Project Hummer PC UPdate (New article in Micro Computer in China)
Discussion in 'Project Logs' started by Robster, 11 Dec 2003.
  1. Robster
    Robster What's a Dremel?
    11 Dec 2003
    Well this is my first post to these forums lets see what happens.
    Well to start this project comes from my desire for a computer as well as a remote control car. ok these 2 don't really mix but should be interesting to see what happens.
    Well actually i have built a RX7 Computer before but was not happy with the performance of it while it looked good it lacked in speed both processor and video so this time out will be doing a full comp with a 3.0 Gig P4 in it as well as a Matrox Parhilia Vid Card so can do Triple Monitor off this thing.
    :duh: yah almost forgot it will be watercooled as well.
    i am starting with a 1/6th scale Hummer H2 which should give me lots of room to do what i need
    This is it before all the distruction
    Doors and Hood open so can access to everything with ease
    This is where the access for the motherboard and vid card will be
    This thing almost to nice to tear apart
    well that is it for now so hey tell me what you think
    and I will be posting more pics as i go.
    Thanks
  2. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    The system sounded nice enough on i'ts own... then to go ahead and water cool it :rock:
    what would REALLY be cool is if the car still operated normally afterwards :hip:
  3. auspex
    auspex What's a Dremel?
    27 Oct 2003
    do you live in a bar? :lol:
  4. STellY
    STellY What's a Dremel?
    24 Aug 2003
    care to show some pics explaining how big it is... because looks a bit small to be doing a full system and watercooling....
    looks like a really sweet project for sure!!! just make sure to keep teh car operational because thats always the problem with these :)
  5. Robster
    11 Dec 2003
    Yah actually i fogot to metion that i intend on keeping it fully operational.
    Hard to tell in the pictures but to give an idea the table it is sitting on is 30in across
    and as for living in a bar well sort of i run an internet cafe so do most of my work here but spend more time here then anywhere else.
    Here's a teaser for the water cooling got the rad mounted in it so far.
    tight fit but it works so far
    starting to get the pump and reservoir set in.
  6. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    Funny place to put a radiator...
    :D
  7. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    dats a big rc.
  8. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    A while back on [h]ardocp's forums a guy by the alias of project twin had a really nice log going about modding a rc chevy avalance into a pc - not with WC'ing but still he was like 70%+ done, but then he had other things in life kick in (military?) so he's left it dormant for a while
    it was pretty cool, and this looks even more challenging :D
  9. Reason_no1
    Reason_no1 What's a Dremel?
    9 Jun 2003
    If you pull this of you are a very very good modder in my eyes.....
    :rock:
  10. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    isn't that the front of the car? The seats are pointed forwards. Or do you meen fan in front of rad?
    This should be cool. What about wireless keyboard/mouse/headphones, maybe monitors as well?
    Then you could drive it around, and no one would think it was a pc. Also make caring to LAN parties a lot easier if you only have a 17" display you could put in your back pack
  11. bsodmike
    bsodmike Banned
    11 Oct 2002
    Damn.
    I was just discussing how someone could mount a shuttle onto an RC Big rig chassis :p
    This is gonna so own, but are you trying to fry your poor passengers? Maybe simulate a 'Princess Diana' incident by burning your passengers with a hot radiator leak :p
    :clap: :clap:
  12. rool
    rool What's a Dremel?
    29 Aug 2003
    I think it'd look better if you placed the fan on the other side of the rad. More "natural" look that way.
  13. bsodmike
    bsodmike Banned
    11 Oct 2002
    Specially if you got the rad painted black or chromed?
  14. Krikkit
    21 Jan 2003
    Not only would it look better, but apparently the most efficient way of cooling down a rad like that is to have th fan pulling air through it rather than blowing it towards... :D
  15. Atomic
    Atomic Gerwaff
    6 May 2002
    That is one big ass RC!
    Watercooled RC-PC, certainly some thing I ain't seen before!
  16. bsodmike
    bsodmike Banned
    11 Oct 2002
    *boing.....**boing....* damn you Atomic, your avatar has my attention... :D
  17. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    That’s a sweet looking RC…Do you plan on interfacing the two, setting up servos controlled by the PC? That would be too cool…dump the RC controller and just use the computer.
    :rock: :rock:
  18. ////\oo/\\\\
    ////\oo/\\\\ Minimodder
    16 Oct 2003
    This is going to be one very intersting project... :rock:
  19. TheOnlyAndromeda
    TheOnlyAndromeda Duh, what's a dremel?
    9 Jun 2003
    Subscribed to this thread because it looks totally awesome
  20. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    This is your captian speaking... We will be processing at an altitude of 200 feet!
    Not bad!
    I am also into rc but my nitro car engine causes the printer to glitch... maybe if I isolate the motor with rubber mounts....
    Do you think a pc in a fully operational r/c plane will work if I have the mouse, monitor and keyboard running Bluetooth????
