project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. piloux
    piloux What's a Dremel?
    12 Nov 2003
    EDIT: here is the official pics presentation made by bit-tech.net with pics supplied by Piloux himself ( :thumb: ) to show the advancement of the project in an easy to follow format: http://bit-tech.net/feature/44/1/
    enjoy it and don't forget clicking through the whole thread to see latest updates:)
    Hi guys, here I go again with a new project log :D
    Long time ago I had the idea to build a Half life lan pc but never had good enough idea to start working on it... well the imminent coming out Half life ² gave me some good inspiration.
    I had some parts and stuff to my disposal to start the project then lets go guys :)
    for now , 2 things are sure :
    -full time damage paintjob (to remind the Blackmesa atmosphere )
    -green uv react watercooling ( to remind toxic liquid)
    here is the stuff I have :
    - watercooling : wb derfone, mj 1000, copper rad from nissan micra
    -2 enremax 120mm
    -2 enermax 80mm
    -1 120 mm
    -2 ccfl uv 10 cm
    -1 ccfl uv 30 cm
    -1 psu 250w
    - actima dvd drive 10 x
    - sony crx 1611 16x/10x/40x
    - différents acrylic stuffs
    - different aluminium stuffs
    here are some pics of everything :
    In this wallpaper you can have an idea how I want the case lokks like :)
    well , after differents search I found this sort of paint to simulate the rustiness of steel
    I try differents ways...
    (Ck)Vegeta likes this.
  2. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Niiice. Looks like you are off to a good start. :thumb:
    Oh, what kind of flat panel monitor is that back there? That Aluminum looking one. :rock:
  3. piloux
    12 Nov 2003
    you can see the differents area I have paint :
    - yellow : primer paint
    - green the result with the oxidant paint
    - red the copper
    - blue copper with steel base color
    you can see the grain due to the steel base paint
    the copper I paint with a brush
    the effect is very different according to the laps time between the 2 different paints
    finally I m going to paint it with the last effect
    thenn I paint the dvd drive :
    steel base paint and 2 coats with the oxidant :
    the same work with the frame :
  4. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    the drives look schweet!
  5. piloux
    12 Nov 2003
    thank you ;)
    this is not a flat panel monitor , it s just an acrylic side panel with a cut aluminium window I made for another case I builded
  6. piloux
    12 Nov 2003
    yes , the rustiness color is more yellow because of the flash but in reality it is really good rust effect
  7. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    It's not my style, but neither is that sweet black/transparent thing you built ;) I bet you can make it look pretty sweeeeeeet!!!
  8. piloux
    12 Nov 2003
    I hope so :D
    this is a really different style, but it is according with the theme :thumb:
  9. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    Wow, simply wow.
    The drive looks amazing, you can be assured that ill be watching this piece.
  10. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    VERY NICE, good job on the drives. its gonna take a while but this is gonna look awesome, good luck! :thumb:
  11. Zilly
    Zilly What's a Dremel?
    23 Dec 2003
    I really, really like the look!
    Can't wait to see how it all turns out!
  12. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Your rust effect is GREAT! :eeek: :rock:
    Looking forward to seeing the rest.
  13. TheOnlyAndromeda
    TheOnlyAndromeda Duh, what's a dremel?
    9 Jun 2003
    Oh wow I am religious or I would use another word
    I am going to watch this.
    Darn it you stole my idea.
    I was just about to do the same thing
  14. Le Tordu
    Le Tordu What's a Dremel?
    16 Jan 2004
    Yeah, Piloux's back !! :rock:
    Your rustiness look (-and-feel ?) is quite amazing ! :thumb: Will the case be totally "yellow" as the wallpaper is or will you use other colors ? Maybe a "standard red" rustiness effect on the radioactive tubes :naughty:
    En tout cas, bonne chance ! :lol:
  15. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    I like. I like a lot! Nice to see another piece of art coming up! :thumb:
    PS can I have a close up of the waterblock? Doesn't look familiar, what is it?
  16. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Oooow another project log from my m8 Piloux ;)
    The drive looks astonishing just perfect :jawdrop: !! I love it :D
    Cant wait to see more, but by my guesses this one is going to be as good as the previous case (if not even better :geek:)
    Ow and do you mind telling me what kind of paints u use, I might consider this effect on my next project. :dremel:
  17. piloux
    12 Nov 2003
    well, the case will be totally rusty but I ll make some orange UV reactive plexi pieces to give it the look :D
  18. piloux
    12 Nov 2003
    of course here it is :
    this is a Derfone's block, a french guy who sell some good stuff on the nokytech.net forum, I like his job :)
  19. piloux
    12 Nov 2003
    hi resetter ;) here is the paint I use :
    this is Instant Iron base coat and instant rust antquing solution, the label is "modern options" I think it is a french product
  20. Darv
    Darv Bling!!
    12 Aug 2002
    Wow :jawdrop: I've always liked the idea of a rust scheme paint job but never thought it would look too good.
    You've proved me wrong! Keep up the good work :thumb:
