Project F.E.A.R.
Discussion in 'Article Discussion' started by The_Pope, 9 Jun 2005.
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  2. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    couple errors in the article on the first page:
    http://www.bit-tech.net/modding/2005/06/09/project_fear/1.html
    1st page, doesnt start untill after the ads on the right stop using IE, just a whole lotta white space.
    also in the first paragraph:
    that EURL thing looks like a bit of code that isnt right.
    Nifty case BTW
  3. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I don't belive
    Code:
     [eurl=www.whatisfear.com/us/]scariest trailers[/eurl]
    is a valid web language.
    edit:
    gerrrr sadffff you type to fast
  4. Tim S
    Tim S OG
    8 Nov 2001
    that is part of the language that we use to input articles in to the engine - easier than html. I don't know how that wasn't picked up on, but it is fixed now.
    The IE bug is also fixed for that page.... it is a strange one that crops up randomly
  5. M_D_K
    M_D_K Modder
    3 Apr 2002
    heh looks like a good game, shame you've covered all the ventilation holes at the fornt of the case :p
    morgan.
  6. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    It looks nice and all but it still kind of dissappoints me that when bit-tech are commissioned to 'mod' a case they seam to just stick a sticker on it. Where the true modding in that? :(
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Exactly my thoughts too.
    Custom Mod... just slap a sticker on it. That'll be £# please...
  8. Guest-16
    Guest-16 Guest
    Well the thing is we have a different idea and time scale to modding than these companies. A proper mod with true innovation takes a LOT of time, anyone on here knows that - mostly in the planning and then having the materials and time and expertise to do it. The problem is these companies want a mod and they want it done yesterday, which is why Geoff said through the article a few times about the constraints he was under and why he needed the post to get to him quickly, or he reused dimentions.
  9. TMM
    TMM Modder
    12 Jan 2004
    It looks nice but........... ventilation? :worried:
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Maybe these should be labeled as 'Corperate Mods' then.
  11. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    So surley its better to turn down the offer than to just slap a sticker on there. I mean yeah we all know about the time/money/skill required for a half descent mod, but its just wrong....How can a website so renowned for modding resort to using stickers? And if this can stress the latest hardware, why is the system being suffocated :worried:
  12. The_Pope
    3 Jul 2003
    Trust me - we explored several options, and with limited time AND limited budget, the CaseSkin route was the only real option.
    For example, everything had to be approved by the Product Manager at Vivendi, who has more on his plate than discuss designs with me all damn day. It took the best part of two entire weeks to get the Photoshop layouts to the point where they were happy, so I make no apologies for it not being Orac tbh.
    As for ventilation, I left it to the magazine boys depending on what sort of system they put into it. The PC-61 will draw air under the front lip at the bottom of the bezel, so it isn't reliant on those front holes per se. Indeed, there is a fairly restrictive filter on those front vents, so the normal airflow is less than you'd think.
    The other reason I didn't go ahead and punch 200-odd holes in the front of my otherwise clean case is my past experience from Project Synapse: http://www.bit-tech.net/modding/2004/09/21/project_synapse/3.html
    As I mentioned in my Worklog, the CaseSkin vinyl really doesn't like fine detail, and cutting those tiny airholes throws up enormous challenges to get it to look decent. So the best solution was to leave them intact for the magazine photography, and if they install something super high-end in it, then can always open them up. Ditto the top 80mm
  13. The_Pope
    3 Jul 2003
    Wow - I'm certainly not going to sit here all night defending this project. I'm amused that several of you are so quick to dismiss CaseSkins as merely "stickers" - they are a hugely versatile medium, are relatively low cost and unless y'all have a PHD in airbrushing, produce a better result in a weekend than many people could manage in 10 times the time.
    There's no law that says every bit-tech mod has to be Orac-level stuff: anyone got a spare 9 months and $x000? We cater for EVERY modder, from the newbie who stil getsl excited by making a, blowhole 4 years after we cut our first, right up to the G-gnomes and Eddie the Danes.
    The bottom line is that this mod was barely 24 hours from CaseSkin delivery to couriering the final product to the magazine, including photography in order to bring you guys something new to read. I'm happy with the end result, and so are Vivendi, which is what is important.
    So take it easy fellas
  14. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Man, you people are being brutal to this just because its not a traditional style mod? Give it a rest; this is an awesome case, with great visuals; it actually does take talent to get measurements right with that kind of stuff, design things to work properly, and to take into account absolutely everything necessary; you did great job :thumb:
  15. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    If you think 'slapping a sticker on' is all it takes you need to appreciate a little more about design before you make such a sweeping statement. As an example I spent longer on the graphical design element of the synapse skin than some people have on entire mods for their cases.
    It's not all about cutting holes and spraying custom formed plastic bolt-ons.
  16. The_Pope
    3 Jul 2003
    Thank you Roto - appreciated
    Everyone else: you're off my Christmas card list :p
    Kna: down boy! ;)
  17. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    I really like how the case turned out - especially considering the time limit it was under with the final judgement being called by someone who probably just wants it done and not as a piece of art.
    Off question: How would you describe the quality of the black of the skin in relation to the reflection it shows? I am thinking about changing the back end of laptop to piano black but, instead of trying to paint and void my warranty, that I could maybe apply a skin to emulate the effect. To rephrase my question, how does look of the black on the skin compare to a piano?
  18. Firehed
    15 Feb 2004
    Well I for one think it was very well done. Even merely applying the skins is tricky to do without air bubbling it to death. I personally like the art that Vivendi through out more, but it is their case.
  19. Guest-16
    Guest-16 Guest
    I defended you :waah:
    As for ventilation - you lot have never used an acrylic case then? Even with airflow it's like an oven and stuff still works perfectly fine.
  20. Nexxo
    23 Oct 2001
    All mods are worthy. OK? :grr:
    Now let's get back to modding.
Tags: Add Tags
