Scratch Build – In Progress Project: FrozenCPU: Billet Pron Bench; Sponsored by CORSAIR
Discussion in 'Project Logs' started by mnpctech, 18 Jan 2013.
  1. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    The thing I like about that kind of work is that you can at least see tangible progress. But it is a lot of the same lol
    What you need is an intern to do that for you :p
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    @Mos, are you hinting at something? :dremel:
    @Waynio, I understand and just wish I had more time to savor the moment :D
    I received the shell for Actuator's LAC control pcb box from firgelli, it's perfect for our Tech Station, it's aluminum with Black plastic end caps, 57mm x 57mm x 26mm, $12 each from their store
  3. Mosquito
    24 Mar 2011
    I think I'll stick with my software dev, I'm probably better at that than modding :lol:
    Looks like the controller box should fit in nicely.
  4. bulldogjeff
    2 Mar 2010
    This just gets better and better, I love all the parts and the overall look. I wouldn't fancy carrying it around though..
    Top modding Bill. I can't wait to see it all come together.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Once this is finished, I think you'll need to build one of these for the workshop. :D
  6. mnpctech
    21 Apr 2003
    @Mos, I've told landlord that I'm looking for bigger shop space... :dremel:
    @jeff, thank you! it's not that heavy tho, but haven't finished top yet :worried:
    @I&W, def need bigger shop if i get that :D
    I've been editing videos mostly this week, I took a mental break yesterday to install our machined alum case feet onto the Tech Station.
    Frozen retails Mnpctech's Aluminum "Grooved" Case Feet here,
    http://www.frozencpu...d_-_Silver.html
  7. Asouter
    Asouter --------
    18 Jan 2012
    That's just blatant marketing :hehe: They suit the build really well though. Looking really good and looking forward to seeing it assembled
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    It bugs the hell out of me that they go out over the chamfer on the bottom:D
  9. Cheapskate
    13 May 2007
    Me too.:worried:
    In my defense; they had to be moved out that far for the optical, and I thought the bevel on the feet would line up. It does, sort of.
  10. Azariel
    Azariel Minimodder
    23 Oct 2008
    Maybe bevel the top edge of the feet to match the beveled edge of the case...
    Anyway, they indeed look made for this case :) Stunning!
  11. avolla
    avolla Mini Water Modder
    26 May 2010
    It wouldn't take much to take a little off the top of the feet to have it meet up with the chamfer you have on the case. Just an idea. Looks great.
  12. Joshcowin
    Joshcowin What's a Dremel?
    7 Jan 2013
    wow just wow only just found this.subbed
  13. Guest-23315
    Guest-23315 Guest
    I thought that was just my OCD kicking in :lol:
  14. mnpctech
    21 Apr 2003
    I noticed that too, on the que for our new OKUMA CNC Lathe!
    Got the final two pieces finished last night, so today I'm going in early to start assembly of the cover, Yay! Yesterday I took these photos of the motherboard tray.
    Any interest in Mnpctech offering ATX version motherboard tray & I/O for Scratch Builders?
  15. Mosquito
    24 Mar 2011
    That looks sweet. Now just need to get the power cables run to the back of the board instead :lol:
    Depending on the price, I may be interested, but it would have to be "down the road"... I've been using the Lian-Li replacement motherboard/IO plates for my scratch builds.
  16. Cheapskate
    13 May 2007
    @Mosquito - With a 3/4" gap under the motherboard, I figure even hoses could sneak under into those 4 holes. -Should make cable management a breeze.
  17. mnpctech
    21 Apr 2003
    Yep, these risers make it muuuch easier.... You know where to find me, Mos :D
  18. Unicorn
    25 Jul 2006
    1) I love this. Who wouldn't?! :D Epic work as always Bill, keep up the awesome work! Subscribed :)
    2) Yes :thumb:
  19. Mosquito
    24 Mar 2011
    I meant attach the cables themselves to the back of the motherboard, similar to what riekmaharg2 did with the panel cables in Blue Horizon
    http://forums.bit-tech.net/showpost.php?p=2795565&postcount=319
    You're a bad influence! (good?)... My checkbook hates you :)
  20. avolla
    26 May 2010
    Just think of it as stimulating the economy one mod at a time.
