PROJECT : Blueize
Discussion in 'Project Logs' started by Father-Time, 1 Mar 2004.
  1. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    Latest Update.
    Pictures of the case
    The board has now gone in, here it is.
    A picture from the back with the pump visible from its out of the case support that i made fit!
    And now a few close ups of the etching i have done, it is a little risque, but i like it a lot!!
    Thats it for now, still awaiting the tubing, got a few other different ideas too.
    FT
  2. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    damn man that loooks soooo sweet.
    I love your dual linux server :D I Would watercool that baby:)
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    Looking great!
    But what is that daughterboard between the I/O Panel and CPU for?
  4. mclean007
    mclean007 Officious Bystander
    22 May 2003
    :nono: RTFT man! :D It's Gigabyte's dual power board - secondary power regulation or something like that, supposed to give cleaner power to components.
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    :blush: sorry, didn't see that.
  6. Father-Time
    23 Feb 2004
    Water installed, no leaks been tested for 24 hours. 8)
    System had just completed winxp pro install.
    Ambient temp at the moment (CPU) is 19c and running pipes screensaver 22c.
    So i am one happy pappy!!!
  7. Father-Time
    23 Feb 2004
    Project Blueize **Updated**
    **Latest Update**
    This where i placed the pump, capable of 1200litres per hour.
    Still need to do some wire management!
    These are with the water in.
    Not really sure why the UV Dye shows up as green when the normal light is on, when the room is in darkness it shows up BLUE as you can see.
    **Left to do**
    Just the main side window, which will be smoked plexi, no etching.
    FT
  8. acidbrain
    acidbrain What's a Dremel?
    13 Mar 2004
    Nice work so far, looks good!
    How did you make the etching? Looks really l33t!
    Put some LEDs in the Plexi to light up the etching, so no one walks by without noticing ;)
  9. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Can't see pictures, is your hosting having problems?
  10. BlueMax
    BlueMax What's a Dremel?
    23 Mar 2003
    they work fine for me! looks good
  11. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Looks really good bro! :thumb: However, I may have read over this, but why aren't you fitting your pump inside the case? :eyebrow:
  12. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    Ya it looks like u would have more than enuff room in that big case. :hehe:
  13. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    damn thats looking f*cking sweet. Keep it up man :D
  14. Father-Time
    23 Feb 2004
    Yo-DUH_87 : Pics should be ok buddy.
    acidbrain : Etching is done by a computer at school, i produce the graphic, iy etches, cheating i know but when you lack talent you have to make do. :hehe:
    ReFredzRate : I like to have as much space as possible inside the case, i like clean looking, so putting the pump outside game me a lot more space. I dont think there is any detriment to the system, but i quite like the origianlity of it :clap:
    Xgamer : Agrred - See above :hip:
    Thanks for all the comments, that what keeps me going in the dark hours, and there are plenty of those : :wallbash:
    Thanks All
    FT
  15. Yo-DUH_87
    6 Mar 2002
    Hrm, my connection must have been throwing me a boner. Fine now :wallbash:
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    :lol:
