever reason this plexi burns and bubbles extremely fast. Like, one pass with the torch as opposed to the five or six I was getting with the other acrylic. I haven't figured out what I'm going to do yet, but I don't think its all that critical that I glass the feet, being as 99% of the time they'll be hidden and glowing like a friggin' Christmas tree.
  11. Supra55
    10 Oct 2006
    Glad I could help
  12. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Looks sweet! Love the thick acrylic plates :)
    Btw! How do you make those cool SketchUp computer-parts? Do you handmake em, or do you have a plug-in pack with it?
  13. endscape
    endscape Minimodder
    28 Jul 2003
    Go check out the sticky in the mod guide section, Jazzle's site has piles of pre made components.
  14. endscape
    endscape Minimodder
    28 Jul 2003
    Small update. Sorry about the pictures, my camera is at my new shop. Just worked on the feet a bit more, trying to get them to polish up better.
    And now for something a little different...
    Now do you notice the water between me and the lights? Nice night out on the water, right? Well considering I'm sitting on the top of a pickup, not so much. That pickup happens to be an F 350 with an 8 inch lift running on 40 inch tires, and there was enough water to pick us right up. Ended up drifting about 300 feet before we stopped moving. And yes, we got rescued by a man in a boat. So that was my Monday, how was yours?
    There will probably be one more update before I have to take a break for a while. I'm moving into a new 3000 square foot shop, so that's going to take up the majority of my time for the next few weeks. :bday: Any modders in the Bellingham, Washington area that need a place to work should get a hold of me, we can work something out.
  15. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    So wait.. the truck just floated out to sea..? I wouldn't think the tires would provide enough buoyancy to lift an F350. Damn.
    Have fun with your new shop, that's a nice bit of space to work with. I might be at Washington State University for a couple months this summer but unfortunately that's about 2 hours away.
  16. endscape
    endscape Minimodder
    28 Jul 2003
    There was a rather large flooded area that someone got stranded in, and we thought that we had enough weight and size to make it out to them. Turns out we were wrong. Apparently the water was moving fast enough that it just picked us up and washed us out into the middle of it (the whole thing was probably 800 feet wide). We probably could have swam out, but it was pitch black and freezing. My partner in crime's father happened to have a dingy near by, so he went and got that and came and got everyone. Meet a couple really nice young women, you really get to know someone when you're stuck on top of a pick up for 3 hours heh.
    We ended up pulling everyone out yesterday, in a dump truck :rock: There wasn't a chance in hell that SOB was floating anywhere haha.
  17. endscape
    endscape Minimodder
    28 Jul 2003
    Anyone see the mistake I made?
    LIGHT!
    So I'm thinking that I might frost the edges of the feet (yes, after I put in all those hours flame polishing them) to diffuse the light and spread it out a bit.
    Thoughts?
  18. endscape
    endscape Minimodder
    28 Jul 2003
    Fixed the backwards PSU issue, as well as added an additional expansion slot and made a couple other minor adjustments.
    E
  19. KlavKalashj
    KlavKalashj What's a Dremel?
    7 Sep 2006
    I really like this! Subscribed!
  20. endscape
    endscape Minimodder
    28 Jul 2003
    Thanks to nOObtard for the radiators!
    Updates incoming.
