Project: GEARED UP. More tinkering! 10/3.
Discussion in 'Project Logs' started by grumblemarc, 20 Mar 2005.
  1. ginx
    ginx What's a Dremel?
    1 Sep 2004
    Wow this is coming along nicely. It's VERY clean and I like that. Keep up the good work mate!
  2. Bak Modder
    Bak Modder What's a Dremel?
    21 Dec 2004
    This mod is totally awesome dude :thumb: :thumb:
    The idea of gears on the side of the case was floating in my mind for about half a year, but I totally drop the idea now, caus this mod is impossible to exceed. Very very nice, I totally love this one :clap:
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  4. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    just what i said by my first message Pwnage and omg good good job!!! :rock: :rock:
  5. grumblemarc
    grumblemarc What's a Dremel?
    12 Dec 2004
    I saw that. I thought something like that would be hard to get at being recessed in the case like that. But I did buy the fan controller from you guys. :D
  6. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    Wow the gear idea is an extremely good one. I am going to follow this log now(know its a lil late... but... better than never)
  7. grumblemarc
    12 Dec 2004
    Still waiting.
    Well I'm STILL waiting on the neon rings to get here.
    So in the mad dash to try to keep this project on the front
    page I decided to get to other things. I'm really getting
    anxious about the neon rings getting here so in the
    meantime I went ahead and ordered a couple of these.
    Radio neon accent lighting tubes.^^^
    Here's what it looks like installed in your car.^^^
    No I don't have any installed in mine.
    Ripping it out of the package and promptly cutting
    wire to pieces you get this.^^^
    I chucked the cigarette lighter and spliced a molex
    connector onto the end of it (which of course you don't
    see because I'm always in too much of a rush to take
    more pics). I opened up the casing for the electronics
    to see if maybe the sound activated components and the
    inverter might be seperate but no such luck. I left the
    thing in the "FULL" and the "MAX" positions and the whole
    thing gets stuffed into the bottom of the case for now.^^^
    Here's where I installed it.^^^
    These are cool because, they run on 12V, install with
    double sided tape so no cutting into the case is necessary,
    they're covered with smoke tinted acrylic so the lighting
    effect isn't so bright and the wire was the PERFECT size
    to route through one of the tiny holes in the case front.
    Now I said I bought 2 of these. The other one?
    Is DEAD!!! Thank GOD it only cost a few bucks. So I ordered
    a couple more. The 2nd one was/is going to go in the spot just
    above the front USB ports and the case badge. That's it for now.
    Going to do some cardboard mock-ups of the inner cases
    acrylic pieces I plan on installing.
  8. ginx
    1 Sep 2004
    This thing is still looking good, though I'm not sure if I like that little radio light on the front bezel. Maybe if I see a shot of it from a little more distance or something? Not sure, but anywho still good work.
  9. grumblemarc
    12 Dec 2004
    It does look odd without it's mate on the bottom part
    of the case. It unbalances the whole front. But the
    thing is, if it winds up not looking good at all I can
    peel it right off! Maybe use it on the underside of the
    case. Hmmm....
  10. Pitbull
    20 Mar 2005
    nice idea dude
  11. ginx
    1 Sep 2004
    That is a really good idea, to use it on the bottom, in the front and one in the back. It would probably look better there than on the front.. iunno.. just my 2 cents :D
  12. mnpctech
    21 Apr 2003
    nice touch :cooldude:
  13. grumblemarc
    12 Dec 2004
    Well I just got an email stating that my Luminglas was
    on backorder and will ship out later next week. :wallbash:
    It's really starting to get annoying.
    Meanwhile my neons finally got here and I got them all
    wired up and mounted.
    It finally balances out the front's top and bottom.^^^
    I think I'll keep them there for now.
    So what do I do until the 'glas gets here?
    I have to plan a way to mount this...
    ...in this location.
    It's a 4" LCD (formally optional now standard equipment)
    that I got off a member of another forum I frequent.
    I powered it up, hooked it up to the S-video out on my 9800
    and it works excellent (pics later). The resolution is very
    low on it but for what I have mind it's perfect.
    The problem with the mounting is going to be the depth
    of the LCD. With the PCB attached it's nearly 1 1/4"
    (apx. 30mm) deep. Half that with the 2 seperated which
    may give me the option of remote mounting the PCB in
    another location IF I dare to extend the wires in the
    ribbon cable. I may even swap locations with the
    Crystalfontz LCD since it's mounting depth is much less.
    I would LOVE to have a graphical LCD instead but the
    Crystalfontz has to stay if I want to keep the wife
    speaking to me.
    I'll have more pics of the LCD up later. I'm shopping for
    a Nikon D70/D100 so I can take better pics. I'm stuck with
    the wifes 2.3 megapixel Canon for now. I use the D100
    at work and it's a must have item. If I can wait a few
    months that could be my NEW birthday present.
  14. Novakog
    Novakog What's a Dremel?
    17 Mar 2004
    While I love this mod (see previous posts in this thread by me), I will be completely honest. I think having both the neon and two LCDs on the front and the fan controller will be way too busy, in fact I think I would probably not have the neon lights, and only one LCD, and the fan controller.
    But, this could be just me, and obviously it's your case, so do whatever the hell you want! :p
  15. grumblemarc
    12 Dec 2004
    You may very well be right about 2 LCD's. I may
    well just have to take the heat from the wife. I have
    an alternate plan on mounting the USB LCD inside the
    case. It won't be seen much in that location but it
    may satisfy my better half.
    The jury's still out on the neon. Right now
    I'm lovin' it just because I got it done. After a while
    I'll probably rip them right off. I don't know. This
    seems to be one of those love-it-or-hate-it kinda mods.
    I'm just going to let them sit there a while and see.
    I just thought that the neon ring element on the
    side would tie in nicely with the ones up front.
    Truth be told I'm not sure that the Luminglas mod
    wouldn't be a little too much for the overall look
    of the case.
    I still have a few things going that might just
    unifiy everything I have done/am going to do.
  16. infered101
    infered101 Minimodder
    30 Oct 2004
    My suggestion is to mount those light things inside the case. I just think that i would look better. It would also dull them by having the metal cover portions of them. I'm not sure though as im not sitting in front of the case.
  17. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    on the pic of the whole front of the case, your USB, Audio and FIrewire ports seem to be lit up blue. is that back lighting from the fan or just a reflection from the neon on above them? i was thinking of trying to back light my ports white, but was having trouble finding the best way of doing it...
  18. grumblemarc
    12 Dec 2004
    They really aren't that bright. They're encased in smoked acrylic. They probably look that way because I had the aperature and shutter speed set up screwy.
    The ports are being lit slightly by the neon.
  19. grumblemarc
    12 Dec 2004
    I've been getting a ton of PM's regarding the purchase of the
    Luminglas that I plan on using in this mod (eventually). I bought
    the first one off of eBay for about $17.50 and some shipping.
    The second one (which I am STILL waiting for) was about $24.99.
    In both cases the shipping was about $10US.
    The MAIN question seems to be
    "How much would it cost to ship to ????".
    ???? being the given country of the person requesting the information.
    As much as I would like to help I have not a CLUE how much
    shipping would be to any given country outside of the US.
    Failing that I have compiled a quick and short list on where
    these things are available for purchase.
    for eBay try this.
    http://search.ebay.com/luminglas_W0QQfromZR40QQsojsZ1
    The sellers I bought those from don't seem to be selling
    these anymore and the availability on eBay seems to be
    dwindling.
    These are also these places. One of which I believe is in
    Australia.
    http://www.coolstuffcheap.com/plasbal1.html
    http://shop.store.yahoo.com/rainbowsymphony/lupllidiorus.html
    http://www.cyi.net/category.cfm?button1=Lighting&cat=a&urli=category
    http://www.amazon.com/exec/obidos/tg/detail/-/B00069IQXI/002-1542160-9170445?v=glance
    http://cheapnovelty.com/luminglas.html
    http://www.infinitygc.com.au/shop/prod271.htm
    http://www.shoplifestyleonline.com/cy861.html
    http://pridenation.com/cdpride/partytoys.htm
    There are more but like I said this was quick and dirty. I have
    found that the smaller Luminglas is extremely harder to find.
    Hope this helps.
  20. Immy
    Immy What's a Dremel?
    13 Nov 2003
    I love the Neon lights i dont think its too busy at all. :thumb: mod on :dremel:
