Case Mod - In Progress Project 'HourGlass' (99% done. Stably running :D)
Discussion in 'Project Logs' started by flare, 20 Sep 2008.
  1. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    I would have to concur and say B as well, overall better look to it. :lol:
  2. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    definitely B !!
  3. flare
    flare What's a Dremel?
    29 May 2008
    :D I have a small bit of good news for you all.
    Aqua Cooled PC have said they will sponsor the project!! Here is their banner that has been added to the main page:
    Click here to go to their website :)
    Thanks a lot Gary :D
  4. flare
    29 May 2008
    Just another small update today before I go and pick up some sand paper so I can finish of the bezel and side panels .
    My lighting stuff came :D along with some speakers :thumb: :
    Next arrived the first items for my watercooling setup. MANY thanks to Aqua Cooled PC:
    The res is awesome, it has a hole in the bottom for a blue LED (supplied) and just in my opinion looks really stylish.
    If anyone has any experience with prepping watercooling parts please post and tell me everything I need to know as this is my first ever stab at watercooling.
    Thanks all for reading.
  5. flare
    29 May 2008
    so it looks like 'B' is winning so far then :). I'll probs ask again after its been painted. On that note does anyone know a good car sprayers (in England :p) as I don't want to risk falling at the last hurdle so to speak.
    Thanks a lot Bill as well, making of the bezel was a lot harder than I thought, and thanks as well to you as if you can remember you tried to help me find the perfect case to mod in the begining (the cheiftec dragon).
    Thanks all so far and I'll post some ideas of places where I will mount the res today.
    Flare
  6. flare
    29 May 2008
    Lo all, I have another small update for today :D.
    I got down to some more sanding with my new sanding equipment, I love custom bezels :(.
    I hate paint:
    I then filled in a few tiny gaps in with some superglue (this will be sanded down later):
    Ok I need people to suggest where to mount the res that I have, the case will be yellow outside and blue inside :cooldude: with UV yellow liquid and UV blue coils (spot the theme :p)
    A
    B
    C
    D
    E
  7. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    That reservoir looks nice, and the color scheme sounds great. Why are you hand sanding, rather than using a block?
    I'd want that reservoir visible. What about some scheme to mount it half in/half out of the back panel? Crazy idea, I know, but wherever it is, it should be visible (but not on top like that, unless you're doing a lot more to the top than I can see. :)
  8. The boy 4rm oz
    10 Apr 2008
    Nice work on the front of the case. It is really coming together, looking great.
  9. flare
    29 May 2008
    That would be awesome, I'll see if that is possible this week end :D. I am useing the sanding block now as well and thanks for all the input :D
    @The boy 4rm oz thanks a lot man I'm looking forward to spraying it now aswell so I can see how close I really am :)
  10. Geeekzor
    Geeekzor What's a Dremel?
    9 Nov 2008
    Hey, this project inspired me to fix my broken rebel9 value front. My mod cant really match up but just wanted to show you what i did :) I didnt have any battery in the camera so i used my cellphone :duh: . (Yes thats my foot i had to cover the small bright led from destroying the whole pic
    [​IMG][​IMG]
  11. flare
    29 May 2008
    haha thats cool man :D I feel proud :D.
    I got your first post aswell :thumb: so thank you.
    I'm sure if you start a new mod people will want to hear about it so deff post it on here.
    :dremel:
    Thanks a lot for reading man.
  12. Geeekzor
    9 Nov 2008
    Hey well when i get some ideas and money i will start a project with an old chassi or maybe a home welded one but as for now i will just get my new screen =) And one more thing go for B :)
  13. flare
    29 May 2008
    Lo all, sorry for the lack of update but I have a new sponsor :D.
    Tiny Tom Logan, Full case modder, case painter and all round awesome guy!!
    Click here to go to his website.
    This guy is seriously awesome and also very good at what he does, he offers a personal modding service along case spraying and so on. :D Thanks a lot Tom!!
  14. tinytomlogan
    tinytomlogan Time To Live Customs
    4 Nov 2007
    Im still not 100% on the res choice, looking forward to seeing how this project progresses,
    any updates matey?
  15. skullen
    skullen Minimodder
    31 Oct 2007
    Looking good flare :thumb:
  16. flare
    29 May 2008
    Lo all again and soz for the lack of update recently.
    Ok well this evening I got down to some serious sanding :p to get the case ready for tomorrow when I hand it to the sprayer :D
    My sanding stuff :D and my workbench/chair:
    Ok so the wet and dry sanding began. I started of with some 400 grit as I had previously gone over it with some 240 grit:
    When that was done I changed the water and started with the 600 grit:
    Got to work on the front bezel as well:
    I then touched everything off with some 1000 grit:
    Then I got down to drying:
    The finish, still really happy about the straight jigsaw line. It may not look 100% straight in the photo but in real life the eye can hardly make out any problems with it:
    I'm not too bothered about particles being on the panels as they will wash it down again and sand it a bit more apparently
    The nice contact with the home made ducts and the fan holders:
    Case as it is:
    Next update will be when the case is back, but I’ll see if I can ask nicely and get them to take pics of the painting process.
    Thanks all for reading :D
  17. Trip.X
    Trip.X What's a Dremel?
    16 Nov 2008
    That was a lot of sanding, and what color wil he come back?
    I think i missed that post :p
  18. flare
    29 May 2008
    mirror gloss yellow on the outside and gloss blue on the inside :D
  19. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    hey you going to digital overload this year?
  20. Trip.X
    16 Nov 2008
    Nice color match! :D
