Project Big Foot Print 56k beware soon!!
Discussion in 'Project Logs' started by couzo, 16 Oct 2003.
  1. Conrad
    Conrad What's a Dremel?
    23 Jul 2003
    why not mount the mobo, gfx card etc in the case on the left and have the w/c stuff hidden behind the mobo tray, so only the tubes of the w/c setup are coming in to the other half, much more space and less hassle when it comes to changing things...
  2. couzo
    couzo What's a Dremel?
    26 Apr 2002
    That arrangement I could do but have decided to try this way. The beauty of this I can change it round at a later date!!
    right just ordered my new cooling bits, a thermochill 120.3 rad mmmmmm cool!! I will post pics of my progress tonight of the complete case. Then at the weekend I hope to get some windows and the rad install on the top of the case!! woohoo
  3. penski
    penski BodMod
    29 Aug 2002
    To logs we go :)
    Sorry about the earlier misunderstanding, dude - hope everything is cool :)
    *n
  4. couzo
    26 Apr 2002
    well I will let you off this time!!!!!!!!!!! No probs mate I am just glad my case has worked............so far!!
  5. couzo
    26 Apr 2002
    right the case is now complete (IE together) what do you think it looks great to me even if I do say so myself I am soooooo happy with it as you can tell
    Now on to modding it!! Altogether this case cost £80!!! bargin I think!!
    Hmm me thinks my cam lense is dirty, wonder what those blobs on the pics are if they are not??
  6. Fubar
    Fubar What's a Dremel?
    7 Oct 2003
    those two little windows in the case are screaming for some lcds...
  7. couzo
    26 Apr 2002
    where do you htik my Noritate LCD is going!!! :dremel:
    Got my 3x120mm grill today and hope to get my 120.3 rad tomorrow so should have time to put in on to the case this weekend!!
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Hey man, that's about to be some sweet case :D
  9. couzo
    26 Apr 2002
    very small update I know but the grills I needed to do the top for the rad did not arrive :sigh: so will have to put that on hold till next week.
    Here is the rad I will be using mmmmmmm size matters!! Or so I hear!!
    And here is my nice new blue Maze 4 gpu block. Note to Dangerden this packaging is the way to go compared to your all bubble bag :rock:
    Hope to add more substantial stuff soon
  10. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    With that thing in your case, you won't be hearing much of anything :p
  11. couzo
    26 Apr 2002
    I tested it with the fans (£ YSTECH 120mm) at 7v and it is very very quiet indeed and the cooling will be great!! :D
  12. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Those cases look awesome, and for the price... well... :jawdrop:
    They look so similar to the inside of my pc60, and yet cost about a third as much.
    Grr!
    Looking good mate, keep up the hard work :thumb:
  13. couzo
    26 Apr 2002
    and the odd thing was the day after I received them komplett had taken them off their site?? :confused:
  14. PTK
    PTK What's a Dremel?
    3 Nov 2003
    Even the mobo tray is worth more than that ;)
    :dremel:
    PTK
  15. couzo
    26 Apr 2002
    right could not wait till the weekend so tonight Icut the holes for my 120.3 rad here they are and I will be filling them down as I have just used a dremel on them so far and they look a bit ragged in the pics but that is just the tape I have on them enjoy!!
    You can't really see that well but all the holes and screw holes are in perfect positioning!! :rock:
  16. couzo
    26 Apr 2002
    finally got the rad on the top of the case looks great thats the tough bit over with a think!!
    That rad fitted perfectly into the top of the cooler case and the bleed hole is in a perfect position to do its job!!
  17. ReFredzRate
    2 Sep 2002
    Looks great, I really love the fangrilles! :clap:
  18. couzo
    26 Apr 2002
    thanks mate with the rad I had a slight rattle in it but last night I rinsed the rad through with some of my water and practiced using the bleed hole and it great and now the rattle has gone :D
  19. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Love those fan grills. Where'd ya get?
  20. couzo
    26 Apr 2002
    www.coolercases.co.uk the fan grills are £10 each and the first one I got was a triple version but it did not fit on the 120.3 rad so he replaced it with 3 of the singleones at the same price, top service I must say
