Scratch Build – In Progress Project "BEHEMOT"
Discussion in 'Project Logs' started by ThePunisher, 26 Feb 2021.
  1. ThePunisher
    ThePunisher Minimodder
    19 Jul 2016
    :D :D :D
    radziecki and Cheapskate like this.
  2. radziecki
    radziecki What's a Dremel?
    24 Mar 2006
    That's what she said! :grin:
    That's one hell of a radiator you've got there... as @Cheapskate suggested: watch out for those wires. I've seen the insulation running down molex cables back in the day when I was fiddling with the cables and messed up the wiring somehow.
  3. ThePunisher
    19 Jul 2016
    Dont worry. This fans will work on 400-500 rpm max so 5W is limit :)
  4. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Cats always love heat! ;)
  5. ThePunisher
    19 Jul 2016
    Ok, chasis is almost complete. I wait for barrow fittings.
    Kitty quality control :D [​IMG]
  6. ThePunisher
    19 Jul 2016
    MADPC and Cheapskate like this.
  7. alain-s
    alain-s Minimodder
    12 Jan 2011
    That is a lot of cooling power. You could almost got with passive cooling with all these radiators.
  8. Cheapskate
    13 May 2007
    Industrial as F!
    I'm usually not a fan of sturdy girls, but this one I'd take to the prom.
    The diagonal grill works great. If it wasn't for the cat, I'd say just paste wax the whole thing and leave the bare metal look.
    ThePunisher likes this.
  9. ThePunisher
    19 Jul 2016
    Thanks :D
    I really like this industrial design. Thats why I deicded to do my own copy of raijimtek eris Evo but better nad bigger :)
    But I dont like this color, black paint is absolutly necessary :)
  10. Datulab
    Datulab Human? AI? Robot?
    12 Feb 2021
    You'll need a crane to move this build once it's done:lol:
    Love how industrial everything looks. Not sure if you mentioned it somewhere, but will you be painting it in the end, or are you going for a metal look?
  11. ThePunisher
    19 Jul 2016
    New mobotray is here :)
    Gpu holder from bykski which I modified a little bit.
    I decided to do direct die for best possible colling performance.
    Shining like a star[​IMG]
    One D5 with rez, second on the bottom :)
    Hardware with fittings :) Looks cool for me :)
    It was my first bending so I think it wasnt bad :)
    More info soon :)
  12. Datulab
    12 Feb 2021
    Not just did you delid your shiny new CPU, you went ahead and lapped the die:jawdrop: How can you walk with balls that large?
    Also, those tubes look mighty fine, especially for doing it the first time!
    kim likes this.
  13. spigs_rex
    spigs_rex Minimodder
    1 Oct 2010
    oh darn that's some sexy pc building there. The ridiculousness of the 14 fans mounted to the radiators really made me smile. Lapping a die... you brave lol
    It looks so awesome.
  14. Cheapskate
    13 May 2007
    It's not the lapping that was scary, It's using super-sticky packing tape as a masking. That stuff could rip the components off.
    All that watercooling, and the board still has fans on it. :/ I bet they will be the loudest thing on the rig too.
    I/O on top, rig the exact height of the desk... I see more cat-proofing. :lol: He'll be pissed when he finds out you are getting rid of his heated perch.
  15. ThePunisher
    19 Jul 2016
    9x140 on mora
    8x140 on front radiator
    8x140 on back radiator
    4x120 on top
    2x120 on bottom
    31 fans inside :D
    spigs_rex likes this.
  16. Cheapskate
    13 May 2007
    ...all the fans.
    You should have went for double stack on the radiators. :lol:
  17. ThePunisher
    19 Jul 2016
    Attention, Attention! BEHEMOT is turned on! Please stay far from the monster!
    First test :) Delta C after 2h in blender 2.82 classrom is.... 3C! With two pumps on 3000 rpm and 850rpm fans. Amazing!
  18. Cheapskate
    13 May 2007
    I suspect the only thing getting hot is the power supply. :lol:
  19. ThePunisher
    19 Jul 2016
    Work in progress :)
  20. Datulab
    12 Feb 2021
    Impressive. Those tubing runs also look very gorgeous!
    I'm assuming you'll be adding sleeved cables soon?
