Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. Morphine
    Morphine weeee!
    23 Feb 2002
    People say that clearflex is the same as tygon, but it hasnt been this way at all in my experience. The ClearFlex tubing was not as flexible and pliable as tygon. My clearflex tubing also clouded up after a month of use, whereas with the same dye, and same additives, my tygon is going on strong 4 months later.
  2. Firehed
    15 Feb 2004
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I dislike barb fittings and have never used them in anything I put together (the reason I stick with small bore German stuff), but Aqua-Computer says there 10mm barb fittings will work with both 3/8"ID and 1/2"ID tubing.
  4. Firehed
    15 Feb 2004
    10mm/25.4(mm/in) = ~.39 in. Trust me, 10mm barbs in a 1/2"ID hose will be quite leaky. Even if it DOES work (ie they're measuring the ID of the barb or something, whereas I'm going with the assumed OD) there's no sense in taking the risk.
  5. modsquad
    27 Feb 2004
    I will take your word for it. As I said I don't use barb fittings. Do you have a source for the G1/4" to 12mm barb fittings this guy needs?
    I have monday/tuesday off work and will try to get some work done on project BN. I would like to get the Power Supply in and start wiring mock up.
  6. modsquad
    27 Feb 2004
    Small Update
    I had a few free hours and did some odds/ends.
    Cable sleeved/heatshrinked the wiring for the Aqua-Computer Aquaero VFD. I will need to paint the flow meter flat black.
    I also wanted to see how the mirrored acrylic would work out as the back-plate for the 5.25" bay area. I cut a 5.75"x11" piece to get an idea.
    Looks promising. I will need to get the DVD RW drive installed as well as the hard drives so I can "map-out" the holes needed for the HD's power and SATA connections to pass through. I also plan to have the above pictured flow meter behind the mirror (so two more holes for the tygon tubing). I did the EZ part, more to come...
  7. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    omg looks like you have another mobo back there!
    sweet.
    hey, what do you use to shrink your tubing? doesnt look very well shrunk IMO. get a heatgun, around 25-30 and you get 50x as good shrinking.
  8. [ShoNuff]
    [ShoNuff] Minimodder
    10 Sep 2004
    Have you thought much about how you are going to setup your cooling loop? Are you going to split two lines coming off of the exhaust such that your 6800u and your CPU get the coolest H2O? Your loop is bound to be complex given the flow meter. I decided to go with the AC flow meter but I have no idea how I'm going to incorporate it into my loop. :confused:
    Keep the pics comin'. I am looking forward to the flow meter painted black. Should work nicely into your case.
  9. modsquad
    27 Feb 2004
    deadly: I do have a heatgun, but the USB plastic plug wanted to start to melt.. Had to stop.
    ShoNuff: My plan for the h20 loop goes
    Res--pump--CPU block--GPU block--flow meter--radiator--res.
    Honestly, have not had time to really think about. Let me know how you decide to setup your's... Another week or so for your Aqua-Computer AquaStream pump ?? Let's hope.
  10. Fahrenheit 541
    Fahrenheit 541 What's a Dremel?
    8 Aug 2004
    clear acrylic
    that clear looks very cool, are you planning to use it anything else? :clap:
  11. Nexxo
    23 Oct 2001
    I have an in-line flowmeter which I just screwed into the res inlet (it has 3/8" BPS though, so the res needed adapting). If you don't know where to put it, I'd just put your flow meter as close to the res as possible.
    Project is still looking good! :thumb:
  12. Firehed
    15 Feb 2004
    SNT has those as well
    http://snt-systems.com/catalog/product_info.php?cPath=21_22_42&products_id=124
    That mirrored plate looks awesome by the way :D I was going to say you had better vinyl dye that meter or something, but I guess you've already got that covered by putting it behind the mirror plate.
    Also, I've used a heatgun on sleeving the USB stuff before... wasn't a problem for me. If it's dual heat go with low and hold it a way's away. At least that's what I do :thumb:
  13. modsquad
    27 Feb 2004
    Thanks Firehed. I am using a new batch of heatshrink, not sure if it's me or the heatshrink but it seems difficult to "shrink"...
  14. modsquad
    27 Feb 2004
    Small Set Back
    I want to work on the mirrored acrylic backing plate next, but when I begun to install my HD's it became apparent the 5.25" mounting brackets I had planned on using are not going to work. I found/ordered other mounting backets that will work (just came in today). I have to work tonight, but will get the HD's and DVD drive installed tomorrow as well as start working on the acrylic...
  15. modsquad
    27 Feb 2004
    Mirrored Acrylic Backing Plate
    The 5.25" hard drive mounting brackets I had planed on using interfere with the bolts holding the laser etched front panel as well as the Lian Li 5.25" bay blank plates. So I will be using these. They are made by C3 Clear Computer Case.
    I also installed the Plextor DVD Burner. I have not had the unit out of the box in about a month (I still like the Carbon Fiber look).
    On to the mirrored acrylic.. I cut a panel to fit under the DVD drive. As I stated in a previous post the Aqua-Computer H20 flow meter will be mounted behind the mirrored panel, so I drilled two holes for the tygon tubing to pass through. I then used two 16mm rubber grommets to finish it of. The panel also needed a notch to allow the wiring from the VFD as well as the other front panel wiring to escape into the case.
    I looped a length of tygon tube from one hole to the other just to get an idea of how it would end up looking.
    I still need to install the second hard drive and make up a mirrored panel for that area...Next...
  16. bozo
    bozo What's a Dremel?
    21 Oct 2003
    the plextors come like this stock? sweet!
  17. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    no they dont come like that stock
  18. modsquad
    27 Feb 2004
  19. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
  20. modsquad
    27 Feb 2004
    Sorry.. computer+beer=typing error..
    It is an interesting article..
