Project: Blackfire ~ Complete!
Discussion in 'Project Logs' started by Taedir, 11 May 2005.
  1. Taedir
    Taedir What's a Dremel?
    24 Feb 2005
    Hi! I'm new here, but I've been lurking for a while. I've had a worklog going for a while that you can see here Project:Blackfire
    So here's the problem. Do I finish the acrylic case or do I build the raidmax? I'm not getting the feedback at Gruntville so I was hoping you would give your opinions. Here are the choices:
    A.
    or B.
    All opinions are appreciated :D
  2. Txx
    Txx What's a Dremel?
    4 Feb 2004
    I think that the plexicase is mush more cool. Isn't possibol to fix the problem ?
  3. Taedir
    24 Feb 2005
    It is, and its not that hard. Plus, now that they've sent me replacement parts for what was defective its even more tempting. Its just been very frustrating.
  4. Firehed
    15 Feb 2004
    I like the plexi too.
  5. radek
    radek What's a Dremel?
    7 May 2005
    Plexi! Red plexi flames are... hot!
  6. Taedir
    24 Feb 2005
    Actually, UV orange. The effect is really nice with UV light.
  7. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Keep the Plexi. It looks absolutely amazing, and like you said, you've already got all the parts to finish it.
  8. OdDBaLL_MoD
    OdDBaLL_MoD Always planning something...
    13 Sep 2004
    I'm not a fan of Plexi cases, but damn, that case looks HOT!
  9. Taedir
    24 Feb 2005
    Pun intended :D
  10. Leinie
    Leinie What's a Dremel?
    4 May 2005
    That plexi case is just way to cool to stop. I think you should give it another go. Keep up the wicked cool work!
  11. Taedir
    24 Feb 2005
    Hey Leinie we live in the same state! What part are you from?
  12. Leinie
    4 May 2005
    South East Corner of the state, Waukesha - west of Milwaukee. You?
  13. Taedir
    24 Feb 2005
    Not very far, I'm in Kenosha.
  14. Leinie
    4 May 2005
    Small world, huh? :hehe:
    How is the quality of the replacement case they sent you?
  15. Taedir
    24 Feb 2005
    I haven't gotten home to inspect it yet, and I'm dying! Still got half an hour till I get off work, and ya, I'm working real hard :)
  16. bahgger
    bahgger Minimodder
    13 Apr 2005
    taedir i have a passing second cousin... his last wishes were to continue the plexi case... i think its for the best if you do that :)
  17. Firehed
    15 Feb 2004
    ^^ You're not serious are you?
    Just noticed this is topic 90000... kinda cool :D
  18. Taedir
    24 Feb 2005
    Well, I got a chance to check out the package from ACRyan tonight. I got two replacement UV ccfls, two blue UV sleeving kits and two replacement plexi panels. The panels are perfect! And they are the totally wrong panels! Instead of sending me the side panel, I got the two center panels that hold the drives! I can't say I'm surprised :duh:
  19. -Erik-
    -Erik- Guest
    You should try connecting the hdd activity led to some other leds and mount them into the orange flame plexi. So when ur pc hdd led is blinking and doing stuff, the flames light up ... What do you think?
    Finish A!!
    When those panels light up, its gonna be killer.
  20. Leinie
    4 May 2005
    What a bummer. Do they know you are letting everyone know what complete idiots they are? :wallbash: You should email them a link to this thread and the one on the other site. They should send you a brand new case!
    How bad are the panels? Can you make it work, or are they that bad?
