Project: Liquidmod update 5th March
Discussion in 'Project Logs' started by revlimit, 11 Feb 2006.
  1. revlimit
    revlimit What's a Dremel?
    25 Aug 2005
    Will the Swissflow work with the AC VFD unit?
  2. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Sure, as long as you connect it accordingly. I'll be using it with my Aquaero aswell.
  3. revlimit
    25 Aug 2005
    Do you know who carry this flowmeter in the states?
  4. Koradhil
    9 Nov 2004
    No, I live in the Netherlands and Swissflow is also located in the Netherlands, I just got it straight from them. I have seen other people here on BT though which have one aswell and live in the states.
  5. revlimit
    25 Aug 2005
    minor update
    I didn't like the silver face that came with the Aquaero so I modifed a bay cover instead. Sorry for
    the image quality and I was too lazy to stop and take step by step picture.
  6. revlimit
    25 Aug 2005
    I contacted them and they sent me a powerpoint on the flowmeter but didn't mention how I can purchase one.
  7. revlimit
    25 Aug 2005
    Here is my first fan grill. I got the idea from one of the project log at Bit-tech.net
    Got this cool kit from Costco.
    Took me awhile to design this.
    Got this huge 4 1/2 hole saw off Ebay for $10, much cheaper than Home Depot.
    Here it is nice and polished.
  8. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    C'mon, please tell me EXACTLY how you made this cut
    I was thinking about doing just the same, and now that I see how perfect it can become, I believe I have to get me an Aquaero myself.
  9. Koradhil
    9 Nov 2004
    I guess he just took off the front plate of the Aquaero and used it as a template to draw the design on that coverplate, then using a drill for the buttonholes and a dremel for the lcd cutout.
  10. revlimit
    25 Aug 2005
    I used the original face plate as a measurement and I print out another template with the same software that I used to make my fan grill. The software I use for the drawing is called Smartdraw. You can also use the original and draw it on a piece of paper. Make sure you make the window smaller than the original because the LCD display is not that big.
  11. revlimit
    25 Aug 2005
    Here is are some cutting of the case for the case handles and AC reservior.
    This is for the AC grill where the radiatior will be placed.
  12. customh
    customh conflagration.
    22 Oct 2005
    Just curious if i am correct on my guessing up there, is it a swiftech storm?
  13. revlimit
    25 Aug 2005
    Yup it is, the last of its kind, hehe.
  14. customh
    22 Oct 2005
    Why the last of its kind?
  15. Koradhil
    9 Nov 2004
  16. z4114
    z4114 FACE!
    25 Jun 2002
    Hey revlimit, can you tell me who makes those case handles you got there? And did you purchase them in the States?
  17. revlimit
    25 Aug 2005
    I purchase this locally in the States. You can check with http://www.mnpctech.com the carry the handle or just froogle for it.
  18. revlimit
    25 Aug 2005
    It appears Swifttech is bringing back the Storm block with a ver 2. Couple months ago, they were being replace by the Apogee block and there was much debate on the Apogee block vs. the Storm block.
