Project H-Bomb Working LCD pics added 9/12/02
Discussion in 'Project Logs' started by Hiren, 20 Aug 2002.
  1. Hiren
    Hiren mind control Moderator
    15 May 2002
    PROJECT H-BOMB
    This is my first attempt and both building a PC and modding a case. Below is what I started with:
    It was my P3 550mhz system which I had for around 2 years. This is what I ended up with:
    I painted the case using Odd's N Ends fast drying enamel although you can't tell from the pics is supposed to be metalitic blue. The transfer panel is from maplins electronics and the biohazard case badge is from Overclockingstore.co.uk. The PC / case still isn't finished as I have started to put rounded (blue of course) cables in to tidy the inside:
    I am planning on mounting an external LCD box, a new graphics card and possibly a window and some cathodes.
    Well there you have it, the case isn't finished but I'm pleased with the results so far. For more info about the PC / case can be found here including more pics!
    H-Bomb website
  2. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
    Thats a nice first bit of work!! Definitely needs a window, get to it!! :D
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    paint the drives :) then do a top window :)
  4. George
    George Bah
    14 May 2002
    and paint the grey button black.
    and nice work mate. :)
    .icecube
  5. dukebox_1st
    dukebox_1st What's a Dremel?
    26 Apr 2002
    nice work, gotta love the 'go faster' strip! weird case looks like its in 2 sections, nice job but def paint the drives!
    tom
  6. m00min
    m00min What's a Dremel?
    6 Jul 2002
    whats with all the usb extenders?
  7. Hiren
    15 May 2002
    mrhaz - Thanks, I am thinking about a window the only problem is as you can see from the first pic my case sits in a little custom made cabinet the only part of the case you can see is the front.
    Lazy - I planning on painting the drives silver although as I've never painted drives before I'm hesisant. Also being white they match the rest of the case.
    icecube - Yeah the button was supposed to be silver but my cousin forgot to bring the paint round :sigh: so i had to leave it that nasty grey color :( . Now that you mention it black would look better thank's for the idea mate! :D
    dukebox_1st - The case is some generic one. It's actually quite wide because the PSU and CPU sit next to each other. The case does look a bit werid though. The racing strip was my dads idea when I asked him for some tape to tape off the button he said instead of painting it one colour why not put some sort of design on it. At the time I was playing GT3: A Spec so I took insperation from the Dodge Viper and stuck on a racing strip. :lol:
    Here are some more pics for you all:
    As you can see I've still not manage to figure out how to hook up the front status LEDs properly or the reset switch.
  8. Hiren
    15 May 2002
    m00min - The motherboard came with 8 usb (4x 1.1 and 4x 2.0) ports so I just put them in even though I only need one (for my mouse).:lol:
  9. m00min
    6 Jul 2002
    lol, case looks uber btw
  10. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    nice werk.. as everyone tells me, needs some cabling tidiadge.. :) i still havn't fixed mine, but im hella lazy.. :D
    -scoob8000
  11. Hiren
    15 May 2002
    scoob8000 - As you can see from the pics the inside of my case is a complete nightmare to work with. That's why I'm going to be putting in rounded cables to tidy everything up. I'm also considering replacing the heat sink and fan as they make way too much noise and in a months time this rig will be in my room at uni so I'm looking at quieter options.
  12. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    looks nice man. i think that that case is weird lookin, also i dont like the one piece cover that they have. at some point in the future i'm going to be modding one of those, should be interesting.
  13. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    looks very nice so far. i like the white strip . cant wait to see what mods you come up with next. keep up the good work
  14. Hiren
    15 May 2002
    VadimtheConqueror - I agree with you about the covering. I hate it as everytime I need to do anything on the inside the whole cover has to come off and their are horrible when you try and put them on. Also the case is quiet wide, not really sure why. :idea:
    Ron Weasley - Thanks I've still got a few ideas but the next sort of mod after the cables will be an externally mounted LCD.
  15. VadimtheConqueror
    10 Jul 2002
    ya, that's part of the reason i dont like helping my sister with her computer. if she lets me mod it, i might see if i can find a way to convert it to panels instead of one piece(have no idea how, of course, but i'd figure something out)
  16. Hiren
    15 May 2002
    I suppose it might be possible to cut a very large hole in one side (as if to put a window in) and then mount a door of some kind. So it would swing open and let you work on the inside?
  17. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    -H-: Case is looking sharp!
    For the side panel thing, I had the same problem with my old case. I ended up cutting a side panel by cutting a straight line and adding some thin molding over the cut. Then it couldn't cut me and fit back together nicely. Only problem is you need to make sure that the new side panel has clips on the front and bottom to hold it in place. Probably the most useful mod I'd ever done. :D
  18. Hiren
    15 May 2002
    Deviate - got any pics? sounds like a very useful mod. :idea:
  19. Deviate
    3 Jun 2002
    Not any good ones. This is about the best one I have of it and it's not that great, actually it sux!
    But you can see where I made my cut and then put the molding over the edge. I used car door molding, but I'm sure you could find some pvc molding that would be even smaller.
  20. tk421
    tk421 Idiot.
    15 Jan 2002
    how about cutting a monster window, like leaving a 1 inch border all around on the normal "opening panel" side, then puttin an acrylic piano-type hinge along the top? so you chould just swing it open , etc ...
