Scratch Build – In Progress Project: Large Wooden Tower - Finished!
Discussion in 'Project Logs' started by Spotswood, 19 Sep 2009.
  1. SquattingDawg
    SquattingDawg What's a Dremel?
    8 Jul 2009
    I am lovin this case! If I love the end product, I may have to order one as well!
  2. Guest-23315
    Guest-23315 Guest
    Coming together rather nicely :thumb:
  3. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Pretty much finished the "false" back.
    All that's left to do is route some slots along the edges of the motherboard tray and maybe another slot for the wiring for the optical drives.
    :rock:
  4. stonedsurd
    11 Mar 2009
    Are you going to route a hole behind the motherboard tray so the CPU socket area is accessible?
  5. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    i think the false back is to conceal the back, while being removable
  6. Spotswood
    30 Jul 2007
    The panel behind the motherboard tray is removable. Do you think I also need to route a hole?
  7. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Er - the reason you have a hole is usually to get at the mounting points for the CPU cooler. If that plate is removable you can get at them anyway; I think you'll be fine.
  8. stonedsurd
    11 Mar 2009
    No, if it's removable then it servces the same purpose :thumb:
  9. Spotswood
    30 Jul 2007
    External Drive Cage Completed
    I completed the the external drive cage. I used a couple of drill bits to align everything, just to make sure both pieces were identical.
    Yet another feature of this case is that each one of the drive rails can be removed for easy modding or for a custom configuration.
    :rock:
  10. Spotswood
    30 Jul 2007
    Two new 5.2mm router bits arrived yesterday afternoon. In an attempt to reduce bit breakage, I "pre-grooved" the 3/4-inch oak on the table saw, cutting an 8mm deep saw kerf. Then it was two passes on the router table, one pass at 5mm deep and another at 10mm. The end result was I only broke one bit.
    Right side panel is done:
    As soon as the 120x4 radiators arrive, I'll route out holes in the panels and apply some aluminum mesh, as modeled here:
    :rock:
  11. Spotswood
    30 Jul 2007
    Fastening the Top
    I decided to fasten the top to the case with some 'T'-nuts, but I didn't have any lying around the shop so I fabricated a simple "plate"-nut. A plate-nut is just a 1/8-inch thick piece of aluminum flat bar, taped for 6-32 bolts. The nut was bolted to a dual layer of 1/4-inch plywood which was then glued to the top. Hard to describe, but very simple to make.
    In order to accurately determine where to drill the corresponding holes in the front frame, I made some pointy marking thingies from a couple of bolts.
    The top with the pointy thingies were then pressed down onto the case, indicating where to drill.
    Perfect alignment! :rock:
  12. Colossous
    Colossous Minimodder
    28 May 2007
    Looking really cool duder :thumb:
  13. Spotswood
    30 Jul 2007
    Side Panels Fastened
    The side panels are held onto the case via four magnetic catches.
    I'm quite pleased with the holding power of these babies. They will eventually get a coating of black paint.
    :rock:
  14. timmmay
    timmmay What's a Dremel?
    9 Jul 2005
    I'm a couple of days behind but could you explain how you used your "plate-nuts"? I get the theory but where are they in the case?
  15. Spotswood
    30 Jul 2007
    The nut is in (on?) the top, here:
  16. ringo
    ringo What's a Dremel?
    14 Jun 2008
    A very cool idea to connect both parts, I like your wooden case. If I see it, I think about to make my own.
  17. Jipa
    5 Feb 2004
    Very nice construction and design, but just like with the Obsidian 800D, I just wish you also made a bit smaller model in the near future ;)
  18. Spotswood
    30 Jul 2007
    What size case would you prefer? Examples? :D
  19. Spotswood
    30 Jul 2007
    Front Panel
    I glued-up the front panel. It still needs a bit of work, but it looks so darn pretty:
    :rock:
  20. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I love it, it's a really nice finish
    I might order myself one of these at some point in the future (not now, I severely lack funds :p)
