Case Mod - In Progress Project : Infinity CM Stacker (Reservoir 100% complete)
Discussion in 'Project Logs' started by DoOb's, 14 Sep 2007.
  1. DoOb's
    DoOb's Overclocker/Modder
    7 May 2007
    Here is my design for my Dual 120mm radiator fan grill, its actually the logo for the Infinity Car sound.
    So im off to go and cut it now.
    Pics later
    Cya
  2. Colossous
    Colossous Minimodder
    28 May 2007
    Its coming together DoOb@s ! :dremel:
  3. DoOb's
    7 May 2007
    Thanks Colossos
    Ok so KB came around and froze my cutting time, which means i would have been done by now, lol jks anyway.
    A whole day has almost gone by and im finished the dual rad grill. Eish my fingers after some pins and needles and hour and a half of filing im done. And dam i missed lunch, so im eating Cereal. lol
    Ok here we are from start to finish....:
    Program used was Freehand MX10, print the design out and stuck it down will pritt .....has another spoon fill of cereal... ok here this pic
    Clamped it down with a piece of alli over it to i wouldnt clamp off the paper design. And here ive cut the first hole
    Ok so after friends had come and gone. I finally got to this.... As you can see closely some of those corner got a bit wide when cutting, thats becoz i had to put a new disk on.
    Ok so now i start filing this grill, .....filing filing filing,,,, and now i got to this point....
    Used some 1000grit water paper to get rid of any final not smoothen edges...
    And then i thought i would polish it with some braso to see how it look kinda if i were to polish it proper.....
    Hope you guys like me Radiator grill. Still gotta make another two grills... eish
    Alrighty until next time... :wink: :wink: :wink:
  4. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Looks awesome Do0b's! Seriously nice sanding and polishing there :)
  5. DoOb's
    7 May 2007
    Yea and thats not even properly sanded either hey dean hehe
  6. DoOb's
    7 May 2007
    Hey guys, I was suppose to do more than i did today, but ag, was doing other crap.
    Ok so ive got my HDD's mounted nicely inside.
    And the front Bezel Yea got that in aswell, Perfect i must add, well to my satisfaction at least. Ok Im gonna let the pics tell you what ive done and what ive done to mount the front Bezel
    When i have the front bezel in again (properly coz as the pics show, i only had 4 brackets in for the bexel), im gonna have to make new holoes for the DVD-RW... Um and dam its gonna be a mission once ive got this stuff in. Because then i gotta get the motherboard tray in, and then bolt that down... Modding Cheesecake i suppose.
    Enjoy :D
    Until next time...:blah::blah::clap:
  7. C:\Joshy
    C:\Joshy How much cake can you eat in a min?
    30 Aug 2007
    I LIke It... Great idea with the HDD's.
    Keep up the good work.
    did you say this is going to be on water or air.?.?.?
  8. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    looking very good DoOB's .......... those HDD's should keep nice and cool down
    there with the fan in front of them .................:thumb:
    and the radiator grill looks awesome too .........
    Alan
  9. Asulc
    Asulc Minimodder
    18 Jul 2007
    Hey Doobs.
    I am loving the case. the res grill looks great
  10. DoOb's
    7 May 2007
    Water hey Josh, thanks mate...:cooldude:
    Yea for sure, the drives i find vertical have a better cooling aid that if they were horizontal. Keep an eye out for this mod..
    Yea the radiator grill looks rad hey, still alot of work to go..
    Thanks mate
  11. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I like the work you're doing so far, Doobs ;)
    Oh and the title addition about the rugby: My bf is from SA originally and he was teasing today about digging up his old SA rugby jersey to wear into university tomorrow. I told him he was evil. ;P
  12. DoOb's
    7 May 2007
    Anyway, heres something small i did today, wasnt really ampt to do much but did somin.
    Got the DVD rom mounted into, made new holes etc. and then also made the pump inlet and outlet holes.
    Pics to follow.
    I know that holes looks siff, im gonna clean it up, even tho you not gonna see it with the cover on...
    The dvd rom cover isnt on yet, but to give you the idea. Im gonna rather use double sided tape instead of two allen cap screws, or i might see how i feel. Or i do it later.
    DoOb's
  13. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    This is gonna be one clean stacker DoOb - looks great so far mate!
  14. Colossous
    28 May 2007
    Totally agree ! Loving it DoOb's, more please ? :thumb:
  15. DoOb's
    7 May 2007
    Thanks Dean and Colossous,
    What you think of this Rad grill, i like this logo better than the other one, I am not feeling the other rad grill, but this one i am in love with....let me know guys
  16. khanage0
    khanage0 Minimodder
    2 Sep 2007
    i like it dude:thumb:,kinda reminds me of spiderman....lol
  17. weasal
    weasal What's a Dremel?
    22 Jul 2007
    dont really like it in the model pic you did but looking at it on the case i would definately say its way better :thumb:
  18. DoOb's
    7 May 2007
    ok here they are, this is what im gonna be making.... nothing will change my mind now..
    This is what i want.
    Single one for the Front:
  19. Scirocco
    3 Jul 2007
    Good choice I think. The new grills look out of the ordinary and have a lot of style if you will.
  20. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Yup, new grills Cheesecake!!
