Project AquaLight - updated [23-2-2007] FINISHED!!!
Discussion in 'Project Logs' started by ssR, 16 Aug 2006.
  1. itsjustacompaq
    itsjustacompaq Member
    7 Sep 2006
    i figured you probably knew what it was, working with carbon a lot. :D i just wrote that incase others didnt.
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I don't appreciate you guys stealing my CF case idea.... :nono: :miffed:
  3. ssR
    ssR Carbon God
    11 Aug 2006
    lol dude you cant really go and say "any1 who wants to make a CF case is copying my idea" its the same as saying that any1 building a wooden case is copying from greensabbath. as long as you got access to a specific material, why not use it? unless of course someone is stealing your ideas and clearly copying your own projects, that is a totally different case
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    come on update!!!!!!!!!!!!!!!!!!!
  5. ssR
    ssR Carbon God
    11 Aug 2006
    Well if you insist :)
    Its a small one though since i didnt have much time this week (much less than i expected anyway
    Well i got some work done on the project. First of all i finally got the LCD screen for the front bezel. i made a CF skin frame for it and installed it. The installation was quite a B@$%H but eventually i got a pretty tight fit. too bad ill get to lit it up only when i complete the assembly (dont worry i checked if it works before installing it)
    The LCD is a crystal-fontz-like 4x20 with blue backlighting and white characters
    I also installed both front and rear 120mm fans and began working on routing the wires (which is pretty damn hard since i never thought about it when working on the case) ill remember to plan everything through in my next project though
    Ye ye i know that thermaltake sticker is ugly, dont worry ill cover it. ye and i still need to sand the CF gril a bit to get rid of the mesh sticking out
    So from now and on its just taking care of all the loose ends and bring it to perfection
  6. hujambo_Bwana
    hujambo_Bwana New Member
    2 Aug 2006
    Nice SSR. V nice, A quick question, is the U-channel stuff you've got round the fan hole soft or hard? The stuff I have is quite hard and doesn't go into a nice circle like your does.
    Jimbo
  7. ssR
    ssR Carbon God
    11 Aug 2006
    the one on the pic is very soft i got it with the hexagon mesh when i ordered it from ebay. i also bought some c-strip from frozencpu, its made of plastic with small cuts all through it to make it easier to take tight corners
  8. arkadur
    arkadur New Member
    3 May 2005
    very nice screen ..
    you can put a circle perspex on the TT logo
    BTW, this is the finel screws ? or you will change them?
    keep up the good work :)
  9. hujambo_Bwana
    2 Aug 2006
    thanks SSR, I might have a look at ebay and frozencpu, about how much is it a meter? and is it easy to cut and form (the stuff I have isn't it's very strong).
    Jimbo
  10. tkdwarrior
    tkdwarrior New Member
    5 Jul 2006
    Aqualight is looking great :D
  11. DimaX
    DimaX New Member
    7 May 2005
    Very sexy looking case! ;) Keep it up man!
  12. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks everyone :)
    hujambo_Bwana: dont remember really how much was it i believe around 1.5$ per feet
    arkadur: im not sure yet about the screws, i might change them but the current ones dont look that bad either
    Another update for you guys, i took the panel home with me today to see if everything works (well mostly the LCD) and apparently it does!!
    Here are some pics of the bezel in action (Bulgin switches are not connected so no lights)
  13. itsjustacompaq
    7 Sep 2006
    its very clean and professional looking. good job! now get those bulgins working and get this thing done!
  14. DimaX
    DimaX New Member
    7 May 2005
    Oh! So neat!
  15. Noni
    Noni New Member
    8 Dec 2005
    Wow very nice. I think the front fan would look better without the mesh tho!
  16. tkdwarrior
    5 Jul 2006
    yeah, and fingers look better in pieces too ;)
    great work ssR, this looks tops.
    wide-angle performance of the vfd doesn't bother you?
  17. customh
    customh conflagration.
    22 Oct 2005
    Beautiful. Was it hard to cut the CF?
  18. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks everyone!
    tkdwarrior: it does bother me a bit actually, maybe if i knew the angle of the view at this screen was this small i would look for a different one. on another hand it costed me 5$ so i really cant complain :)
    customh: define hard :). it really depends on what tools you use to cut the carbon. with 0.7mm thickness it wasnt too hard i just went a few times over it with an exacto blade and snapped it then sanded it to the desired shape.
  19. Solaris
    Solaris New Member
    26 Apr 2006
    Absolutely beautiful :)
  20. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    Nice work, I like the colors and my favorite part of this case is probably the front plate thingy, with the 2 Bulgins in it. Looks pretty nice, keep up the good work.
