Project ICE-CUBE - Home made box
Discussion in 'Project Logs' started by Albertoliveira, 27 Mar 2003.
  1. Albertoliveira
    Albertoliveira What's a Dremel?
    27 Mar 2003
    Hello to you all...here goes some pictures of my box...
    :D
    it was a 3 mouth work with planning an making but I think it was a god job...
    What do you think ?????:clap:
    :p :p :p
  2. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Mmmmm, nice :D
    Looks pretty clean, though I'm not a fan of the beige optical drives or fan grills (don't ask, I have a weird hatred of them for some reason).
    It's a shame that our fingers would bleed so much without fan grills because intake fans look great without grills on IMHO.
    Anyways, nice case, where've I seen it before? A certain case gallery that is cool that I won't mention the name of?
  3. Albertoliveira
    27 Mar 2003
    :confused: :confused:
    It's a cube in acrilic, perhaps there is some of them in the NET, nothing is impossible.
    But this is a project of mine and made by me...not a copy to anything or someone...I know that box you are talking about and it's a lot different, I think the only thing that is the same It's the shape of the box... a cube in acrilic.:D :D
  4. NiHiLiST
    18 Aug 2001
    Haha, no, I've really seen one in acrylic like yours with the drives and fans in the same positions etc :)
  5. Albertoliveira
    27 Mar 2003
    :eeek:
    could you please give me the link ?????:confused:
  6. NiHiLiST
    18 Aug 2001
    I can't remember where I saw it, but thinking more carefully it might have had 80mm fans at the top and black drives :confused: I'll look around for it and see if I can find the link.
  7. Albertoliveira
    27 Mar 2003
    thank you...:D
    because it will be hard for me to have a box like my on on the net...the people here in my forum may say that I did copie my box from another one....
    and it's not true...I didnt never saw anything like it before.... :waah:
  8. IceColdFever
    IceColdFever What's a Dremel?
    28 Mar 2002
    nice...i like the bloo glow!!! Fans all over!
    I'm sure i know the answer, but why two PSUs?
    Is the top of the case attached?
    I have also seen the acrylic cube case called the IceCube. Regardless i think this one looks good.
    I had a similar idea...Mine was even going to be IceCube...(notice my username) but i guess i'll have to use IceT. My first name starts with a T. Now you got me thinking...case shaped like a giant T....hmmm
    Anywho. Like the case. Get some different fan grills and you will be kicking!!
  9. NiHiLiST
    18 Aug 2001
    Don't worry, you can't expect every mod or case to be original; there's hardly any that couldn't be "copied" from somewhere else.
  10. Albertoliveira
    27 Mar 2003
    I have the two psu linked together to start at the same time...1 is for the system and the other for the secundary stuff's 2x 120mm Fan's and Cold-cathode ( cooling in general).
    yes, I already think of that... fan grill's like biohazard or atomic power or something...
    not yet, i'm waiting for the acrilic bolts ...:D
  11. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    NiHiLiST has a good point about the fan/finger guards. I already lost a slice of finger on some simple 60x60mm coolermaster fan *auch* It bled like hell...
    Albertoliveira: I really like the box! :rock:
  12. KiwiCobra
    KiwiCobra What's a Dremel?
    27 Mar 2003
    Vvvvvery nice !! :clap: I was going to ask about the twin PSU's, but someone already asked....
  13. ReFredzRate
    2 Sep 2002
    Albertoliveira: the specs in your signature are the specs of the system running in your ICE-CUBE?
  14. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Very nice. I dont mind those standard fan grills myself but im quite new to this so maybe i will learn to dispise them :D Is therte anything inside the beige coloured bottom section? It looks too deep to not have stuf finside it!
  15. Albertoliveira
    27 Mar 2003
    yes, :D I know that pain, I already felt it on the blades in the papst 120mm in the front :hehe:
    I have finger guards in the front, but inside the box I don't need them because probably I only touch something inside with the power off ( I hope so ) :D
    And you peolpe know that finger guards make more noise than without them....and I want my cube to be silent ( and it is ), besides the 2 PAPST 120mm with 165CFM's ( with a voltage control switch on the back ).
    Yes, my signature show thw material inside, and if you want tempratures : idle 36/37 and in full 38/39º- the diference in idle and full it's only 2º......:D :D
    no, I dont have anything over there, but in the future probably I will put some blue neon under it.
    The bottom has that shape to hold strait the inox bars in the 4 corners of the box. His function is to bare with the weight and to hold the all box...
  16. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Sweet box:D
  17. NiHiLiST
    18 Aug 2001
    You haven't truly felt the pain until you manage to drop a running 120mm YS-Tech 135CFM beast onto your finger and manage to shatter a fan blade off :wallbash:
    Now THAT'S pain.
  18. ReFredzRate
    2 Sep 2002
    Albertoliveira: Those temps are in celsius or fahrenheit? If they're fahrenheit, then it's pretty cool, but celsius... I'm running my system on 24 celsius :p lol... j/k The temps are ok, since you're not running the same crappy, overcooled system that I run :)
  19. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    Very nice rig:D
    DDK
  20. Atomic
    Atomic Gerwaff
    6 May 2002
    Surely it'd have been easier just to get an uprated PSU rather than have two seperate ones?
    Sweet case tho.
